The shifter cable will probably work alright if you can make a bracket to hold the front part where it is separated. I could not find the OEM bracket anywhere. I was told that it was discontinued by GM. I rigged my own bracket. It is not as sturdy as it needs to be. I have to feel when the tranny goes into R or D. I know where to find them so it is not a big problem for me. It goes into park just fine. I don't need to manually shift to 1, 2, or 3 using the shifter. I have a toggle switch on the console for that. I am using the fast/tci tranny controller on my Z06.Good luck with your swap.
Ok, do even when using one of those you'll still need rpms jumper harness ? That wouldve sucked to find out last minute
yes you still need the harness, they build the harness to plug right in to the computer. ill post a pic of harness shortly.
Originally Posted by baezi z06
If a complete transmission wiring harness from another Auto vette would be used wouldn´t that be enough for the swappe ? and then just reflash the pcm
Baezi
no, see post below
The one on the floor is the safety. Purple and Yellow wire. They'll be going to your tranny safety switch which is physically located on the transmission.
The one on the top of the pedal is for your cruise control which is redundant and also on your brake pedal.
Cool, so i can leave the top one alone and then connect the bottom one to the safety switch on the tranny.
