Solid Rear project started! WOOHOO! Pics inside . . . .
Old Dec 8, 2007 | 05:58 PM
  #81
dr.juice's Avatar
dr.juice
Originally Posted by RUKWKR
So are you still running the ZF6? What clutch?
I was running the ZF6 with SPEC stage 3 until now. No problems at all with low 1.4's 60ft.
But now I'm going to switch to a Powerglide...
Old Dec 8, 2007 | 06:23 PM
  #82
pablocruise's Avatar
pablocruise
dr. juice,
I'm looking at switching to a 'glide also.
How do you anticipate handling the tailhousing to C-beam situation?
I guess I'll have to fab something up.
Old Dec 8, 2007 | 06:42 PM
  #83
dr.juice's Avatar
dr.juice
I'm not using the C-beam now...since I went the solid axle route, I made a crosmember for the ZF6. Now I'm going to remove it and build another one, because the trans is shorter than the ZF. But I assume you can build an extension for the C-beam to fit to the trans.
Old Dec 10, 2007 | 06:02 PM
  #84
dr.juice's Avatar
dr.juice
No problems at all. I didn't figure it was the only back halved LTX just hadn't seen any LTX cars like that yet. Do you have pics of your car? Would love to see some.
After I saw your new pictures, I realized what you meant by 'backhalf'.
Anyways, I found a few pictures....
Old Dec 10, 2007 | 10:58 PM
  #85
DVNCI's Avatar
DVNCI
LOL, as in nothing in the back half of the car anymore!
Looks like you did a nice job on yours, I'm impressed!
Old Dec 11, 2007 | 07:47 AM
  #86
dr.juice's Avatar
dr.juice
Thanks...
But the most satisfying thing is, as I said before, is that I (in this case, replce "I" with "you") can launch the car as hard as I can and it goes straight and fast. No more broken parts....
To tell you the truth, after I finished with the car I tought I should've gone the way you are going. But hey, it's never to late...
Are you going this route???
Or something like that.....
Anyway...keep us updated.
Old Dec 11, 2007 | 10:05 AM
  #87
DVNCI's Avatar
DVNCI
Thanks...
Well I debated cutting the car up, we were originally just planning on a mini-tub w/ some ladder bars but after discussing it more with my builder I decided to just get it all done and not have to worry about it again. Now I'll be able to run any wheel/tire combo I could ever want pretty much.
I'm sure it will end up looking somewhat similar to what you show above, but it will be almost 100% fabricated by my builder, he even fabricates the rear end housing itself and it looks amazing.
Old Dec 11, 2007 | 10:16 AM
  #88
fc_soldier's Avatar
fc_soldier
Wow nice work. Im setting up camp.
Old Dec 12, 2007 | 01:40 AM
  #89
red L98's Avatar
red L98
man thats going to be on short set of ladder bars
Old Dec 12, 2007 | 08:00 AM
  #90
DVNCI's Avatar
DVNCI
We would have cut the storage compartment/ABS compartment out to do it. I just meant cutting the WHOLE back out.
Old Dec 12, 2007 | 09:50 AM
  #91
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
The setup we sell for Abodies is very much like a latter bar setup and is pretty short and it works awesome. However you have to have everything just right with a short setup or you will have very little adjustment, since your movements will be pretty course...but it can work. Longer the arms even with a 4link just allows for finer adjustments to key in on the IC. When I did mine I spend a bunch of time locating the front brackets so that the main group of adjustment would be right in the required IC approximation. Another thing that helps is you can use the ride height of the rear as a fine tuning method to get the IC set. Just takes some time....and I am sure if your guy knows what he is doing, which it sounds like he does...he will have that all figured/planned into the setup.
You should spend some time with him talking about adjustments and he should be able to give you some ideas on how to tune it and what adjustments will move the IC to where depending on how the car reacts. I plotted mine all out on cad and used it to figure out what movements will do what. Some guys just do it on a large piece of cardboad and map it all out.
Lastly, a friend video taping your launches if your guy can't get to the track with you will help him be able to tune it in also.
Good luck.
Redl98, let me know when you want to send your piece....my car is snowed in my garage and the other one is consuming all my jackstands so I can't take any photos of mine yet. If you want to make the necessary messages and send me the piece I will TIG it up for you. Let me know...I know you were busy with finals etc....so keep me posted.
Old Dec 12, 2007 | 10:13 AM
  #92
DVNCI's Avatar
DVNCI
Yeah I know he uses some type of software for calculating the IC, but that is about all I know. And I'm pretty sure I can talk him into coming to the track a few times to help me out, I know he has done that with several cars he has built.
And I'm also planning on video taping for him/myself/whoever - if nothing else just to have it.
Or put it in my sig.
Old Dec 12, 2007 | 02:25 PM
  #93
red L98's Avatar
red L98
jesse said it all, nothing wrong with running short ladder bars, its just makes it harder / more time to get the car 100% where you need it than a longer one. im sure with the help of your guy it would be a walk in the park. also with the new ladder bars they have out , you have more room to play with as long as your running somthing like the one in the link ...
http://chassisengineering.com/shopDe...ProductId=1199
Old Dec 21, 2007 | 05:07 PM
  #94
DVNCI's Avatar
DVNCI
Hey guys, just added 3 pics of the rear end being built.
Should have some good roll cage pics by end of next week!
Old Dec 28, 2007 | 07:24 PM
  #95
DVNCI's Avatar
DVNCI
Just added some 4 link bracket pics and some also some pics of the roll cage main hoop!
Old Jan 3, 2008 | 05:58 PM
  #96
red L98's Avatar
red L98
so i see your going with 4 links, what made you do that over ladder bars ?
Old Jan 3, 2008 | 07:24 PM
  #97
AKS Racing's Avatar
AKS Racing
I think the pick-up points (as in bar length) lays preference to 4-link set-up over ladder bars on the C4 and C5 vettes.
Aaron
To Solid Rear project started! WOOHOO! Pics inside . . . .
Old Jan 3, 2008 | 08:50 PM
  #98
Corvette Chris's Avatar
Corvette Chris
I was actually looking for this thread earlier today.
Looks like its coming along real nicely. That rear end is a work of art.
Old Jan 4, 2008 | 02:06 PM
  #99
j-stingray's Avatar
j-stingray
thats a sweet setup
i`m on the market myself for a solid axle conversion kit to
i stripped my engine ,trans and rear suspension of my 86 vette
im looking at jesse`s setup [ski down it]
but this conversion is also A way to go
jeff.
Old Jan 4, 2008 | 04:43 PM
  #100
DVNCI's Avatar
DVNCI
Why not is probably the better question.
Once we decided we were going with the backhalf it just made more sense to do the 4 link.
