Wax ideas
Products that work well, can be cloned and their formulas replicated with a different label. So today, there are products that have different names and manufacturers that use the same molecular formula.
Personally, Ill stick with what I've used for the last 16 years. No one had a product like this 16 years ago, and I'm guessing ones that offer similar properties, somehow came from the blood sweat and tears of a guy working with his DuPont Chemist relative in his garage in North Jersey. Funny how his products wound up in the lab of a giant like Maguire's, and I suspect a few other major manufacturers. So, the bottom line is, there is more than one product out there to do the job... There is no longer, any secret magic.
The reason you need clay has to do with the pollen count in your area, the amount of bug guts your car draws. eg. if you do a lot of highway driving and see bugs splashed on your front fascia, you need to clay them out. Surface contaminants come from many things. Generally speaking, I clay my car at least once a year. Its more therapy than necessity. Clay will never hurt your finish. What clay does compared to a cleaning product is clay does not remove any clear coat, Zero. what it does do is draw out things that have etched into the surface ( it backs them out ). many things that are organic turn to an acid. Pollen and rain can increase the PH of acid rain. a dead bug can decompose on your finish and attach it self to the surface.. those little pin head sized yellow dots that are stuck to your car ( bee poop ) can also turn acidic and etch to your surface. Clay will only draw out the bug and its guts, without removing anything else.
For Me, because I am so ****, I can take the back of my finders and lightly run them across the surface of my car and tell if there is anything attach to it. So to answer your question, only you will know how often its necessary to clay.
Clay is usually needed the most, in the front fascia, the hood, the roof, and the hatch .
Also, Clay can damage the surface if you do not use it correctly, and that is with lots of lube, if you run clay on a dry area hard enough, it will scratch the surface. Clay is an easy thing. you lube up the area and then you just lightly run it around in all directions, back and forth, and circles. these different strokes will catch anything on the surface and remove them. The only way you know the clay is working is you will see contaminants on the clay itself.. ( it changes color... usually black or dark. ) I always Zaino after claying. for me. to clay my car , takes about 30 minutes, and then Zaino is another 30 minutes. Once done, the finish is so slippery, you would think it was all soaped up , although its actually dry. Any other question feel free to ask. There are lots of knowledgeable people here who have beautiful cars, that make my car look like a beater.
Bill aka ET
A few years back I got into machine polishing and the things you can do are fairly amazing. I use both Adam's and Menzerna formulas for paint correction and choose the pad based on the hardness of the clearcoat and what is needed to get the job done. C5s have a ridiculously hard clear coat so sometimes you have to be a little more aggressive with them. Once corrected, it's all about maintaining your paint so that it doesn't get to the point of needing to be aggressively corrected again.
One of the best things anyone can do for the paint is to learn proper washing and drying techniques. When you wash the car, use straight motions, either up and down or side to side. Try your best not to wash in circular motions. This way, if something happens to end up in your wash mitt, you have a better chance of correcting the marks later since straight lines are much easier to correct than circles. Also, use good products. Proper microfiber drying towels (sourced from South Korea, NOT China) go a long way. Thanks to Junkman, they can be found relatively inexpensive from theragcompany.
Just a quick example of what machine polishing can do. My friend stopped by with his G8 last Saturday and asked if I would do a test panel on his car to see what he could expect. He's always kept up with his car and had recently polished, wax and sealed it by hand.
Here is a 50/50 shot of what one pass with Menzerna FG400 and a MF pad did followed by one pass of SF4000 on a foam pad. Obviously, a huge difference in depth and reflectiveness. Now imagine topping this with your favorite sealant and wax
I am not sure what "color correction" is or how it's done, but i'm sure there are threads about it.
Thanks for your help.
Hands down !!...don't know why people say they have problems with it...it's a polymer so you put it on VERY lightly...NOT like you're buttering your bread...easy to take off and what a deep shine with a few coats of Z2 !!...try it...you'll like it !!
There are many cars on this forum that are more than a decade and a half old. Some of them just jump out at you. People tell me all the time that my paint looks wet.. and indeed it should look wet. With 99.9 % optical clarity, my paint looks the same whether its wet from the hose or just toweled off.
My finish has never seen a product that has a disulfide in its formula. After 16 years , my car need no color corrector.
Bill aka ET
If you use products with a bunch of silicone or fillers without paint correction, you are just filling the valleys to level it off and give a perfect appearance. This is fine, but typically only lasts a week or less as the fillers and silicone go away. The only way to actually fix the paint, is to level it first and then use a sealant and/or waxes/glazes to protect it. This, combined with better washing and drying techniques, will keep your paint looking great and give you a "show car" finish.
Got any links for that?
Here are some great tips and a little explanation of what you are trying to accomplish, and what I was trying to explain in my previous post.
For machine correction products I stick with meguiars and for chrome or exhaust polish I go with 0000 steel wool and p21s polishing soap.
I really put their product to the test on my truck, which I'm ashamed to say looked bad (before I started). I Used the product as the instructions said (ie; apply without washing the vehicle first), and I was happy that it does everything that Neil said it will do!
Next I had to try it on my Z and again I was very happy with results.
I know that there a lot of good products out there and I appreciate all of the wonderful ideas, To be honest when Neil made post on this thread, it told me that Neal is a man who believes in his products and who see customers as people who want their vehicles to look great, instead of man you wants you to just buy his product. There is a difference. He provided me with Customer service where I could tell they enjoyed dealing with me instead of you're being a pain attitude, that is too common now days.
Chadwick's rocks!
