ebay Header Install
Old Apr 25, 2006 | 02:11 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Not a bad fab job at all. Think it would it be possible to just whack off the front of the stock mid section even with the end of the headers and use band clamps to join them? Under a grand is nice but I want to maximize my $. If I approached a grand I would much rather have some LG Street Series which would go all the way to the rear section, no cutting no welding(although this would not include high flow cats for that price).
Old Apr 25, 2006 | 02:35 PM
User 81424's Avatar
User 81424
Please no links to ebay.
Commercial posting
Supporting vendors pay for the considerable bandwidth charges on the Forum, making it free for the rest of us. In exchange, they get the privilege of using the Forum to market and promote their goods and services.
Forum members are welcome to sell a Corvette or Corvette parts they purchased for their own personal use. Anything else is considered to be a commercial sale. No links to eBay sales, please. If the sale is appropriate for the Forum, post it on the Forum, rather than linking to it elsewhere.
Members are not prohibited from mentioning it when they have a good (or bad, for that matter) experience with a non-supporting vendor. But such mentions cannot be so specific (address, phone number, e-mail address, URL, price, part number, etc.) and so frequent that they become marketing and promotional references.
Only supporting vendors can post Group Purchase threads.
Members can include a mention of their personal businesses in their signatures so long as the enterprise does not compete with an existing supporting vendor, is not Corvette-related and is not so detailed or so frequently appended to their posts that it becomes inappropriate marketing and promotion.
Old Apr 25, 2006 | 02:36 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Originally Posted by N0TDADYS_98
So you woudln't be worrried about the pipping it's self cracking but more the welds?
I noticed people talkinga bout rust... is there things one can do to protect the headers to keep them from rusting without sacrificing performance? IE high tempature paint?
The weld area is normally the high stress point. Even thought it's called Stainless it will discolor from high exhaust temps. You can have the Jet-Hot coating applied that will keep the finish and reduce underhood temps.
Old Apr 25, 2006 | 05:50 PM
98vert6spd's Avatar
98vert6spd
where were the o2 bungs at originally?
Old Apr 25, 2006 | 06:45 PM
Black 79's Avatar
Black 79
From the pics it looks like these headers have some nice welds.
David.
Old Apr 25, 2006 | 07:10 PM
sxeC7's Avatar
sxeC7
Not that simple to just cut off the stock mid-pipes. If you do away with the cats you'll need reducer/transition pipes to get from the 3" headers to the 2.5" mid-pipes.
Old Apr 25, 2006 | 07:14 PM
sxeC7's Avatar
sxeC7
The bungs were in a the right area they should have been rotated about 15 degrees for the sensors to clear structure.
Old Apr 25, 2006 | 11:55 PM
N0TDADYS_98's Avatar
N0TDADYS_98
i have stock piping all the way back ot my corsa's.. what other materials were required to finish the install? and price?
Old Apr 26, 2006 | 12:24 AM
SLPRC5's Avatar
SLPRC5
I bought a set of shorties for my '97 from e-bay. Pace Setters is the name of the company out of AZ. I had mine ceramic coated. I paid less than $400.00 for them and they fit nicely and sound good with my Hi-Flo cats, X-pipe and ZO6 Ti exhaust. The ceramic coating is holding up nicely..
Old Apr 26, 2006 | 01:19 AM
htvette's Avatar
htvette
Is it possible to rotate the O2 bungs (DIY install) so no cutting/welding is required?
Old Apr 26, 2006 | 01:42 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Can't wait to get my headers
Old Apr 26, 2006 | 09:43 AM
cruisemon's Avatar
cruisemon
Default header outlet diameter
Can someone who has bought these tell me what the outlet diameter is and whether the headers will mate with factory exhaust? Also, is a band type compression clamp used to hold the header/cat together or what?
Charlie
Old Apr 26, 2006 | 09:53 AM
  #33
sxeC7's Avatar
sxeC7
Nope, the bungs are welded in place and have to be plugged with a threaded plug and the headers have to be re-drilled and new bungs welded in. You might be able to use the existing locations, if you installed the sensors before you bolted the headers to the engine, but you couldn't replace them without unbolting the headers.
Old Apr 26, 2006 | 11:41 AM
  #34
htvette's Avatar
htvette
I am planning on not using cats. Would plugging the existing O2 bungs and using O2 sims work? Thanks
Old Apr 26, 2006 | 11:42 AM
  #35
NSTG8R's Avatar
NSTG8R
word of advise .. wrap the 02 sensor cable / connectors in heat resistance material.
otherwise .. clean install.
Old Apr 26, 2006 | 12:21 PM
  #36
VetteNoob's Avatar
VetteNoob
You have to have the front O2s functional or you will have driveability problems. You can SIM the rear O2s, but you shouldnt need to looking at these headers as long as you run CATs. If you dont run CATs, you can SIM the rear O2s or have them programmed out when you get the car tuned.
Old Apr 26, 2006 | 03:05 PM
  #37
Mike@NorrisMotorsports's Avatar
0Mike@NorrisMotorsports
Former Vendor
St. Jude Donor '11
Hey All,
We are doing a set of these right now and I can give you my .02 on this product.
From the top everything looks good and a nice fit. High polish and nice TIG welds. Time will tell how they last. Underneath is VERY disappointing to say the least, but these are $300 headers. The height variance from right to left at the collector is about 7/8" with the LS collector being very low.
The brackets at the collector that go to the bell housing are approx 1.00" too far back to bolt up and agin the LS bracket is about 7/8" lower then the RS. Very sad.
The LS oxygen sensor contacts the bell housing as mentioned here. I see that RPM did a quick fix by locating the sensor at what apprears to be where the bell housing brackets use to be. I personally would prefer the proper top location but they probably did not want to remove the LS header for the sensor relocate.
Again, it is very sad quality as far as fit, but they are $300 and not much more should be expected. Our customer will end up with approx $1200 into these headers to make them proper and that is with off road pipes. I guess we could do it cheaper by moving the oxygen sensor location to what RPM has and use aluminized steel for the pipes, but we prefer to stick with stainless and TIG welding as well as a proper fit. We will most likely also cut and re-weld the LS collector for proper height.
Hopefully down the road these cheap imitations of TPIS and JetHot will not fall apart. Hope this info helps some folks.
Mike Norris
To ebay Header Install
Old Apr 26, 2006 | 04:10 PM
  #38
sxeC7's Avatar
sxeC7
Originally Posted by Vette Doc
Hey All,
Mike Norris
Interesting that the one side was that low, because we all were happy to see how well mine aligned. Could have used the existing rear bellhousing mounting bracket by turning it 180, but decided that the bungs were more important than the mounting tabs which would probably crack anyway and as you said, we didn't want to drop the headers again.
Old Apr 26, 2006 | 06:15 PM
  #39
98vert6spd's Avatar
98vert6spd
im very interested to see more about this. Not often oes a product that costs way way less than comparable products actually deliver. I am thinking about getting a set because the set i bought a year ago are not stainless and i really want the stainless look
Old Apr 26, 2006 | 06:58 PM
  #40
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Hey All,
Mike Norris
I guess you get what you pay for 99% of the time
