Upgraded TPMS
Old Mar 4, 2010 | 04:17 PM
  #41
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Originally Posted by si2956
Mark, there not threaded all the way down, they look like regular valve stems the rims were changed out and where the stem comes out is really tight fit, thanks for the info
Glad I could help.
Old Apr 5, 2010 | 08:53 PM
  #42
joelk's Avatar
joelk
Great Info, but I have a couple questions.
After the conversion, can I still use 97-2000 TPS, if I want to. The reason I ask is because I am currently just replacing my rear tires and would prefer not to demount the front tires to replace the sensors that are still working fine. I assume I will need 2001-2004 TPS in all 4 wheels, but would like to confirm before I order parts.
Is there a similar conversion that would allow the use of C6 parts? I like the C6 5 spokes and may consider buying a set of "take off" wheels and tires with sensors already in them especially if there is a "C6 Conversion" that might offset some costs for me making the conversion.
Old Apr 5, 2010 | 09:20 PM
  #43
Mark C5's Avatar
Mark C5
Once you have replaced the receiver you must use the TPS in all tires and FOB's for that receiver.
There is no conversion kit I am aware of to allow the use of C6 TPMS and FOB in a C5. They operate/interface with the cars computer completely different. I would imagine the cost to come up with such a system would be prohibitive.
Old Apr 5, 2010 | 09:38 PM
  #44
joelk's Avatar
joelk
Thanks for the reply. Thats what I was expecting, but wanted to confirm before proceeding.
Can the TPS be removed/replaced by just breaking the outside bead or does it require dismounting and remounting the tire?
Old Apr 5, 2010 | 10:07 PM
  #45
Mark C5's Avatar
Mark C5
It can be done just by breaking the bead.
Old Jun 1, 2010 | 05:08 PM
  #46
Dave1998's Avatar
Dave1998
Can someone tell me where I can locate the original receiver in my 98?
The upgrade may be the way to !
Dave
Old Jun 1, 2010 | 05:55 PM
  #47
Mark C5's Avatar
Mark C5
Dave
Take a look at the second pic on the first page of this thread.
Old Jun 2, 2010 | 12:53 AM
  #48
TurboBerserker's Avatar
TurboBerserker
Yep. Inside your hatch, above the DS rear tire -- you'll never see it unless you crawl in the hatch area and lay on your back, so just reach up under there and you'll find it -- trust me
Old Jun 3, 2010 | 11:04 PM
  #49
joelk's Avatar
joelk
Anyone know where I can buy a 10312535 - remote control door lock receiver?
Gene advised me that it is currently back ordered with ETA unknown.
Old Jun 8, 2010 | 10:47 PM
  #50
Jetts4u2's Avatar
Jetts4u2
On my 99, the drivers door opens with the key fob, but doesn't lock, it used to sometimes, now not at all. Is this a broken clip on the linkage as I can hear it actuate. But, every once in a while you can hear the door locks open and close while driving.
Old Jun 12, 2010 | 09:44 PM
  #51
DoctorNeon's Avatar
DoctorNeon
2nd Gear
Hello, my remote door lock reciever blew up (a hole in the side) where can I get another one, none of the dealersa have it and chevy has a nation wide back-order on them. part # 10312535
Thank You
Old Jul 22, 2010 | 09:24 PM
  #52
KorbenDallas's Avatar
KorbenDallas
Same situation here. Does anyone know the part # for the 97-00 style receiver? Mine went out.
Old Jul 22, 2010 | 10:28 PM
  #53
joelk's Avatar
joelk
After several attempts to get a 10312535 - remote control door lock receiver from Gene and several other GM Dealers I was able to get one off of Ebay.
A guy was selling the receiver with 2 new 2001-2004 remotes for $150. Not a super deal, but better than waiting forever. Not sure if he has anymore but you might want to do an Ebay search.
I installed mine last weekend and it is working great. I was not able to get the recommended connector, but was able to wire mine up with parts I pirated out of an old aftermarket remote door lock system I had laying around.
Had to hold magnet (dial indicator magnetic base) at each valve stem for over 5 seconds to get horn honk, but the process went very smooth.
It seems the 01-04 remotes have at least twice the range that my 2000 remote did. I was never impressed with the range of the 2000 remote and the 01-04 remote range seems much better, but I have not yet tested it's limits.
I don't know the PN for the 2000 receiver, but I just looked on gmpartshouse.com and their price is over $300 (List price over $400) so you may want to continue search for 01-04 receiver or shop for a used 97-00receiver.
PM me if your interested in buying mine. It was working fine when I removed it.
Old Jul 23, 2010 | 05:24 AM
  #54
Corvette Don's Avatar
Corvette Don
All of you guys that are taking your old 97-00 sensors off, I will buy them.
Old Jul 23, 2010 | 12:19 PM
  #55
joelk's Avatar
joelk
"All of you guys that are taking your old 97-00 sensors off, I will buy them"
How much? I am planning to put mine in the For Sale section, but if the price is right I will save that step.
Old Jul 23, 2010 | 02:00 PM
  #56
Bakersfield's Avatar
Bakersfield
After doing the math, the upgrade kit cost you $294.37. If it were me, I would have spent a third of that and had new batteries installed and been done with it. I guess if I needed new FOBs I would go that way, but not just for cheaper sensors. Just my .02 cents worth.
Old Jul 23, 2010 | 10:32 PM
  #57
joelk's Avatar
joelk
Batteries are a lot less than $100 BUT......
The upgrade is not for everyone, and initially it was not in my plans. I DIY just about everything and I purchased batteries to replace them in my 2000 TPS. When I took the rear tires off to replace them, I pulled the old batteries out of the OEM TPS and soldered the new ones in.
I got the batteries out with the TPS seemingly in good condition and got one of the batteries installed and making good contact. The other one, I was not getting good contact so I tried to resolder. In the process, I damaged the printed circuit board so I think one of my OEM sensors is now junk.
Many others may be better solderers and have a better success rate.
My regret now is that I did not keep running the OEM sensors until they started acting up. Mine at 32K were still working fine and the batteries I took out only had slighly less voltage than the new ones. They may have failed tomorrow, but they may have also lasted several more years.
I have one good 2000 OEM remote, but the other one has a bad battery contact. I really only need one remote but is nice to have a spare. Also figured the other one might fail someday and they are around $100each.
With the potential for $400+ for new 2000 sensors + another $200 or so for remotes, I thought the upgrade was the way to go.
To Upgraded TPMS
Old Jul 28, 2010 | 07:58 PM
  #58
KorbenDallas
To anyone who has upgraded their receiver box to the new 01-04 style, I might be interested in buying your 97-00 style receiver box. It needs to be free of defects, and the wires in a condition that I can resolder them if needed.
Please PM me!!!
EDIT: Found one, thanks!
Old Sep 26, 2010 | 03:09 AM
  #59
linf94112's Avatar
linf94112
Glad I could be of help
I need to give credit to forum member ajg1915 for teaching me about fuse 27!
Just finished the updated receiver mod and I cant believe why I didnt do it sooner, but the post about checking fuse 27 made an endless search to finishing only take 10 minutes to fix!
I guess it gets blown since the wires aren't all connected at the same time when they get soldered on the new receiver or something. I know the fuse was perfectly fine a week ago.
Thanks again!
Old Sep 3, 2011 | 12:13 PM
  #60
niphilli2's Avatar
niphilli2
This is a great thread, can you answer a few questions for me?
My dad has a 98 vert and is planning to buy new wheels that to the best of my knowledge will only accept the newer style TPS. For this reason we are thinking of doing the "upgrade". He is looking at the deep dish style thin spokes. Any advice?
When doing this do you have to replace the key fobs as well?
Is the transmitter in the same place on verts as coupes (behind driver side b-pillar area)?
Any other advice?
THNAKS!
-Nick
