Replace or rebuild? ‘90 L98
Not as much “steam cleaning”, and the valves are pretty uniform:
Engine is stripped down to a short block now - should be easy out.
I think I’m going to rebuild it for my ‘91. Now to choose a used engine for this car… How much should I pay?
You may also want to consider posting a want to buy ad here on the forum regarding the engine. You may find someone here selling one for a reasonable price. Also Facebook marketplace is a good place to find used parts in your area. Would be nice to hear an engine run before buying it and if you find someone parting out a car locally, you may be able to hear the engine run before its pulled.
https://phoenix.craigslist.org/wvl/p...602980848.html
Or this one in Apache Junction might be just the ticket. You would be able to check it out really well. Get your heads refurbished and you would be good to go.
https://phoenix.craigslist.org/evl/p...607105936.html
Also how much will I have to spend to refurb the heads?
I texted the guy in Apache Junction and it’s still available - good find!!
Going to pick up that rebuilt short block that @Blue Bucket List found yesterday. I don’t fully understand the upgrades the guy said he put in (the cam yes, but flat-top pistons look just like the ones on the outgoing engine. Were the Vortec stock ones different?). From what I’ve read the ZZ4 cam should be great without posing trouble for the stock eprom. If anyone has experience with this, thoughts please!
Another question for this engine: he says it has a one-piece rear seal. Does this have implications?
I brought the old heads to a local machine shop with a good reputation yesterday, and they will be cleaned and inspected in more detail. Initial assessment was that there was part eaten away from rust that would have to be re-welded, and then resurfacing would be necessary. Regular valve job was quoted at $250, but this will probably be all-in around $550 assuming no cracks or bigger issues.
Then I’ll need some parts, like rockers arms and pushrods (the old ones are just nasty), probably some new sensors (unknown), water pump, hoses, vacuum lines, and I’ll need to replace a number of harness connectors and repair frayed wires. Engine guy has lifters and a timing cover. I’ll reuse the old oil pan. Hopefully old alternator, A/C, etc. are good.
My ‘91 has roller rockers (was that way when I got it). Worth doing to this one?
All in sounds like I’ll be way under the $2500+ for a used engine, and get a brand new one. Can’t wait to fire it up!
This is my first time actually digging into an engine this deeply - had to buy a hoist and engine stand. Hope I don’t mess anything up!
Thanks for all the great suggestions! Corvetteforum at its best
I should have that old block out this weekend and will post pics of the bottom end.
With that cam, which seems to have a little more lift than stock, do I need to worry about the stock rockers being ok with that? Or valve cover clearance like with roller rockers?
Rockers won't care about the added lift from that cam, but you might need to change springs due to RPM and/or lift. Valve covers will be fine.
Totally!
