Lost all communication help!
Old Nov 17, 2011 | 10:30 PM
  #161
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Good job!!
BC
Old Nov 18, 2011 | 03:55 AM
  #162
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Good job Jon!!!!!!!!!
Tim
Old Nov 18, 2011 | 09:04 AM
  #163
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Outstanding!!!
On another note, you can use the 2001 newer RFA box along with the new FOBS/TPMS in your '99
As Bill stated, change the pins or swap the connector(3 pins)
the later TPMS and FOBS are about HALF the cost of the early parts
Your wiring to the RFA really runs down the LHS rocker??
I've owned a 98coupe and 99/00FRC and a bunch of Z06's, they all kick over to the pass side
Old Nov 18, 2011 | 09:13 AM
  #164
Superman09's Avatar
0Superman09
Former Vendor
Originally Posted by SteveDotenMotorsports
Outstanding!!!
Wiring for the RFA crosses over the hump and down the passenger side to the passenger side foot well.
I have the newer RFA but honestly with all the hassle now and finally getting it to work, I never want to touch it again!
Old Nov 18, 2011 | 10:21 AM
  #165
SteveDoten's Avatar
SteveDoten
C'mon bro, Bill Curlee says "Gidder Done"!!!!!!
just wanted you to know the newer gear can be easily swapped once you have the newer 01 box in there
Old Nov 18, 2011 | 10:28 AM
  #166
Superman09's Avatar
0Superman09
Former Vendor
haha, I knowwwwwww! This is the one occasion where I will actually follow the logic of, "If it's not broke, don't fix it!"
The sensors are in my tires and working and everything is flawless. If the sensors ever die then I will do the swap
Old Nov 18, 2011 | 10:58 AM
  #167
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Just figured I'd give everyone a FINAL update!
Car is now working 100% in all categories!
I have 2 working key fobs, and 4 new TPS Sensors in the wheels that I just programmed and took for a drive to show they are working flawlessly
FWIW I used a trick found here also on the forum to learn the TPS sensors using some magnets, thanks everyone!!!!
This is awesome -
I remember when all this started and we also talked on the phone - man I am so happy it is all settled -
Thanks,Matt
Old Nov 18, 2011 | 11:31 AM
  #168
Superman09's Avatar
0Superman09
Former Vendor
Originally Posted by madmatt9471
This is awesome -
Thanks,Matt
Thanks Matt! Wouldn't be fixed without your help! Much appreciated!
Old Jun 16, 2015 | 07:00 PM
  #169
Big Kidd's Avatar
Big Kidd
Hey Guys & Gals,
I know this thread is old, but it actually helped me trouble-shoot a problem I had with my C5 windows.
My windows would intermittently work. Every time I checked the DIC it would say there was "A LOSS OF COMMUNICATION with BCM" for the door modules, seat control module and the HVAC. The rest of the modules worked fine, the car ran fine......just the windows would stop working from time to time.
After reading this post, I decided to check the star connector #2 (see diagram in an earlier post to understand what the star connectors are) to see if I could find any issues with the wiring for the LDCM, RDCM and the SCM. I didn't see any issues. So, I decided to look at star connector #1. When I removed the shorting bar from star connector #1, I noticed one of the pins was bent on the shorting bar. The pin that was bent was the one that connects the serial bus between star connector #1 and star connector #2......which is the purple wire in the harness. The bent pin on the shorting bar was the reason I was losing communication to the BCM.
Sometimes the bent pin would make a connection and sometimes it wouldn't. I straightened the pin and reassembled the star connectors and my problem was solved. I had to reprogram my key fobs and clear the error codes from the DIC. Now the windows work great and there are no more DIC codes.
I want to thank Bill Curlee, Tim (Tstar) and Lucky131969 for helping out my fellow corvette enthusiasts via this forum. If I hadn't come across this thread, I'd still be driving around with intermittently working windows.
Doug
aka Big Kidd
Old Jun 16, 2015 | 07:39 PM
  #170
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Excellent troubleshooting on your part. I am very happy the issue is solved and you are back on the road 100%
Bill
