Having Problems Installing Distributor
Old Mar 27, 2021 | 01:56 PM
  #41
drwet's Avatar
drwet
Originally Posted by 3X2
Another suggestion: remove the gear and install the distributor without the gear and see if it fits correctly. Look down the distributor hole to see which direction the oil pump shaft faces, rotate the distributor shaft the same direction and see if it fits. If it does, there is an issue with the gear.
Not a terrible idea but if you decide to do that make sure all of the shims come off with the gear. You don't want to drop any parts in there.
Old Mar 28, 2021 | 01:06 PM
  #42
How Are You's Avatar
How Are You
Are there different distributor gears for flat tappet and roller cams? I know it shouldn't affect fit, but premature material wear.
Start watching at 1:15
Old Mar 28, 2021 | 02:15 PM
  #43
3X2's Avatar
3X2
Physically the gears are the same size and tooth count. Difference is the metal they are made of.
Old Mar 28, 2021 | 02:48 PM
  #44
How Are You
Originally Posted by Jebbysan
If not, sometimes replacement gears have no “leader” or chamfer to receive this. The shaft will sit slightly cockeyed in the hole and no way will it take the shaft.
The way to solve this is to remove the gear and chamfer.
I have seen this quite a few times, especially on MSD stuff, so it is worth checking.
I checked the gear and there is no bevel on the shaft. See pic. So I have to remove the gear to bevel both sides?
Old Mar 28, 2021 | 03:08 PM
  #45
lars's Avatar
lars
That's your problem. Very common issue on aftermarket distributors and replacement shafts, especially the Chinese-made stuff. The end of the shaft needs to be modified to look like this:
Without the bevels shown, it is almost impossible to get the distributor dropped in to engage with the oil pump drive shaft.
Lars
Old Mar 28, 2021 | 03:15 PM
  #46
How Are You
Okay, I will remove the gear and bevel the shaft.
Thanks Lars, Jebbysan and everyone so far!
Old Mar 28, 2021 | 03:23 PM
  #47
'75's Avatar
'75
The gear should have a dimple, make sure that aligns with the rotor contact.
Old Mar 28, 2021 | 03:33 PM
  #48
drwet's Avatar
drwet
[QUOTE=How Are You;1603216701]Are there different distributor gears for flat tappet and roller cams? I know it shouldn't affect fit, but premature material wear.
Its not actually flat tappet vs. roller that requires different gear materials, its what the cam is made of. Just follow the cam manufacturer's recommendations.
Old Mar 28, 2021 | 03:48 PM
  #49
3X2's Avatar
3X2
Correct. Different camshafts require different distributor gear material. I think billet camshafts are the ones that need a brass or composite gear.
Old Mar 28, 2021 | 04:34 PM
  #50
How Are You
Austempered Ductile Iron is what my camshaft is made of. I assume that’s compatible with the gear that came with my distributor? Just making sure.
Old Mar 28, 2021 | 07:18 PM
  #51
How Are You
Still doesn't go in.
Old Mar 29, 2021 | 08:19 AM
  #52
walleyfisher's Avatar
walleyfisher
Years ago, I was changing my distributor gear and the replacement fit the distributor shaft and roll pin went in easy, but he inside diameter of the new gear was smaller (by thousands) and would not engage the oil pump shaft either. just for ***** and grins, try putting your old gear on the new distributor
Old Mar 29, 2021 | 08:52 AM
  #53
wilcar's Avatar
wilcar
You have done all you should at this point. Send it back to who ever you bought it from and get a refund. Put your old unit back in or have it recurved or rebuilt!
Old Mar 29, 2021 | 12:01 PM
  #54
How Are You
Read first post
Read first post
Old Mar 29, 2021 | 12:14 PM
  #55
walleyfisher
Read first post
Read first post
I missed you no longer have old dizzy, still going to say you need to try a different Gear, the aftermarket MSD must not fit in my humble opinion.
https://www.summitracing.com/parts/a...CABEgIJWvD_BwE
Old Mar 30, 2021 | 11:33 AM
  #56
How Are You
I got it in with the help of my mystery neighbor. Screwdriver trick worked. Actually it was a hacksaw blade. Thanks Frank!
Old Mar 30, 2021 | 11:34 AM
  #57
How Are You
...and thanks everyone for your help and suggestions!
To Having Problems Installing Distributor
Old Mar 30, 2021 | 11:47 AM
  #58
7T1vette's Avatar
7T1vette
The screwdriver is not a "trick"; it is a necessity to get the parts aligned.
Old Mar 30, 2021 | 12:00 PM
  #59
walleyfisher
Here's Engine masters showing how to install without the screwdriver
Old Mar 30, 2021 | 12:01 PM
  #60
How Are You
You know what WOULD be a neat trick that involves a screwdriver?
