Corbeau A4 Install (Holy CRAP !!!)
They replaced C6 Z06 seats mounted on C5 rails. The drivers seat was power and weighed 47 lbs. The passengers manual seat weighed 36 lbs.
I think that the heavy part is the Corbeau iron seat rails. It would be nice if they would make an aluminum version or at least use some light weight steel.
If anyone ever needs to mount a fire extinguisher the BK fire extinguisher mount will work with the A4s.
If your looking for a set let me know and I'll get you hooked up with a set
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Originally Posted by DNAST1 View Post
Well I finally got around to installing mine! I have torch red interior and the leather does not come in red , so I had to get cloth. Does not look bad at all IMO! I know I'll probably like it even better come summer time!
Nice,
This past weekend was the first time that I have had the car out since installing the A4s. They replaced the 06 C6 Z06 seats that I had installed in my C5 a while back.
This past weekend I attended an autoX training/practice day on Saturday and ran 2 autoX races on Sunday. There is no comparison between a stock C5/C6 seat and the A4s when it comes to holding you in place under high cornering forces. For the first time ever when running autoX I did not have to brace myself between the console and the door panel.
The seats were also very comfortable on the 40 minute drive to and from the track.
BTW- Great forum! I've been just laying in the weeds the last couple of months soaking up the know how!
Be very very careful when moving seats in/out of car... there are sharp edges everywhere and I did have some scratches... no big deal for me... but for some of you, it may be a big deal. You must install it with the recliner lever towards the center of the car, otherwise, with their bracket offset design, it won't fit with the lever on the outboard location. I needed to modify the bracket to allow the seat to move forward more. I am 5-8, and have 30" inseam... just couldn't get close enough. Contacted Corbeau and their solution was an adapter bracket, which raises the seat 1-1.5" (no thanks!) or weld couple more cross bars to relocate the seat fwd. I went to lowes to get some steel, drilled some holes and bolted the mod. Now my short legs are happy. And I agree, their brackets are "cheaply" made and heavy. The slider is heavy too. They could spend some R&D money there, but then it will cost more. Back to the install, I put couple of washers in the front to raise the seat angle up a bit... it makes the rake better for me. For my extinguisher, the BK brackets still fits, but it limits the fwd seat travel (like before) and now the end of the fire bottle touches the front of the bracket. So I decided to install a "z" shaped bracket, which allow me to install the BK bracket fwd about 1.5". Now, I am happy. One thing though, check the bolt that holds the seat back to the seat bottom. It is covered with a cheap plastic cover. On one of my seat, the bolt was not tightened all the way, and that little bit of protrusion, prevented my seat from dropping in... It is that tight in the C5 cockpit. I bought the black suede and with double lock on the driver side and single lock on the pass side (because of the BK extinguisher bracket). I am fairly happy with this mod. The all black looks nice and my wife thinks there is more room behind the seat... not that it matters... I don't store anything there. The biggest thing is now I have something to hold my shoulders in place and a proper hole for my shoulder harness to fit thru. If I didn't care about looks... I would have left the OEM pass seat in place... BTW, I do not have the BK harness bracket on the pass side... My passengers can use the OEM belts and be flung around ( I usually do not have passengers...they weigh too much LOL)
Ever since I installed my Corbeau A4's (and Corbeau seat brackets) I have been left with an empty spot around the mounting feet....
...I bought carpet from Walmart...I lifted my seats, then cut 8x square pieces of this carpet (6"x6"), then cut a hole in the middle for the bolt to go thru. I was able to slip this carpet square under the existing carpet easily.
You can now barely see where the factory carpet ends and this carpet starts.
Walmart Item # 15524364 (under $9).
Hope this helps someone...
Toque
Guys:
Toque
Did mine, thank you for the great Idea!
Guys:
Toque
Good to hear !
Toque
It took me 5 hours to do a nice neat factory look job, including installing the control module and wire harness to the new seat, adding the "black Walmart carpet" (perfect match!) to cover the space under the seat mounts, adding washers between the front seat tracks and the seat and also under the front seat mounts (lifted the front of the driver's seat as much as I could). The install was easy overall.
- The seats look awesome.
- The leather is much better looking than the factory sport seats and the A4s are also ALL leather - unlike the factory seats.
- While tight (I'm 6' and 215lbs) the seats are comfortable
- No more seat rocking!!! ...even though I thought I had fixed that damn problem last year
- Cornering is now a new kind of fun. I can't wait to hit my first on/off ramp!
Dislikes:
- The seat tracks on both seats are VERY stiff - It's difficult to move the seats back and fourth (unexpected - WTF). It can't be the washers I installed because I only added those to the driver's seat.
- Seat back adjustment access sucks! I should have installed Toque's key chain trick.
- I got the lumbar adjustment and I'm not sure it's holding air - it's like it has a slow leak. I'll need to keep an eye on this as I'm just not totally sure if it's really leaking air.
- Obviously the loss of seat memory and the exit feature, though I knew this going in.
I want to thank Toque as it was this thread and all it's great information that sold me on replacing my seats with the A4s.
After some "seat time" I'll post another update.
-Mike
