Code C1214?
Old May 22, 2011 | 12:40 AM
  #61
2001z06papa's Avatar
2001z06papa
3rd Gear
Originally Posted by tstar
Hey guys... The first thing to try is cleaning the grounds and contacts on the EBCM. I have a write-up on the procedure w/pics. PM me with your EMail address if you want it.
If cleaning the contacts and grounds doesn't resolve your problem, the next best thing is to have your EBCM re-built. Here's a cut and paste of vendors that have been used successfully in the past;
1. well just wanted to let everyone with this problem know found a place to get this thing repaired and after talkin with Brandon got him to repair and upgrade it for 150.00 plus 8.00 for return next day air .
this is a great price if ya look at cost to replace and customer service was also great. he will gurantee the ecbm for as long as you own the car.So if ya have this problem give him a call , site is absfixer.com or call 877-648-7530 let him know ya heard about him on the form.
2. The name of the company is Auto&Truck Electronics. I am in no way affiliated with them, nor do I recieve any discount or monetary consideration for making this post. I'm making this post in an effort to save you guys some $$$ and hopefully help to prevent future failures given the problematic part could fail again if replaced with another flawed design part(assuming they haven't corrected whatever tends to break). I was a bit leary of this whole deal since I didn't have any references to say it was a good deal, or they did good work etc...
So if anything use me as sort of a guinnea pig in this matter. I had a GREAT experience both with the service of the rep and of the part they fixed for me. In my opinion it's $$ well spent to both save alot of $$$, but also, from what I'm lead to believe, have a much smaller chance of having the part break again. They have a 5yr warranty on their work as well. Their # is 1-800-550-0674
3. I had to have my EBCM re-built 4 months ago. Put it back in the car and no more codes. The company I used is on ebay, but I contacted them directly at http://autoecu.com/ Their phone # is at the bottom of the web page.
Hope this helps you guys out!
please send info and pics on cleaning this unit great help I have a 2001 z06 thanks! leroycampos@yahoo.com
Old May 22, 2011 | 10:24 AM
  #62
Jumper11's Avatar
Jumper11
Tried the website but it doesn't exist. Do you have the link correct?
Old May 23, 2011 | 03:43 PM
  #63
2001z06papa
3rd Gear
Please send me info on procedure and pics on cleaning and replacing this unit thanks.
Old May 30, 2011 | 11:46 AM
  #64
904pizza's Avatar
904pizza
Can I sign up for the pics/info email too! justinsherman17@gmail.com
Old May 30, 2011 | 12:10 PM
  #65
02koolC5's Avatar
02koolC5
Originally Posted by trussme
Chris.... The procedure for replacing the EBCM is very simple. The only special tool you need is a T-20 torx screw driver. A flathead screwdriver may also be needed to pry apart the EBCM from the BPMV
1 - make sure the car is off.
2 - you will probably need to remove the airbridge to get to the EBCM.
3 - remove the wire harness by first removing the white plastic clip that locks it in place (I cut it off and replaced it with a zip-tie), then lift gray handle and pull back on the wire harness. At this point, you will be able to see the second wire connection that is removed by pulling down.
4 - The service manual call for you the remove the 2 insulator nuts that hold the BPMV to the brackets and lift the EBCM/BPMV out of the bracket. I do not think this step is necessary because there is plenty of room while it is still in the bracket and you do not gain much additional clearance since the brake lines restrict the movement.
5 - Remove the 6 T-20 torx screws connecting the EBCM and BPMV - 1 on each corner and 2 on the sides.
6 - Separate the EBCM from the BPMV by gently pulling apart until separated" In this case, I had to use a flathead screw driver to brake the seal. Once it moved a little, the rest was easy. In addition to the rubber seal, each of the 12 holes have a peg in them from the BPMV. Don't go crazy, but be prepared to force them apart.
7 - At this point, all you've got to do is put it all back together. push the new or repaired EBCM onto the BPMV.
8 - Replace the 6 T-20 torx screws
9 - reconnect the wire harness
10 - put the intake back on
An alternative to buying a new one is to have your original rebuilt.
For EBCM repair/replace
Call Brandon
877-648-7530 at ABS FIXER
or: www.absfixer.com
$150. plus UPS....warranted as long as You own it
Old Aug 4, 2011 | 06:58 PM
  #66
dkellerd's Avatar
dkellerd
Just thought I'd add that they do this same rebuild on ebay for $50 instead of $150 at absfixer. The seller gets good reviews from past buyers and also has the lifetime warranty. I'm gonna give the ebay guy a try and save $100. Dang C1214 code...
Old Aug 5, 2011 | 11:21 PM
  #67
02koolC5's Avatar
02koolC5
Or fix like I did with this thread.....just a few bucks. Post #111
http://forums.corvetteforum.com/c5-t...iy-thread.html
Old Aug 24, 2011 | 01:50 PM
  #68
bdog's Avatar
bdog
I seem to have the same problem and code. I will check out the diy. Hopefully it works. Thanks for all the great info!
Old Dec 5, 2012 | 02:24 PM
  #69
HappyOwner's Avatar
HappyOwner
1st Gear
If it is not too much trouble, would you kindly send me the procedures for clearing the grounds and contacts. I have a 50th Anniversary Corvette and I am having the same problem. There was another thread in which there were pictures of the grounds, but I did not get a reply. If you could kindly send me your information to guillmunoz@gmail.com, that would be very much appreciated. Have a good day
Old Jul 11, 2013 | 09:21 PM
  #70
Ohioguy's Avatar
Ohioguy
1st Gear
Default C1214
I had the 1214 intermittent for a couple of weeks and it would reset.
Then it went to a hard code that would not reset. Traction control and ABS lights on dash also.
After much analysis I removed the ABS module and sent it to ABSFIXER.
Brandon received it on Friday, had it repaired and headed back to me on Monday. I installed it tonight, all codes corrected.
Awesome service, I got an email when he received, another when repaired and another when shipped, could not be happier.
Curt
Old Feb 4, 2015 | 05:31 PM
  #71
sargentat44711's Avatar
sargentat44711
Cruising
Default Please tell me more and Thank You Very Much?sargentat44711@yahoo.com2002 Vette.
Old Feb 4, 2015 | 05:33 PM
  #72
sargentat44711
Cruising
I have a code of c1214 and resetting it has worked in the past , but not now? HELP and Thanks
Old Feb 5, 2015 | 03:18 PM
  #73
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
DTC C1214 Solenoid Valve Relay Contact or Coil Circuit Open
Had the same problem about 18 months ago... messed with it again & again.......
So just sent it to absfixer.com (call 877-648-7530) ... Better then new...
But first check your grounds, plug in connectors, and especially the female part of the connectors.. (see Bill Curlee's electrical) on the forum---great info about the female damage's-repairable.... If you do need to send it off you can still drive the vet.. Be kool though...
Old Feb 6, 2015 | 04:15 PM
  #74
3boystoys's Avatar
3boystoys
Really, you need help? How about reading THIS THREAD! Or the dozens like it?
Old Feb 22, 2015 | 12:12 PM
  #75
billjohns33's Avatar
billjohns33
Cruising
Default C1214
All,
Yes I have read the thread...
So I have had the C1214 code, did my research and seemed straight forward to remove and get fixed. This morning I removed the ABS module and this is where it got weird. As soon as I pulled it off there was some fluid, not running just dripping. Surprised me since guys drive w/o this part. I put a clean rag down to catch it and came back a hour later and its soaked!
What is going on? Am I going to have to bleed the brakes or any idea of this is a indicator of something else? Anybody else?
Right now I have that "it just got worse feeling"
Old Feb 22, 2015 | 05:17 PM
  #76
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you remove that EBTCM,,,,,, That cavity MUST be completely DRY! Theres Z E R O access to the hydraulic system with that module remove. Those small poppit valves are sealed to the BPMV body!!
If theres some sort of fluid in there,,, its either something that leaked in from the OUTSIDE due to an improper seal between the EBTCM and the BPMV OR The BPMV has a bad seal on one of the solenoid poppiy valve pintles. Pressurize the brake hydraulics by pressing hard on the brakes and see if you see any brake fluid leaking from the solenoid pintle valves.
Old Feb 22, 2015 | 10:05 PM
  #77
billjohns33
Cruising
Default Yup it's bad
Bill-One of the valves is pierced so the "easy" fix just got more complicated. Removing and installing a new ABS module seems straight forward with the exception of bleeding the system.
I may be in over my head on this one...
Pretty sure it's not going to be a cheap fix. Can I just replace a poppy valve?
Any words on the way forward would be appreciated.
To Code C1214?
Old Feb 23, 2015 | 06:52 PM
  #78
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
No! The entire Brake Pressure Modulator Valve (BPMV) is bad and must be replaced.
You can get a used one from Vettenuts which would save you some cash.
Just install it and bleed it like regular brakes. That will get 90 percent of the air out. Sometimes you can run the rear wheel with the rear on stands and the antilock will cycle.
I fhe brakes are still soft after you bleed them, you will have to get access to a GM Tech 2 and do the bleed procedure.
Old Feb 23, 2015 | 07:44 PM
  #79
billjohns33
Cruising
Default Bpmv
Yes as soon as I saw a drip of fluid I felt the pit in my stomach tighten and I instantly knew something was wrong. Thanks for the info about bleeding the system.
When I put new brake rotors and pads on the car I toyed with the idea of new brake lines but didn't want to crack that seal...now seems like a good time!
I found and bought a BPMV on eBay for $215; still stings but it can always get worse! (I couldn't have said that yesterday)
Old Mar 10, 2015 | 02:31 PM
  #80
sargentat44711
Cruising
Default code 1214
I had airbags inc.? Duluth,Ga 89.00 plus 16.00 S&H returned rebuilt in 4 days! works Great
