Camber Adjustment Maxed Out
Old May 4, 2018 | 08:54 AM
  #41
DUB's Avatar
DUB
Originally Posted by 2mnyvets
Adjustables are expensive! Can we just remove the bushing to get the extra length?
NO...you have to have a bushing of some design there.
You need to look and understand about the part that is being discussed here. Then you will understand why what you are asking does not make sense nor will work at all.
DUB
Old May 4, 2018 | 12:24 PM
  #42
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
You're kidding......RIGHT????
And BTW, if you wanted to compensate for too much negative camber, you'd need to SHORTEN, not lengthen the strut rods....
Old May 4, 2018 | 06:47 PM
  #43
DUB's Avatar
DUB
Obviously....that person was kidding due to so much not being even in the 'ballpark'.
DUB
Old May 4, 2018 | 11:12 PM
  #44
2mnyvets's Avatar
2mnyvets
DUB
Sorry DUB. Sarcasm not ignorance. IE If 3/16" doesn't matter why do you need the bushing ?
Now I do have a question. Sounds like some of your customers are using adjustables instead of fixing the real problem. How would adjustables compensate for the real issue? With the 3/16" play won't the top shaft be moving in and out and camber be changing a few degrees randomly? Sounds like this is what the OP is trying to do. Is it a viable short term solution?
Old May 5, 2018 | 08:06 AM
  #45
leadfoot4's Avatar
leadfoot4
A) you need a bushing, because the strut rods have PIVOT POINTS. If you didn't have bushings, that would mean that the rods were "hard bolted" into position. How are the struts going to pivot, as the suspension rises and falls, with the unevenness in the roads?
B) most of the adjustable strut rods use "rod ends", or as they're also called, "heim joints". These rod ends have bodies with male threads, which attach them to whatever you need the ability to rotate. In this case, it's a Corvette suspension part. The bodies of the rod ends need something to screw into, thus a piece of steel tubing, creating the "adjustable strut rod".
C) even the OE strut rods are "adjustable". They have to be, as this is how rear camber is set. The OE struts work off of an eccentric, at the inner end of the strut.
Ignoring the side yokes isn't a good "short term fix", since they'll only wear more, and cause more issues.
Old May 5, 2018 | 09:16 AM
  #46
zwede's Avatar
zwede
Something I don't see mentioned yet is the fact that the tip of the yoke is only surface hardened. Once that hardened layer is gone wear increases drastically. What I'm getting at is that a summer of driving will wear the yokes more than you may think. You need to keep a very close eye on them unless you're willing to junk the housing.
Old May 5, 2018 | 10:01 AM
  #47
DUB's Avatar
DUB
This is an addition to post #45 and 46.
IF you do not have a bushing in the end of a factory strut rod. It would be a like pencil on a soda pop can. The pencil is the bolt that would go through the can and the inner diameter of the soda pop can is the inner diameter of the strut rod end. THUS...the strut rod is useless due to it can NOT be adjusted and hold that position. Because the air space between the inner diameter of the can and pencil is so great. This area MUST be at a very close tolerance.
3/16" of end play on the side yoke IS a big deal.
YES. When the side yokes are worn.....and have significant in and out play when the suspension is unloaded. The half shaft can move...thus it changes the camber.
YES. Installing an adjustable strut rod to by-pass the evident side yoke wear is a short term repair that may or may not achieve the desired end result.
The adjustable strut rod can be shortened due to their design...which is what is needed in this scenario.
DUB
Old May 5, 2018 | 10:05 AM
  #48
DUB's Avatar
DUB
And knowing that these side yokes are worn this much. I would also bet that the clutches in this differential are also worn out due to the slurry of material that has been worn off has been circulating around inside the differential and eating of the clutch friction surfaces.
DUB
Old May 5, 2018 | 01:34 PM
  #49
leadfoot4's Avatar
leadfoot4
When I dealt with this issue, on my wife's C-3, I was still working for a large manufacturing corporation, that had all sorts of internal maintenance shops, that could keep a huge factory going, as well as do some "government jobs" for the employees.
It may have been a little "bubba", but I removed the yokes, which fortunately still had the snap rings intact, for a dimensional reference, and we added material to the ends of the yokes, by welding it on. After we built up about 1/8-3/16" of weld, I slid the yokes back in, and measured how much had to be removed, to obtain the proper clearance between the yokes and the spider gear shaft. The excess material was ground off.
Old May 5, 2018 | 02:26 PM
  #50
zwede's Avatar
zwede
Yeah, that was quite bubba unless you checked hardness and hardened it afterwards as needed.
You'd been better off drilling a hole in the end of the yoke and machining a button out of hardened steel. That's actually a quite acceptable repair.
Old May 6, 2018 | 02:54 AM
  #51
2mnyvets's Avatar
2mnyvets
[QUOTE=leadfoot4;1597132367]You're kidding......RIGHT????
ABSOLUTELY.......
Old May 6, 2018 | 08:27 AM
  #52
leadfoot4's Avatar
leadfoot4
We did.........as I mentioned, it was a LARGE corporation, with abundant resources.
Old May 6, 2018 | 09:19 AM
  #53
zwede's Avatar
zwede
Cool. Maybe you can convince them to take up a side business rebuilding yokes. Most of the ones on the market now are trash.
Old May 6, 2018 | 09:30 AM
  #54
DUB's Avatar
DUB
on both parts...the side business thing and the yokes today are all 'pot luck' on what you may get.
DUB
Old May 6, 2018 | 02:39 PM
  #55
leadfoot4's Avatar
leadfoot4
Sadly, VERY sadly, the once thriving corporation I worked for, Eastman Kodak, ironically invented "digital photography", the innovation that pretty much put EK out of business. At one time, the company employed 70,000 people, and that was just in the Rochester, NY area. That roster, today, is down to about 5000......
