Stealth Light Cannons: Development process
Old Dec 11, 2009 | 06:53 AM
  #521
Quik Z06's Avatar
0Quik Z06
Former Vendor
Originally Posted by TheRadioFlyer
Yes. I believe you will have to cut thee 2 wires going to the headlight motor since there is no quick disconnect (I suggest removing the motor fuses as well)
Aluminum takes to being painted quite well especially with a good primer and quality paint.
What wire are you talking about, as far as cutting? When I installed Depo's on my FRC, I remember removing a small harness for the motors etc, I didn't have to cut anything, there was a quick disconnect on them
Old Dec 11, 2009 | 09:02 AM
  #522
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Originally Posted by Quik Z06
I have only pulled them out going from under the car, is it possible to get them out without having to get under it?
Any updates on the shrouds George?
Yes you can go in fron the top....in fact it's essential that you do. The Aluminum shrouds (we'll call them bezels to keeep from confusion) should arrive today.
Old Dec 11, 2009 | 09:13 AM
  #523
Quik Z06's Avatar
0Quik Z06
Former Vendor
Lol, so I've been doing it the hard way the whole time
Lol, im already confused on the whole bezel/shroud thing
so can't wait for pix
Old Dec 11, 2009 | 09:56 AM
  #524
dquagliaroli's Avatar
dquagliaroli
Default To Paint or not??
The aluminum shrouds are in route as the final piece for the first sets.
General Question: how many of you plan to paint the main shroud, lens and/or the aluminum projector shroud?
At this point I am not sure what if anything will be painted. Need to see the final product and how it looks on the car. I want them to look like they came with the car not an add on.
Old Dec 11, 2009 | 01:55 PM
  #525
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
bezels arrived 5 minutes ago. The final "base" version will be installed on my car tomorrow (I have a lovely sinus cold that's not very condusive to particulate Aluminum, ABS and PETG shavings)
The good news: the prototype lights have been on my car now for over 2 weeks in everything from 90+ degree days to snow and rain. An initial concern from one of the meembers was concerning condensation buildup. I noticed that evern when the windows fogged up like mad, the headlights were still clear because of the magnitude of ventilation allowed in the design.
The final design incorperates a LOT of adjustment options to fit just about any car (including those that have had body work done)
Since none of the cars in my inventory have OEM headlights anymore () The install guide will include a mix of previous install guides. I will be showing you how to install the kit on my car. (i will make a video as well which will be made available on youtube for easy access)
Stay tuned for finished pics....and the first SLC GP!!!
Old Dec 11, 2009 | 02:08 PM
  #526
Castrellon's Avatar
Castrellon
You can fly out to to EP for cheap on SWA and do the install on my car. Post up instructions on Youtube.
Old Dec 11, 2009 | 02:47 PM
  #527
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
If you fly me out there I'll install them.
Old Dec 11, 2009 | 06:58 PM
  #528
Quik Z06's Avatar
0Quik Z06
Former Vendor
In for pix
Old Dec 12, 2009 | 06:45 PM
  #529
luckyirishguy's Avatar
luckyirishguy
will u have pics of all the options? halo ring/ half halo, led strip?
Old Dec 12, 2009 | 07:54 PM
  #530
01magnetic01's Avatar
01magnetic01
Been reading this thread off and on for a month and I gotta give you mad props for all the work you've done on these lights. Tho upgrades on my 01 vert aren't in the near future these or the cannons are definitely on my wish list. Keep up the good work.
Old Dec 12, 2009 | 08:10 PM
  #531
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
That's the plan.
Unfortionatly there's been another slight setback, the aluminum shrouds miss the main lens clearance by about 1/4" (see pics below)
The final plan is to have the Aluminum cut at an angle (as pictured) The sunlight will still focus on the same area, but the aluminum will not be affected.
In addition, my hardwaree supplier sent me the wrong size bolts
I will be contacting them to get the proper size shipped out ASAP.
On a brighter note, the heavy mist and fog allowed me to capture some awesome shots of the prototype setup:
Old Dec 12, 2009 | 08:42 PM
  #532
clif's Avatar
clif
St. Jude Donor '09-'10
Awesome pics in the fog!
Old Dec 12, 2009 | 09:05 PM
  #533
ssmith512's Avatar
ssmith512
I apologize, but I am confused by the above bold statement. Are you saying that after you cut the top of the aluminum bezel to clear the lense that the sunlight will still be focused and potentially burn a hole in the shroud, or the sunlight will still be focused but the focal point will hit the inside of the bottom portion of the aluminum bezel? Help me understand, just trying to picture this in my head. TIA!
I like the bezels BTW! I think they will look killer in a nice brushed and clear anodized finish.
Steve
Old Dec 12, 2009 | 09:10 PM
  #534
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Steve
Also, if it's the latter, what happens when the sun hits at a different angle? Would the focus now be beyond the bezel?
If we powdercoat the bezzle, are we going to burn a hole in our powdercoating?
Old Dec 12, 2009 | 09:28 PM
  #535
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
There is only a certain few degrees where the sun will actually refocus the light (it's about a 10 degree span) Above this, the sunlight doesn't hit the lens at all and below this, the incoming light does not focus.
The purpose of the new shroud design is to put the aluminum in the "danger zone" of where the sunlight will focus. Aluminum is renound for it's heat dissapating qualities and is often used in radiators and heatsinks for this reason.
powdercoating will be dependant on the type of powdercoating used. There are some techniques that are used on exhaust headers (that will get WAY hotter than even focused sunlight)
At a customer's request, i will paint the aluminum bezels with high-temp black.
Old Dec 12, 2009 | 10:25 PM
  #536
dquagliaroli
Default Sharp
Love the pictures George. It looks like a C6 at night. Great Job
Old Dec 13, 2009 | 03:43 AM
  #537
Castrellon's Avatar
Castrellon
I'll fly you out if that deducts from the $1275.
To Stealth Light Cannons: Development process
Old Dec 13, 2009 | 05:17 AM
  #538
Quik Z06's Avatar
0Quik Z06
Former Vendor
Couldn't something be done like the DEPO lights, where you have a small aluminum piece beneath the projector to protect the shroud?
Like this...
Please tell me these will arrive before Christmas, lol I hate pressuring you but if I dont get them before then they may have to sit around for a while, at which point I might as well sell them
Old Dec 13, 2009 | 06:42 AM
  #539
dquagliaroli
Default Wow
Based on the above picture I will be installing just as they are. No paint as I feel they are great looking and will look like they were standard equipment.
Old Dec 13, 2009 | 09:33 AM
  #540
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Yes, the aluminum will protect the shroud.
I'm hoping to have these ASAP, but getting them by christmas may be cutting it a little short. This stupid bezel fitmant issue is what's holding everything up. If i thought everyone was going to paint their main lens with an eyebrow, it would solve the problem.
