Dash lenses? Change update?
Old Apr 26, 2018 | 03:10 PM
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
Default Dash lenses? Change update?
Are there any pluses or minuses to replace the spedo tachometer and center console gauge cluster with new lenses?
Its apart so now would be the time to put a nice clear set in.
Old Apr 26, 2018 | 03:42 PM
Alan 71's Avatar
Alan 71
Hi C3,
If the lenses seem to be scratched or marred enough for you to notice it, NOW would be the time to replace them.
It's an easy job if the driver's side pad and gauges, and center gauges, are already apart.
Regards,
Alan
Be very careful as you put things back together so that you don't have any finger prints on the inside of the lenses or dust on the face of the speedometer, tachometer, and other gauges.
You might think about replacing the lenses on the heater/defroster control too. That a pretty straight forward job if you have the center gauge cluster out.
Old Apr 26, 2018 | 03:48 PM
DUB's Avatar
DUB
Not this may matter to some. But when you look at the reproduction small gauge lens. It may not be perfectly flat where the lens goes flat across the gauge. I have seen them have a quite warbly/orange-peely look to them.
As for the speedo and tach lenses....they are fine.
And NOW is time and you won't regret it.
DUB
Old Apr 26, 2018 | 07:40 PM
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
Any suggestions for where to purchase? Does it matter?
Thank you for the help
Old Apr 26, 2018 | 08:58 PM
ignatz's Avatar
ignatz
I made this change to the center console and discovered the new lenses were clear but as DUB mentioned, the reflection off the front face was wavy. It might not bother you but I expected better.
Old Apr 27, 2018 | 01:21 AM
7T1vette's Avatar
7T1vette
If the present lens-plate has no damage, you could just re-polish the gauge lenses and put it back together.
Just musing to myself: Why does everyone want to replace the original parts if they merely have cosmetic problems? Replacement parts are generally of MUCH lower construction quality and cost MONEY to purchase them. If the existing part is functional, just refurb it!!
Old Apr 27, 2018 | 07:27 AM
Alan 71's Avatar
Alan 71
Hi EC,
I used Meguiar's #17 Clear Plastic Cleaner and #18 Clear Plastic Detailer on the original lenses for my 71 and was pleased with the results.
As I said, be very careful when you reassemble that you don't end up with a piece of fuzz on the lens or gauge face.
Regards,
Alan
Old Apr 27, 2018 | 08:46 AM
DUB's Avatar
DUB
Get them from anybody who sells them I do not think one company over the other has a better one.
I also prefer to clean and polish the lenses when possible. Sometimes sanding on them is needed due to bad scratches. But the owner always has the option. Because if I spend an hour restoring this lens. That alone in itself costs more than putting new one in that does not matter to them. I guess it may also boil down to how much you value your time ...obtaining the products needed tor restore it....and the importance of the perfection of this particular part.
I know it may not be seen by others. But the new small gauge lens is not quite there in my opinion but it does work and the average person is not going to see what some of us pick up in how well it is made.
DUB
Old Apr 27, 2018 | 01:09 PM
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
This is exactly why I posed the question. Most of what I am doing is refurb and reinstall, in other cases finding oe stuff and reinstall. Based on what I have read I will likely swap out the spedo and tach and polish existing small gauge lenses
Old Apr 27, 2018 | 10:54 PM
7T1vette's Avatar
7T1vette
Always do what you think is best for YOUR situation. But, as you have indicated, use whatever you can of original parts wherever you can.
To Dash lenses? Change update?
