Erod ls3
Old Oct 5, 2012 | 04:19 PM
  #221
3D87C4's Avatar
3D87C4
They did another exhaust fitting today: manifolds, CATs, O2 sensors all tack welded in their final positions. Everything fits. Nothing touches anything it shouldn't. Installation instructions followed to the T. Gonna pull it all for final welding, plug an extra hole or two in the new manifold, then put it all back in for good & connect it up to the rest of the (original) exhaust system. I'll upgrade the CAT back system later.
Old Oct 5, 2012 | 04:49 PM
  #222
ch@0s's Avatar
ch@0s
Old Oct 5, 2012 | 05:11 PM
  #223
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Pictures of you doing a burn out
Old Oct 5, 2012 | 05:52 PM
  #224
85MikeTPI's Avatar
85MikeTPI
Very nice!!! I knew it was gonna be a race to which one of us would get our exhaust work done first.. Took me over a month, but it's well worth it.. You're gonna love that car when you can finally drive it..
Old Oct 6, 2012 | 12:10 PM
  #225
856SPEED's Avatar
856SPEED
Nice thread!
It's good to see you stuck by the project through the thick and thin of it!
I can see this project being in my future less the California Natzi emission problem
Old Oct 6, 2012 | 12:57 PM
  #226
3D87C4's Avatar
3D87C4
Thanks.
It's even better the shop actually doing the swap has stuck with it. An LS swap is tricky enough without the added CA smog requirements that come with the EROD package, and a customer (me) who still wants the stock creature comforts like cruise control, AC, etc.
They keep plugging along and are getting awfully close.
After the exhaust system is finished up, some connector pins are on order for the tach/speedometer adapter wiring, the cruise control wiring has to be finished, and we're waiting for the kwik AC bracket to show up. There's also some question as to which intake/air filter to use---the one that comes with the EROD is pretty bulky---with the C6 style favored if it will fit.
Old Oct 6, 2012 | 01:36 PM
  #227
ch@0s's Avatar
ch@0s
Thanks.
I bet the stock intake would fit just fine.I put a claw on mine but im not sure it will fit your vette.
Old Oct 6, 2012 | 05:19 PM
  #228
856SPEED's Avatar
856SPEED
I would guess the early C4's would have an easier time since the ECM does not control the gauges. I would also guess if you have an 85 like me, there would be no issue regarding ABS (I don't have that) or other computer controled problems since these ECM's are somewhat behind on 21st century technology.....having said that,
the big thing for me on this conversion would be to somehow have the upgraded, up to date computer controlled EFI to better accomodate tuning......these early EFI cars are getting long in the tooth and harder to find anyone to tune them if you are running modified engines.....LS tuners are a dime a dozen....also
it just seems these later archtecture powertrains have less oil leaks, are lighter, and respond all to well to upgrades.........the only downside I have with LS engines.......they just "AIN'T PRETTY"..........but I guess I could get over that pretty quickly with the enough HP!
I guess you can do whatever you want as long as you have the funds to throw at it, hugh??
again, I embrace this project like ch@os' ...awesome...would like to see an LS7 C4 out there too!!
Old Oct 6, 2012 | 06:18 PM
  #229
3D87C4's Avatar
3D87C4
I was looking at your claw photos yesterday.
We've talked about using the stock intake but aparently this would entail quite a necking down of the airflow so something bigger is preferred. Also, the installation instructions make me leary of using anything smaller:
Air Cleaner It is recommended that the provided dry element air
cleaner be used. However, if an alternative air cleaner is used it must
be of the dry element variety. NOTE: Emissions compliance and
fueling cannot be guaranteed if a different part is used
Old Oct 7, 2012 | 09:30 AM
  #230
85MikeTPI's Avatar
85MikeTPI
Does the EROD kit use the "LS7" card MAF ? If so, the C6 intake works great for that. I'm using one on my L99 swap and it's a pretty good fit though could use some trimming to make it perfect.
Old Oct 8, 2012 | 01:45 PM
  #231
3D87C4's Avatar
3D87C4
I don't know. The relevant part numbers are:
15865791 Mass Airflow Sensor
19166574 Mass Airflow Sensor Bracket
Here's what the installation instructions have to say:
I looked, but couldn't find seperate installation instructions for the LS7 EROD package.
Old Oct 8, 2012 | 02:07 PM
  #232
85MikeTPI's Avatar
85MikeTPI
Yup, that's it.. If you grab a C6 (LS7 preferred, but LS3 will work) Intake and filter it will have the bracket built in. Otherwise you can TIG weld the aluminum sensor bracket to any round aluminum tube and make your own intake tract.
Old Oct 8, 2012 | 03:18 PM
  #233
3D87C4's Avatar
3D87C4
This is an area I'm simply too far away to contribute & have to trust to their judgment. They have a variety of intakes on hand. I think the radiator orientation in the earlier C4's makes it harder to get the intake into the cold air region.
Old Oct 8, 2012 | 04:39 PM
  #234
85MikeTPI's Avatar
85MikeTPI
Oh, ok. I thought you were asking for advice/options on what intake to use...
Old Oct 9, 2012 | 12:50 PM
  #235
3D87C4's Avatar
3D87C4
No worries, I value your comments and input, and have passed along several suggestions recieved in this thread. (and they are reading it too)
The issue with the intake is fitment & since they are hundreds of miles away I can't look at it and put in my 2 cents. I believe Ch@0s' radiator is installed at an angle that helps with the intake routing, but mine is vertical. I forget what year yours is (though '85 seems a good guess) so if you're able to get the C6 intake to fit it seems lilely it will work in mine, and that's very encouraging.
Old Oct 9, 2012 | 01:45 PM
  #236
85MikeTPI's Avatar
85MikeTPI
I had to "settle" for a '85 Z28 27-years ago, and I've
had the same screen name for the past 20 years on dozens of forums..
But my Vette is a '92, so the angled radiator may be why the C6 intake fits.. sorry.
Old Oct 25, 2012 | 01:05 PM
  #237
C4orce2's Avatar
C4orce2
I have not looked at this thread in a while. Cannot believe your build is not completed after over 10 months! My build took just under 4.5 months and I thought that was way too long. I assume most of the extra time is a result of the Calif regulations. Hope you are driving it soon!!
To Erod ls3
Old Oct 25, 2012 | 01:34 PM
  #238
ch@0s's Avatar
ch@0s
He is moving along faster than some of us. I know some that have been in the making for years. Mine was started 03-16-2011 and I'm not done yet.
Old Oct 25, 2012 | 06:08 PM
  #239
3D87C4's Avatar
3D87C4
I didn't want to jinx it, but...
was told last week he has all the parts needed, in-hand, for first start.
Exhaust done, a little wiring TBD for the Dakota adapters, still mulling over the air intake---will likely use Ch@0s's claw or suck engine compartment air (the C6 intake hit's the hood).
AC's a different matter, but I'm holding my breath expecting to hear it rumble soon.
Oh, and trust me, they want to wrap this up as badly as I do.
Old Oct 26, 2012 | 11:06 AM
  #240
C4orce2's Avatar
C4orce2
That's great news! I guess I was very lucky in a lot of ways. Kim Madsen who owned Corvette Restoration AZ was my builder and he personally did about 80% of the mechanical work on my car. The build was completed in July of 2010. Shortly after the completion, his cancer came back and he sadly passed away in May of 2011. Three months later his company went backrupt. My build was one of the last completed ones his shop had before he became too sick to continue working. Fortunately for me Wes, the gentleman from Florida that did the engineering and all the electrical work on my car, knows everything about the build and has become a good friend and my go-to guy with any questions I now have. The good news is that cars like ours are unique; the bad news is cars like ours are unique! Good luck!!
