Issues With Disconnecting Battery
Old Dec 16, 2009 | 09:17 PM
Dorslamr's Avatar
Dorslamr
Default Issues With Disconnecting Battery
I have disconnected the battery on my 04 Z06 to do some mods on the car over the winter, are there any known issues with the electrical equipment that I should be aware of? I had to replace a radio on my Monte Carlo once and after having it unlocked at the dealer they told me that if the car lost battery power for any reason the radio would lock again.
Old Dec 16, 2009 | 09:49 PM
vettenuts's Avatar
vettenuts
There shouldn't be, I do it every winter. Did you ever enter the lock code in the radio?
Old Dec 17, 2009 | 03:26 AM
DeeGee's Avatar
DeeGee
If the theftlock is activated your radio will lock. Its easy to unlock using the code. If you dont have a code PM me and I'll look up the info on where to get the code. You may also lose the memory settings. Other than that no dramas.
Old Dec 17, 2009 | 07:03 AM
Dorslamr's Avatar
Dorslamr
Bought the car last year, so I am not sure if a code was ever used. Is that something that would show up right away or over a period of time?
Old Dec 17, 2009 | 09:44 AM
DIXZ's Avatar
DIXZ
If the theft lock is activated there wil be an indicator on the radio itself that says LOC.
This is ll in the owner's manual.
Old Dec 17, 2009 | 09:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Owners manual link!
http://www.corvetteactioncenter.com/...ual-links.html
You will also set some DTCs which will be reported as history. No big deal. You can clear them easily.
Old Dec 17, 2009 | 11:11 PM
c5blkvetteguy's Avatar
c5blkvetteguy
I never had any issues.
Old Dec 18, 2009 | 04:19 PM
PJW001's Avatar
PJW001
I also disconnect my battery every winter..no issues. Only thing that I find needing resetting is the clock. Other than that no issues.
I would also recommend to once every month or so to hook up the battery to a battery tender/charger to maintain & preserve battery life.
This way when you reinstall in spring you have 100% juice to start up.
Old Dec 20, 2009 | 09:41 PM
redman0204's Avatar
redman0204
Default remove battery
i also remove my battery every winter .no problem. i do take it to the auto parts like autozone for a check&charge be fore i reinstall ,
Old Dec 20, 2009 | 10:51 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Make sure that you secure the battery when you put it back in. Mine worked itself loose after a few months, and for a while I thought I had a suspension issue cause every time I turned Right or Left I heard a "knock" sound. I could also "FEEL" the knock when I turned. It was just the battery sliding back and forth.....
Toque
Old Dec 21, 2009 | 12:22 PM
Bowtie_Brigade's Avatar
Bowtie_Brigade
The latest fix for this is a lighter adapter sold at most auto parts retail stores that utilizes a regular 9 volt household type battery. This back feeds the system and maintains your settings. Not sure if it would last an entire winter though......
Old Dec 21, 2009 | 02:50 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That little 9 VDC battery will only last about 30 min before it poops out.
BC
To Issues With Disconnecting Battery
