Xtralights HID Conversion Kit
Old Nov 20, 2017 | 10:18 AM
  #61
Renfield's Avatar
Renfield
Originally Posted by aklim
These are LED? Interesting if they are since they maybe incorporate a resistor or there already is enough resistance.
Yes. Here's a link to the ones I bought.
Maybe the wiring on a 22 year old car gains resistance over time? Dunno. Just doing my happy dance for not having to jumper the relay.
Old Nov 20, 2017 | 11:34 AM
  #62
PatternDayTrader's Avatar
PatternDayTrader
Are they glass ? or are they plastic ?
Old Nov 20, 2017 | 03:55 PM
  #63
Renfield's Avatar
Renfield
Polycarbonate on aluminum. I got excited and forgot to weigh them. Maybe in the link? Very pleased and ready for the night.
Old Nov 20, 2017 | 05:06 PM
  #64
aklim's Avatar
aklim
Material does not have any effect on the bulb, I don't think
Old Nov 20, 2017 | 05:18 PM
  #65
PatternDayTrader
Do you think it might have an effect on the headlight motors ?
Old Nov 20, 2017 | 06:37 PM
  #66
aklim's Avatar
aklim
The theory is that if you lessen the weight, you can extend the life of your motor. I have not seen any hard evidence as to how much to reduce for any significant amount of benefits. Might be just conjecture that you are doing something good so I would not do it just because.
Old Nov 20, 2017 | 07:03 PM
  #67
Renfield's Avatar
Renfield
But it's just mass in rotation. So long as that mass is centered.
Old Nov 20, 2017 | 07:37 PM
  #68
383vett's Avatar
383vett
Anyone think these will work?
Amazon Amazon
Old Nov 20, 2017 | 08:20 PM
  #69
PatternDayTrader
Originally Posted by 383vett
I cant see why they wouldn't as long as the installer is prepared to deal with the fog light relay issue.
Old Nov 21, 2017 | 05:37 AM
  #70
grandspt's Avatar
grandspt
These headlights must have resistors in parallel to the high beam LEDs (diode) to simulate the stock filaments.
I am glad it worked without any mods for you
The price is great! I tried to find the wattage or current draw but they do not list it. The current draw would give a clue if they have a built in resistor. If the high beams are on and they have resistors in parallel to the LED (diode) they will draw more current than an LED without the resistor.
So it has nothing to do with 22 year old wiring gaining resistance (resistance would have to decrease and a wire cannot do that over time).
Old Nov 21, 2017 | 07:21 AM
  #71
Renfield's Avatar
Renfield
I came really close to going with those. Probably just as good, and a better price point. I was concerned that the light cutoff might not be as sharply defined.
Hook 'em up and let us know!
Old Nov 21, 2017 | 07:28 AM
  #72
Renfield's Avatar
Renfield
Now I'm really confused. Adding a bulb in-line increases resistance, no?
Anyway, very glad I resisted the urge to mod the relay while waiting for UPS.
Old Nov 21, 2017 | 08:16 AM
  #73
Paul Workman's Avatar
Paul Workman
Low beam "cutoff" line is required for DOT certification, for one, but more important to prevent blinding on-coming traffic.
Without cutoff some lights are for off-road use only. Those particular lights appear to be the off-road type. Cost is the first thing you'll notice; off-road typically cost 1/10 as much as DOT approved lights.
Old Nov 21, 2017 | 02:55 PM
  #74
383vett's Avatar
383vett
I only use my headlights on the return road after a 1/4 mile run. My halogen H4s are starting to dim after decades. I'm not concerned about the cutoff line or DOT. I did order the JW speaker lights because they weighed half as much according to specs even though they cost more. If I can save a few lbs off the front end and see better, it'll be worth it.
Old Nov 21, 2017 | 05:30 PM
  #75
grandspt's Avatar
grandspt
Hi Renfield, an incandescent bulb (our OEM headlights) has very low resistance probably only a few ohms.
So if you add an incandescent bulb in a parallel circuit to the LED light you are decreasing the resistance across the LED.
If you add the incandescent bulb in series circuit to the LED you are increasing the resistance of the LED.
Conclusion: The LED headlights you have must have a resistor (or maybe even a hidden incandescent bulb inside the housing) in parallel to the high beam LED circuit. This allows your fog light relay to work without a modification.
I hope I didn't confuse things as that was not my intention.
Old Nov 21, 2017 | 05:56 PM
  #76
Paul Workman
Default Clearing up some of the LED conversion confusion...
Here's the deal:
One should understand the operating parameters of the original (incandescent) bulb(s) and those of the LEDs are practically opposite one another, leading to special circuit considerations:
incandescent (filaments) bulbs are have relatively low resistance and thus pass a lot of current which is required to heat them till they glow (white-hot)
Light Emitting Diodes (LED) chips, on the other hand, require very little voltage (as little as 0.6V) to switch them ON. But, here's the rub: once they're switched ON, they have very low resistance and would easily be burned up when (12 volts) is applied.
So, LEDs intended for automotive use are pre-packaged, often simply large value resistors (ed) connected in series with the LED (chip) itself, drastically reducing current flow . This current reduction reduces the load on the electrical system significantly.
So...what's the issue??
Often there are relays and other components, e.g., turn signal blinkers, etc., that depend on that higher current draw to function. By simply swapping out various bulbs for LEDs there can suddenly be a number of unintended changes and how the circuits now work...or NOT work!
Two solutions:
Replace the standard "blinker" switches with LED (electronic) blinker switches: These blinkers solve many of the problems encountered when swapping the old bulbs for LEDs. However, the old blinkers would fail to work if a standard bulb were to go out, but most electronic "LED" blinkers continue to function, with or without bulbs in the circuit.
LOAD resistors: Substituting and including a LOAD resistor with the LED installation will simulate the original (filament) current draw and will return most circuits to their original operational configuration, e.g. Fog lights "issue":
By design, if the fog light switch is turned ON, the fog lights will be illuminated until the headlights HIGH beams are turned ON. (Don't ask me what the logic was for that...unless there was some law or designers were attempting to limit system current draw??).
IF it is desired to have the lights work as designed (say for originallity/NCRS perhaps?), either a LOAD resistor will be needed to provide a low resistance to ground so the relay will work, OR a more sophisticated relay circuit (beyond the scope of this post) can be used instead of the LOAD resistance.
However, as many have pointed out, simply grounding the fog lamp relay will result in the fogs being on anytime the fog switch is ON, regardless of whether the high beam switch is ON or OFF. This simple step is easy and cheap to do and my be preferable to most. And...if an LED bulb is substituted for the old bulb, the over-all current load will be reduced in spite of the fogs being ON (along with the LED high beams).
If the marker lights are converted to LEDs, the fact that LEDs only conduct current in ONE DIRECTION ONLY creates yet another set of circumstances and need of a special circuit. But, we're way beyond explaining headlight/fog light and relays. So, for now perhaps maybe consider not to change out those old bulbs?
Anyways... These are the basic considerations one might use when considering replacing the old bulbs with the more efficient (AND BRIGHTER) LEDs.
Lots of ways to skin this cat!
Old Nov 21, 2017 | 08:22 PM
  #77
aklim's Avatar
aklim
I wonder if it has a legal thing behind it? I think you cannot simply have a couple of 1 million candlepower headlights, as an extreme example. I would think that the high beams are the maximum limit and the fog lights would add too much light hence that standard? I think there is something said about you driving with high beams all day long and you can be pulled over, or at least, I have when I left them on accidently.
To Xtralights HID Conversion Kit
Old Nov 21, 2017 | 09:39 PM
  #78
PatternDayTrader
I am 100% certain that driving with misadjusted headlights or high beam headlights on is illegal in Michigan. We presently have a pending civil suit in federal court over this exact issue, because a police car was driving around with his high beams on blinding everyone, and someone else clicked his brights as a courtesy to remind the cop to turn his off, but then the cop whipped U-turn and pulled the guy over instead. Ultimately, the cop ended up shooting and killing the driver of that car. So now this entire issue is going to be looked at very carefully by the courts.
Old Nov 22, 2017 | 07:48 AM
  #79
yd328's Avatar
yd328
I'm pretty sure it's a law on how much light you project. Even my HD turns off the driving lights when the high beams are used. I believe it was in the area of 65watts low beam on standard lights. I'm not sure what the lumen rating on LEDs would be be.
Gary
Old Nov 22, 2017 | 07:56 AM
  #80
Renfield's Avatar
Renfield
Series vs. parallel makes sense. Thanks. And thanks to Paul as well.
As should be expected, I buy something fun for the 'vette then something of equal or higher value fails. Getting a MAF error code P0100.
So it goes.
