Stealth Light Cannons: Development process
Old Dec 6, 2009 | 09:25 PM
  #501
dquagliaroli's Avatar
dquagliaroli
Default give it a try
Originally Posted by TheRadioFlyer
I'd love to do that, unfortionatly I can't get any better prices on the tail and corner lights than you guys can (I'm not a wholesaler) I would consider offering a "modification package" though.
George, put some numbers together and lets discuss.
Old Dec 6, 2009 | 09:30 PM
  #502
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Originally Posted by Castrellon
Would black plastic shrouds not work because they would heat up and crack too?
I'm sure they might work, but it would be difficult to keep the perfectly round shape with plastic with material that thin.
Old Dec 6, 2009 | 09:34 PM
  #503
M3MOTORSPORTS's Avatar
M3MOTORSPORTS
2018 C2 of Year Finalist
15lbs includes the frame that supports the light assemblies et all?
yup
Old Dec 7, 2009 | 07:56 AM
  #504
Castrellon's Avatar
Castrellon
Don't like the words sure and might being in the same sentence. Guess I'll take the penalty of a few ounces and go with the Al.
Dang, M3MOTORSPORTS, I was hoping for more. Maybe with now I can run an 11.970 instead of a .973. Either way, it'll be great to be able to see past the traps. I have the funky Canadian spec with light sentinel that I can't turn off. I've been disconnecting the motor fuse, but that doesn't really help past the traps where there's no track lights or the return road.
Old Dec 8, 2009 | 08:45 PM
  #505
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The aluminum shrouds are in route as the final piece for the first sets.
General Question: how many of you plan to paint the main shroud, lens and/or the aluminum projector shroud?
Old Dec 8, 2009 | 09:31 PM
  #506
Quik Z06's Avatar
0Quik Z06
Former Vendor
I will most likely paint everything (depending on what it looks like) Are the shrouds going to be bare aluminum or are they going to be black?
Old Dec 8, 2009 | 09:36 PM
  #507
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I plan to leave them bare in case the customer wants to paint/powdercoat them a different color or even have them chromed or polished.
Old Dec 8, 2009 | 09:45 PM
  #508
Quik Z06's Avatar
0Quik Z06
Former Vendor
Now can the llights and lens be mounted without the shroud? I just want to get them mounted because after Dec I wont have much time to get this done. If I can mount them and the lens I will do that then take the shrouds to be painted, but at least I could already have the lights mounted.
Old Dec 8, 2009 | 10:57 PM
  #509
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
How long are you thinking it should take for an amatuer to install?
Old Dec 8, 2009 | 11:59 PM
  #510
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The main lens cannot be mounted without the shroud. I would advise having the shroud painted before installation.
Installation should take no more than an hour (if you can keep track of your tools better than i can...lol)
tweaking/aiming/adjusting may take a little longer....figuree another 15-30 minutes to get everything lined up.
Old Dec 9, 2009 | 12:06 AM
  #511
doje's Avatar
doje
Wow, I was guessing an all day job. This includes removing the original assemblies and attaching all wiring to the new lights?
Old Dec 9, 2009 | 05:24 AM
  #512
Quik Z06's Avatar
0Quik Z06
Former Vendor
The OEM lights are preety easy to remove once you can get to them. I would say maybe 1hr to remove both if that.
Old Dec 9, 2009 | 08:46 AM
  #513
ssmith512's Avatar
ssmith512
I am definately painting the shroud (to match car body color). Lens will remain clear. What I do with the aluminum projector shroud is dependent on how it all looks, but they will either be painted to match body color, brushed or polished.
Old Dec 9, 2009 | 10:10 AM
  #514
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Yes. I believe you will have to cut thee 2 wires going to the headlight motor since there is no quick disconnect (I suggest removing the motor fuses as well)
Aluminum takes to being painted quite well especially with a good primer and quality paint.
Old Dec 9, 2009 | 11:38 AM
  #515
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
You can pull both headlight assemblies in under 15 minutes, with one of these. Get one of these, people. You can thank me later.
Old Dec 9, 2009 | 01:43 PM
  #516
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Santa? is that you?
Old Dec 9, 2009 | 08:44 PM
  #517
chrisj's Avatar
chrisj
St. Jude Donor '12
I was at the shop this past weekend getting something different installed. I got to see some of the components up close and even touch them when George wasn't looking! You guys are going to be happy!!!!
chris
To Stealth Light Cannons: Development process
Old Dec 9, 2009 | 09:38 PM
  #518
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
chris
So YOU'RE the one responsible for the fingerprints...
....now i have to apologize to the dog
Old Dec 10, 2009 | 06:55 PM
  #519
chrisj's Avatar
chrisj
St. Jude Donor '12
What did you think I was doing when I was roaming around.....
chris
Old Dec 11, 2009 | 06:49 AM
  #520
Quik Z06's Avatar
0Quik Z06
Former Vendor
I have only pulled them out going from under the car, is it possible to get them out without having to get under it?
Any updates on the shrouds George?
