1980 Budget build
Heads seem like a lot of work to get the right ones with the least amount of complications. From what i have read headers true duals and a good tune up seem to get me right where i want to be?
I am torn between the cheap aluminum heads and the expensive ones and i will admit my basic knowledge of parts swapping vs tech knowledge of everything that needs to be done or looked for is intimidating.
If you buy new heads you really gotta consider the motor as a whole. New heads aren’t going to do much if you keep the low compression pistons and small lift cam.
the L82 is a very good base to work on.
But with the stock torque converter, it will still be a dog. If the transmission is out to be rebuilt right now, do some research on fixing that problem.
OP here is my tuning on stock 79 L82 manual, and yes i am on a budget...
https://www.corvetteforum.com/forums...x-power-2.html
before you go jacking around with distributor springs etc..
note the L82 along with cam and pistons also has a great vacuum advance already, all in 2000 rpm and limited advance..(at least in 79 maybe someone has the manual for 80)
for what you are looking for .. no way am i changing heads.. (budget).
tune it up, NGK plugs good oem wires, cap rotor.. exhaust ( i would not even go headers for budget) but for sure duals no cat if you can.
all on budget and all can support other upgrades.
consider unless carb very nice a Lars rebuild..no better value/ knowledge and engine tested performance. Thread below
https://www.corvetteforum.com/forums...l82-q-jet.html
The stock heads are quite a cork in the system.
If you get new aluminum heads decide if you want to keep the cam and stay flat tappet or go roller cam.
There are lift and valve spring differences.
Next, how much you spend on those heads is almost directly related to the quality you will receive. You can get decent heads for the $1200-$1500 range. If this is for the street look for 180cc or close to that for intake side volume. 2.02 intake valves. 195 cc heads will be a little lazier and shift the power to a higher RPM range.
For $2000 ish dollars are the AFR eliminator 180 heads.
The enforcer's are a lot cheaper and as cast vs cnc'd. around $1300
Cast iron, you could get a set of vortec heads. Those can be found cheaper and provide pretty good flow increase over stock.
A set of 1.52 roller tip rockers and good pushrods will help too......the stock rockers are so **** poor in quailty control that the ratio can be a shitty as 1.4.....
I do not recommend 1.6 rockers on a stock head as they almost always rub on the pushrod hole in the head......
The stock L-82 timing curve is not what you really need either as you would have to dial 20 degrees initial to get 36 total.....which is optimum.....actually the L-48 distributor with lighter springs is a better choice.......also with the L-82 vacuum can......
The L-82 heads flow a tad better so all of the above mods including long tube headers will put down 280hp to the tire and 350 on an engine dyno........
BUT....here is the bolt in the gears.......stock heads are pretty terrible as I have said over and over........and most are wore out in this day and age.....BUT, if you can find a nice set, or yours are in very good condition and the guides/seats check out....you can buy a brand new set of valves for about $40 from Enginetech, $15 for premium valve seals, and $100 for a Z/28 spring, lock retainer kit from Elgin.......now purchase a nice carbide bit set for $100 and a die grinder for $50.........I can port and blend a set of these stock heads now in about 4 hours.......removing the heavy ledge in the bowl....and some port match on the face of the runners. If I have a block available....I bolt it on and scribe the chamber from the bottom, then grind the chamber back to that scribe to unshroud the valve..........take your intake/exhaust valves to a machine shop and have them backcut for $50......assemble these heads......now you are at about 390 hp......and it is a very nice running engine.......the extra head flow is a boost all over the curve for hp and torque.......I have done this about a dozen times over the years......and plan to do it soon to my L-69 spec 305 in my 82' Z/28.....it is just so cheap to do......and very backyard satisfying.....make sure to lap your new valves in really good.
A blended L-82 head with backcut valves will flow in the upper 230's on the intake......from the 2.02 valve......a 1.94 heads about 5 less cfm.....
BUT....I have ported a lot of heads and know where and what to grind.......not everyone can get there or cares to.......I basically only do it for my own stuff but I did a pair of 68' 327/300 heads recently and that engine pulls very strong.......
This is why heads are available to buy.........but $$$$$$......
Jebby
I was doing that stuff to these cars when they were new. You are spot on with all your observations.
Jebby
Yes, you need an electric choke and they are cheap and easy to install........earlier models are harder and more expensive to convert......but most who block the plate say it just takes a bit longer to kick off with the stove.
Another thing that works really well is the oil splash pans in the valley that Moroso and others sell........keeps hot oil off the bottom of the intake.......the intake is going to heat up one way or another...there is water going through the front, sometimes the back and the heads will eventually transfer heat to the intake through the bolts.......but every bit helps........oil temp is hotter than water temp so you can see how this will work.....
I run my car with the rubber flaps out of the upper A-Arms so the air from the fan has somewhere to go.......this helps a ton........
The last thing is to make sure you use the proper 1/4" spacer/gasket for your Q-Jet........I use 1/4" phenolic for Holley's......the correct gasket is available from Cliff's........
With proper timing, and all of these mods....you will **** how much cooler the engine is under the hood from stock.......
Jebby
Here are the links to what I did based on feedback from the fourm.
L48 Top end upgrade
1980 L48 upgrade
TKO600 conversion
Big Thanks TKO swap
TKO 600 not fitting on 1980 C3
3.53 or 3.73 rear end
L48 Top end upgrade
Rebuilding "joserpaq's" 1980 Q-Jet
"Speedmaster aluminum cylinder heads for SBC, 2.02 intake valve, 1.60 exhaust, 210 intake runners, 64 cc. Valve springs are good up to a 650 lift flat tappet cam, guide plates, $800 for the heads and $950 with the scorpion full roller rockers 1.5 ratio. good heads, have a couple of scratches"
I would walk away….
Jebby
these are what im running but I bought mine bare for $300 and loaded them myself after porting. I used better hardware than these have.
https://www.ebay.com/itm/29199616916...3ABFBM_MS1xvNh
I should point out I went from older dart iron eagle 64/180 heads to these and the improvement was noticable.. so much so I had to rejet..
