View Poll Results: do it
Do it, it's fun
31
72.09%
Do it but I don't think it'll be accurate
1
2.33%
Don't do it, it is a waste of your time
3
6.98%
Save your time and drink
4
9.30%
Just drive it
4
9.30%
Voters: 43. You may not vote on this poll
Trying to plan a crossfire experiment
Old Apr 26, 2022 | 12:44 PM
  #301
84 4+3's Avatar
84 4+3
For those following along at home, it's all good now.
Old Apr 26, 2022 | 12:56 PM
  #302
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
How?
Old Apr 26, 2022 | 02:24 PM
  #303
84 4+3's Avatar
84 4+3
Originally Posted by Tom400CFI
How?
I'm going to be honest, I messed with the acceleration enrichment. So it was going lean when you nailed it then the fueling was catching up causing the burbling... added basically a larger pump shot back (what was in it but should be way too much fuel) and all is good.
I gotta get this thing to a track, may take a quick little video of a quick rip later if I feel alright. Vertigo started acting up.
Old May 1, 2022 | 03:46 PM
  #304
84 4+3's Avatar
84 4+3
Tossed the keys to my friend, he did a 160 mile trip on the highway back home and to me. I asked him how it was. He just nodded and said "how is every gear passing passing gear. And not the car to drive that hungover."
Old May 15, 2022 | 10:32 AM
  #305
84 4+3's Avatar
84 4+3
Since it's running pretty well I may reach out and have it dynoed now, using the same tables and such as it did prior so it's a more fair A/B just with the fueling corrected to what it wants. Then the difference is solely the intake characteristics.
Old May 15, 2022 | 11:00 PM
  #306
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Get it on the rollers! Get it to the track!
Old May 16, 2022 | 08:51 AM
  #307
84 4+3's Avatar
84 4+3
Track is a little difficult with our current staffing issues but the dyno is on my way home.
Old May 23, 2022 | 12:15 PM
  #308
84 4+3's Avatar
84 4+3
So I had some time today for some very unscientific testing. But basically I pulled the best data log from the old intake and compared it to the data log from the current setup which isn't even it's best.
Data says:
13.7s vs 12.7s E.T.
96 vs 109 MPH trap
Now these are all calculated but my throttle tip in was about the same and looking at the data it's an impressive difference between the two from just simple data. Hopefully we get some guys at work and then I'll have a more normal schedule again.
Old May 23, 2022 | 10:17 PM
  #309
cv67's Avatar
cv67
St. Jude Donor '05
Thats one hell of an improvement. 10mph is huge
Old May 24, 2022 | 04:51 AM
  #310
84 4+3's Avatar
84 4+3
what's strange is 0-60 and 1/8th is about the same. To me that indicates it isn't falling on its face higher in the RPM range. Which is good.
Old Jun 29, 2022 | 07:48 AM
  #311
84 4+3's Avatar
84 4+3
I reached out to the shop the other night, they said from the day I'm ready its about 1-2 weeks for dyno availability. All I have to do now is fix the oil leak and all will be well. Hoping by the end of next week I'll have some numbers.
Old Jun 29, 2022 | 03:05 PM
  #312
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Cool! I can't believe that they're that far out. It's weird that we have a plethora of dynos here, but no drag track anymore.
Old Jun 29, 2022 | 06:58 PM
  #313
84 4+3's Avatar
84 4+3
I mean it is and isn't that far out. They do a lot of inhouse dyno tuning hence the sporadic availability. Like i called monday and they told ke they could squeak me in friday afternoon. But its not fixed and im at work lol. Also, the reason it's like that... its one of the only import shops around. It's a nice facility
And yeah. We're down to 1 track I think. Maybe 2 still but no open test and tune during the week... only weekends and I don't want to deal with all the people.
Old Jul 8, 2022 | 01:42 PM
  #314
84 4+3's Avatar
84 4+3
Renegade continues to show its flaws... distributor base machining is off so it also leaks... I added a second gasket, checked pump engagement, measuring about .2000 inch with the second gasket so it should be okay. This is getting annoying.
Old Jul 8, 2022 | 05:37 PM
  #315
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Grrrr.
I feel you. It sounds, frustrating.
Old Jul 8, 2022 | 05:44 PM
  #316
84 4+3's Avatar
84 4+3
Update: sustained 4k rpms yields no smoke show behind the car. Seems good to me.
Old Jul 8, 2022 | 07:50 PM
  #317
GregMartin's Avatar
GregMartin
Hey Paul
Did you mention recently that you up-ed your accelerator enrichment numbers. I’ve had a couple of times recently where I’ve mashed the throttle and it’s had a big cough. (Very embracing). Anyway I think my car may need a bigger pump shot because if you feed it throttle it’s fine. It only happen on a really fast delta if that makes sense. Anyway interested to know where you ended up with this.
I’m also thinking about reactivating my decel cutoff even though I kind of like the obnoxious burble, crackle and pop it has now.
To Trying to plan a crossfire experiment
Old Jul 8, 2022 | 08:18 PM
  #318
84 4+3's Avatar
84 4+3
Originally Posted by GregMartin
Hey Paul
Greg, I get an occasional buck or cough when i get back in it on a gear change sometimes. Otherwise it feels pretty stout... if you'd like i can email you my bin so you can take a look at my current numbers? They are roughly the same as the stock calibration Tom came up with to preload onto the EBL he sells. It needs tweaking i just don't have the time to do all that fine tuning... I don't understand it enough. If it was a carb I'd probably just swap out the pump cam to fix it. Seems like it needs to hit just a little sooner on my shift.
Old Jul 9, 2022 | 07:09 PM
  #319
GregMartin's Avatar
GregMartin
Thanks Paul
that sounds like a plan. I’ll email you my current bin as well. I recently leaned it out down low and fattened it up up high. I did that because I noticed that the INT was maxed out and not really changing fuel delivery in closed loop. It seams to regulate properly now.
Old Jul 9, 2022 | 11:29 PM
  #320
84 4+3's Avatar
84 4+3
Thanks Paul
I'll send it your way in a bit. My tuning was done in open loop so it should be pretty close. I will let you know I have lean cruise (highway) on.
