Trying to plan a crossfire experiment
1. Any power guesses for a stock base. Remember, heads, cam, exhaust car. Any extra info youd like for power guesses just ask.
2. I have oxygenated race fuel. (I put it in the 55 for winter storage so I don't have to deal with ethanol in the teapot all winter... I don't want to rebuild that again) should I run it or not bother for the dyno. All I'm thinking is the oxygen will add a little extra and skew the base line so idk. The dyno will most likely be the last time the car is driven for the winter so it'll also sit without ethanol too. Granted this would be the first time I've ever done that to it because it really doesn't matter. Otherwise winterizing is simply rolling up the windows with the top on so dust doesn't get inside and maybe remembering to plug the battery tender in. (Can't open the hood in the garage to disconnect the battery while parked so I can use the tool box and compressor.)
2. Engine Masters just did a test on this shockingly (to me anyways), the oxygenated race gas DID make a meaningful amount more power. 15ish? on a ~500hp engine? I'd have to watch the episode again and can if you want more accurate info....
I just FINALLY fired the kart last night w/the MiniRam. My god that took forever to get buttoned up, but I'm going to try to squeeze that onto the rollers here if I can find a warm dry day.
I think your 270 is high though. The front half is great, the back end is slow. We'll see though.
Now, did the mini ram make it sound different?
No at all, idling and revving. I'll have to get back to you on the driving sound.
I don't want to hijack you thread but though YOU of all people would find this interesting. When I started it, it was as if the ECM "didn't come to work today"....or something. It fired right away with thunder....same as always....then died nearly as fast. Did that 4 or 5 times, then I held the throttle open to help it stay going, which it did, but totally didn't want to. It ran like dog ****, smoked (blue) profusely and fumigated my garage in no time, to where i couldn't breath or see. If I let off the throttle at all, it would die, instantly. I eventually got out of the car and to the throttle w/o it stalling, and noted a few things:
1. IAC was closed.
2. Timing changes made no discernable difference...even radical rotations of the distributor (like 30* at the distributor!!)
3. Stroking the TPS didn't do squat -it usually surges the injectors. Nothing happened.
Fighting w/the throttle to keep it running, I got it warmed up and then let off the throttle, let it die. Shut the key off, checked over things, connections, any leaks? etc....found nothing. Decided to start it again to try to further diagnose it, and RooOOOOM!!.....LA-LA-La-La-la-la-la-la-la-la-la-la-la-la....into a perfect idle...IAC sucking air, TPS working, responsive to timing...
Weird as phuc. As my auto Prof would have said, "Huh. AM/FM....AutoMotive ******' Magic".
1. IAC was closed.
To save the math, the mustang numbers were 249hp 314tq
I think that is quite respectable for a stock base. It would be interesting to measure the vacuum in one of the head ports at 3500 RPM.
I think that 3400 rpm on up will show gains. The average power is impressive and like I said... it front halfs great. Back half is weak.
