Stealth Light Cannons: Development process
Old Nov 9, 2009 | 10:43 AM
  #301
Quik Z06's Avatar
0Quik Z06
Former Vendor
George, balance sent through paypal, let me know if you got it
Old Nov 9, 2009 | 07:33 PM
  #302
ssmith512's Avatar
ssmith512
I too have sent the balance payment!
Steve
Old Nov 9, 2009 | 07:58 PM
  #303
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Can someone explain the difference between these two items?...
Originally Posted by TheRadioFlyer
100w halogen high beam upgrade: $40
Toshiba Halogen Infrared Bulb 65w high beam upgrade: $75
I am ready to send final payment but I am not sure which I want since the Toshiba's are a new item with no details.
Old Nov 9, 2009 | 08:13 PM
  #304
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
got it!
HIR bulbs: (requires some modifications to fit the high beam projector)
http://hirheadlights.com/
These are bright little bastards. I use them in my reverse lights.
100w halogen bulbs: these are clear-glass bulbs and have about the same amount of outputt as teh HIR bulbs, but do consumer more wattage to do so.
Old Nov 9, 2009 | 11:09 PM
  #305
doje's Avatar
doje
got it!
Is there an advantage for me to consume less wattage? Unless I am using a big stereo or something and am worried about overloading my alternator?
Old Nov 9, 2009 | 11:23 PM
  #306
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
no huge advantage.
Old Nov 10, 2009 | 03:39 AM
  #307
SCM_Crash's Avatar
SCM_Crash
In the technicality of things, consuming less energy uses less engine power. But if your engine makes 350HP, it's making 260,995 watts of energy. Assuming 100% efficiency from the electrical system, 55 watts is a drop in the bucket.
However, there's one big aesthetic difference with the HID setup which is that with the ballasts, there's no light flickering during normal operation, whereas if you had either your AC or turn signals on, you'd normally see the lights flicker or dim.
Old Nov 10, 2009 | 08:17 AM
  #308
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
If your headlights aree flickering with the turn signal, you may want to look into the big-3 upgrade:
http://forums.corvetteforum.com/audi...ig-3-pics.html
This significantly decreases the strain on your charging system. Think of it as an aftermarket intake/exhaust for your alternator.
Old Nov 11, 2009 | 12:29 AM
  #309
SCM_Crash's Avatar
SCM_Crash
I may do that. I really don't see my lights dim unless I roll my windows up or down. But I've seen it on other C5s.
Old Nov 11, 2009 | 11:04 AM
  #310
VerTigo456's Avatar
VerTigo456
St. Jude Donor '08
got it!
RadioFlyer...been wanting bulbs that will make my reverse much better? What bulbs is it you recommend?
Old Nov 11, 2009 | 05:06 PM
  #311
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
the easiest upgrade would be a 50w halogen. Do a google search for 3057 halogen bulb and you'll find several places that sell it. For maximum output from these bulbs, I suggest installing a relay setup, but it's not essential to see more output.
Old Nov 11, 2009 | 07:05 PM
  #312
SuperTom's Avatar
SuperTom
what type of projectors are used with these headlights
Old Nov 11, 2009 | 07:13 PM
  #313
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Hella 60mm modular projectors. Water-Clear lens and DOT step cutoff.
Old Nov 11, 2009 | 07:29 PM
  #314
Lancejoker's Avatar
Lancejoker
Did I miss pics of the finished product? I can't keep up with this thread
Old Nov 11, 2009 | 07:41 PM
  #315
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
negative. I will start a new thread once i have pics of the finished product. It will also be the official GP thread
est countdown: 8 days till finished product pics.
Old Nov 11, 2009 | 08:47 PM
  #316
luckyirishguy's Avatar
luckyirishguy
cant wait to see this
Old Nov 11, 2009 | 10:10 PM
  #317
Quik Z06's Avatar
0Quik Z06
Former Vendor
Sweet!!!! Can't wait
To Stealth Light Cannons: Development process
Old Nov 11, 2009 | 10:40 PM
  #318
black98c5's Avatar
black98c5
Definitely looking forward to these pics!
Old Nov 14, 2009 | 08:00 AM
  #319
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Good news!!! The thermoformer is ahead of schedule. I will have shroud/lens pics on monday. I plan to mount one of the prototypes on my car for picture purposes.
Since I'm doing teh trimming of both the lens and ABS, I have a good excuse to buy a band saw
Old Nov 14, 2009 | 08:44 AM
  #320
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
Hey George
I love the love of the lights. Since I'm back in Houston from Durango would it be a problem if I came by and took a look at them in person? I'm very interested in getting a set and since on one of the pages back you mentioned looking for a donor vehicle to install them on if you don't already have someone set up for that I'd be happy to do it.
