my first corvette, my first "build" thread
Old Apr 3, 2020 | 08:08 PM
  #461
2k2wranglerx's Avatar
2k2wranglerx
C5 of Year Finalist (performance mods) 2019
Full send
  #462
2k2wranglerx
Originally Posted by MikeyMcFly
Car looks great.
Keeping your daughters in my thoughts. Hope they're getting through this okay.
Thanks man. They're going a little crazy. We are coming up on a month with no contact other than my wife and i...
My wife and I. Also going a little crazy haha
Old Apr 3, 2020 | 08:37 PM
  #463
MikeyMcFly's Avatar
MikeyMcFly
Both my daughters (2.5 and 6 months) had the flu the week prior everything shutting down. I had 2 days back at work prior to working front home.
I have seen Frozen and Frozen 2 at least 30 times each now. I might be losing my mind.
Old Apr 3, 2020 | 08:52 PM
  #464
2k2wranglerx
In January Penelope and I had a really bad respiratory virus. I lost 7 days of work and it took me over a month to recove . And a cough that lingered longer. Makes you wonder
The biggest challenge in this whole thing right now is getting groceries delivered. Constant instacart orders. Amazon is worthless for this stuff now. Target delivery has been ok.
We bring everything into the garage. Stuff comes out of bags into "dirty" bins. From there it either gets quarantined or cold and frozen foods get sanitized and put into the downstairs fridge for a few day quarantine.
I feel like a crazy person doing it But I have to ya know.
Old Apr 3, 2020 | 09:04 PM
  #465
dskinsler83's Avatar
dskinsler83
Its (COVID-19) been here since January.
Old Apr 3, 2020 | 09:26 PM
  #466
2k2wranglerx
Absolutely could have been.
We tested negative for flu
Old Apr 13, 2020 | 12:15 PM
  #467
2k2wranglerx
Making some progress on quarantine.
ls2 chain and melling oil pump installed, summit harmonic balancer installed and pinned. Used BTR spring compressor and valve seal tool to install dual valve springs with titanium retainers as well as new valve seals.
Painted the valve covers and added some billet coil brackets. I need to shine them up a bit.
next step is to install the linked lifters and heads and measure to make sure my pushrods are the correct length. This will be a first for me so i'm going to take my time. The weather was beautiful the last few days so i did some work around the house instead of working on the vette. hoping to have this stuff wrapped up and installed this weekend and be close to first fire.
Old Apr 13, 2020 | 12:49 PM
  #468
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I recommend the 2005 CTS-V replacement valley cover with the built in PCV valve assembly as a since you are already in there this far.
Old Apr 13, 2020 | 01:41 PM
  #469
2k2wranglerx
wait... tell me more about this. This is the first time anyone's brought this up.
they're not super expensive or anything... what's the purpose and what do i do? lol
https://www.summitracing.com/parts/nal-12577927
Old Apr 13, 2020 | 01:48 PM
  #470
Mr. Black's Avatar
Mr. Black
It basically is suppose to improve the stripping of the oil from the crankcase vapor like a catch can does but it's all internal to the engine. It also eliminates the PCV valve itself. Some people still run a catch can though if so desired.
It really cleans up the top of the engine eliminating a bunch of the factory PCV corvette plumbing.
And the nice thing is if you bought one now and did your new engine later you can just move it to that one as long as its not a DOD block.
It certainly is not mandatory but it popped into my had as I had done it recently and when I saw the picture of your short block the valley cover sticks out like a sore thumb lol.
Old Apr 13, 2020 | 02:02 PM
  #471
2k2wranglerx
I mean... i'm here so i might as well right?
I'll look into what plumbing and stuff i'd need to make that work. Thanks man.
Old Apr 18, 2020 | 07:52 PM
  #472
2k2wranglerx
L
last pic on the stand!
Old Apr 18, 2020 | 07:57 PM
  #473
2k2wranglerx
Taking my clutch measurements for my monster twin disc.
Monster wants me between .0625 and .2000
with the smallest shim the tick kit came with im at .1770. Im pretty sure of that measurement since I've done it 10 times lol.
With the next step up (medium shim) I'm at .0940"
So do I want to be on the tight side or the loose side of spec where I am now.
Both get me within spec.
The pilot bearing fought me. Once i desroyed and yanked the cage and needles out of it i was able to find purchase on the inside of that lip. Problem was that was too far out to pull it all the way out. Needed some 2x4 assistance
i think it took me longer to put this on than any clutch ive ever done. I was so careful lol. This is a lot pricier than the 200 dollar jobs i slam in my miatas haha
bellhousing on and ready for measurements
Old Apr 18, 2020 | 10:37 PM
  #474
dskinsler83
You did change your rear main whike in there right? And put sealer in the crank pulley keyways since your have none? And the LS6 valley cover is what was referred to about and other than having to cut the block its not bad. Easier to hook up the catch can now.
Old Apr 18, 2020 | 10:46 PM
  #475
2k2wranglerx
Man I'm glad you mentioned the keyway... im going to need to seal that. The crank bolt isn't torqued down yet. I was waiting till I got the flywheel on. So I could use the locking tool I have.
I'll have to plug that up before I put the arp bolt in.
Old Apr 18, 2020 | 11:54 PM
  #476
wf847834's Avatar
wf847834
Old Apr 19, 2020 | 06:10 PM
  #477
2k2wranglerx
motor is in but these baffolds wouldn't fit between the rockers. So they're gone now and I have a catch can on the way
To my first corvette, my first "build" thread
Old Apr 19, 2020 | 06:51 PM
  #478
Mr. Black's Avatar
Mr. Black
Clarify a little bit?
Old Apr 19, 2020 | 07:03 PM
  #479
dskinsler83
Thought the LT-1S was just a bolt in no measuring?
Old Apr 19, 2020 | 07:04 PM
  #480
dskinsler83
And what baffles are those from? Center bolt valve covers dont have em
