NEW Interior LED Mod Thread
Old Aug 26, 2009 | 04:33 AM
  #481
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Michael posted an excellent DIY in here when he did his PRNDL. I believe he modified his waveguide... Look for strips that have discreet LEDs that can be tilted;
http://superbrightleds.com/light_bars-flexible.html
Top LED Strip, as an example...
You might also get good results with some of the newer multi SMD LED bulbs out now, look for one that focuses alot of light towards the front and sides...
Tim
Old Aug 26, 2009 | 09:43 AM
  #482
mtndv8's Avatar
mtndv8
Default My one real contribution to this thread...
Originally Posted by karateboi87
tstar, it's your fan (me) again!
Alright, I got a question for you...
How does the LED replacement for the automatic transmission indictator work?
As an alternative to single bulb replacement...
http://forums.corvetteforum.com/1568687300-post285.html
Be sure to check the bulb socket thoroughly! Mine was heat stressed and disintegrated in my hands...
Aloha
Old Aug 26, 2009 | 11:06 PM
  #483
karateboi87's Avatar
karateboi87
Aloha
Man that looks tough lol.
I don't really want to go into soldering and splicing. I prefer to avoid any chance of messing up... I'm not as handy as you guys.
If I have time in the winter we'll see about this mod!
Old Aug 31, 2009 | 09:32 AM
  #484
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Here are some fuzzy pics of my blown A/C controller circuit boards. In the first pic, you can see the power board track that fried. Can this be repaired?
In this pic, you can see where I messed up one of the bulbs on the light board. I think this is what caused my power board to short out. Can this be repaired?
Old Aug 31, 2009 | 04:50 PM
  #485
tstar's Avatar
tstar
Yes and yes... I can fix that BUT if another component ( other then the one I suspect) is blown then I probably can't do much for that. If I had a damn schematic for the boards I could...
Anyway, let's get with JW and figure out a fair price....
Tim
Old Aug 31, 2009 | 05:56 PM
  #486
mikex7's Avatar
mikex7
Has anyone ever just replaced their rearview mirror lights? Im thinking about getting some blue ones, but would it look weird with everything else stock?
Old Aug 31, 2009 | 06:05 PM
  #487
tstar's Avatar
tstar
I would do the Footwell and Cargo lights too...
Tim
Old Aug 31, 2009 | 06:10 PM
  #488
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Very weird!
We have options for your footwell and cargo areas.
Cheap and good lighting (both)- http://www.shop.jwmotoring.com/produ...0&categoryId=4
Not as cheap, but better lighting (footwells)- http://www.shop.jwmotoring.com/produ...9&categoryId=4
Old Aug 31, 2009 | 06:19 PM
  #489
mikex7's Avatar
mikex7
Originally Posted by Jhonathan_W
Very weird!
your site says youre out of stock of the rear view LED's.
Old Aug 31, 2009 | 06:23 PM
  #490
JW Motorsports
Banned Scam/Spammer
Yes I don't carry those anymore. Too many people blowing fuses from sticking screwdrivers in them.
Old Jan 21, 2010 | 05:08 PM
  #491
deadcafe's Avatar
deadcafe
TSTAR, I just pulled the passanger side window switch out and I want to replace the bulbs with the red LED's but they are a direct replacement and I dont see how to get the resistor in there as well, BTW will a 1/4 watt resistor work or do I need the 1/2 watt? Thank you If you have any pics of that job that would be cool. Dave
Old Jan 21, 2010 | 06:33 PM
  #492
tstar's Avatar
tstar
"Direct Replacements" such as the plug and play LEDs with the bases already?? If so those already have LEDs built into them...
Were the called type 74 or NEO Wedge ?????
Tim
PS 1/4 Watts are fine for discreet LEDs...
Old Jan 22, 2010 | 08:30 PM
  #493
deadcafe's Avatar
deadcafe
Tim
I used the quarters and the passenger side came out nice,, sure the light is not overwhelming but honestly when you are driving at night the interior lights can be a freaking killer. I soldered the lights in directly and I am thrilled with it all I plan on doing it all and your thread will be my guidline for the install. Thank you.
Old Jun 26, 2010 | 04:50 AM
  #494
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Some damn useful info and great ideas in this thread!
I ordered a set of about 20 of the ozium premade bulbs and swapped out the trunk release, both doors, and the traction control switch today. Since the ozium bulb housings are too big to properly fit into the stock spaces, I unwound the wiring from the ozium and stock bulbs and swapped the LEDs into the stock housings. All went in with no problems and the rebuilt lights worked like a charm.
The only place that seems to not light up so well is the traction control. Has anyone figured out a way of improving the lighting in that which doesn't involve hacking it apart or soldering lights directly to the board? Reflective materials perhaps?
Also, JW / Tim, I really dig the under-door lighting for when the doors are open, but I'm none too hot on just slapping a strip of LEDs under the door. Have either of you looked into a directed lighting setup that would replace the butt-ugly red reflector that's factory installed with some kind of directed lighting setup? I know I've seen some mods that put a light behind it, but I'd sooner be rid of that thing with some hidden lighting behind a panel.
Old Jun 26, 2010 | 05:07 AM
  #495
tstar's Avatar
tstar
Yeah there's ALOT of info in here, just takes some time decyphering it.... pun intended!
The Traction Plate is a real problem with LEDs... I've found it best to remove the wave guide and insert a 3mm LED into the back of the Traction Button by drilling a hole in the back of it. I think that procedure is in here. Gary came up with a way to solder a LED in with longer leads and having it extended below the PCB and aimed right at the back of the button, this works well for bright LEDs like Blue and White...
You can try to wrap the wave giude with a reflective material like mylar or aluminum foil like in the Radio. I use metal duct tape in the Radio... Do you have Selective Ride?
Tim
Old Jun 26, 2010 | 05:11 AM
  #496
tstar's Avatar
tstar
Oops... Missed one!
No I haven't looked at replacing the reflector, that would take some fabricating! I'm more into adapting what's already there... Now this might be right up Michael's (Mnt8dv, I think) alley though!
Tim
Old Jun 26, 2010 | 05:26 AM
  #497
flaagan's Avatar
flaagan
St. Jude Donor '12
Nope, just the traction control button. It's amazing how indirect the light is behind that thing, especially considering there's two lights (now LEDs) on that board!
Oops... Missed one!
Tim
Yah. I'm temted to pop one of the reflectors off and take a look at the space it occupies, just to see what you could cram in there.
For the existing reflector LED mods and under-door strips, is there a power source within the door that coud light up the 'courtesy light' it would provide, or is it something that's got to go all the way back to the interior?
To NEW Interior LED Mod Thread
Old Jun 26, 2010 | 05:33 AM
  #498
tstar's Avatar
tstar
Yeah it's the narrow beam of the LEDs that make them a challenge in certain applications. This one in particular is VERY frustrating...
Not really, the only power source suitable is in the Door Switch and if you used that the lights would be on whenever you have your parking or headlights on... the footwell lights are the best place for what you're considering and also the outer door handle LEDs if you're so inclined...
Tim
Old Jun 26, 2010 | 05:43 AM
  #499
flaagan's Avatar
flaagan
St. Jude Donor '12
Good to know I wasn't just imagining that being the case.
Tim
Hmm.. that may work in my favor, then. I was really digging the LED strip one of the guys posted up for an alternative to the footwell lighting, could just work off of that.
Seeing as I'm slowly acruing the body parts for my car's external makeover, I'm still toying with the idea of a shaved door handle setup. I'm intrigued by the fender cove lighting idea, but I can't come up with a color that I'd want to do. I'd like to do some kind of custom external lighting on my ride, but nothing's come to mind yet that really sits well with me.
Old Jun 26, 2010 | 10:51 AM
  #500
angman5's Avatar
angman5
Nice info
