C5 most annoying feature
Computer Aided Gear Selection (CAGS)
Useless Cup Holder
Gargantuan Antenna on the Z06's
Weak Headlights
BUT that Corsa Indy exhaust does make a pretty cool burble when it is under water while pulling the boat out!!!
not having the ability to override the Tire pressure sensors monitor in earlier models
having to press the reset button every time you start the car gets old .
/jc
Conceptually, why did they build the climate control so when you first touch it nothing happens? The first touch puts the unit into SET mode, and then you can adjust it. That's really dumb.
Finally the radio buttons should be illuminated when their station number is selected. I'm forever pushing button 4 to find out the radio is already on number four.
No problem with torque though!
The AC auto mode is demon posssessed. I DO NOT want AUTO, that is why I have a MN6. I want manual AC. Yes I get it there but it could be easier.
Sorry to disagree with that those of you named the CAGS, but that keeps our cars in the high MPG group and keeps the gas guzzler tax off us. Buy the CAGS eliminator and it is gone.
I guess if I drove it more, it might drive me more...batty.
But here are the things that do tend to make me a little batty:
The column lock fiasco is pitiful. The person responsible for the whole mess should not only be fired, but his or her salary retracted from the time of design inception.
Also, I thought it was just me, but I'm glad to hear that others think the headlights suck. I got my wife a new ('06) Camry and the lights on that thing are fabulous! On bright, it's like daylight ahead. Even my 2000 F-150's lights are better. How could this be? Did Chivvy use left-over bulbs from the last Vega production run?
And while I'm on a rant, having owned a couple old (70s) GM big blocks with "twice-pipes," the LS1 exhaust note, especially combined with the MN6 rattle, is nothing to savor. From the back, instead of a hi-perf car, it sounds like a Caterpillar farm implement. I certainly don't want it louder; to me, the decibels are just fine; just smoother and mellower.
But these things do fade in comparison to its good points....I wouldn't trade mine for anything, even with the pimples and imperfections. I guess they give it personality...
Column Lock - but that's easy to bypass too
No auto up on the windows
Cup holder - but I added another one so that's no longer an issue
Use of a non standard size radio... c'mon GM if you had used a double din it would have been so easy to change out the stock unit for a really nice DVD/Nav double din unit. I sure wish some forum vendor would offer a console modified to accept a double din and that looked OEM.
Wheel hop
The wiper stalk is alloying as hell when youre autoxing.....
I thoght I was the only one to have that problem. Isn't it embarasing?
I am trying to figure a way to either bend it away and/or down a bit or shorten it. I suppose doing that would be a major production. Anybody else bothered by this? Any other options?
