Installing Fast 90..Need help
Mesa Red
Ill post up vids later
Happily found out My intake seal was not good enough ( the thought was in the back of my mind as a last probability)
So I spent today taking it back apart and cleaning it again.
I bought this really good gasket sealer my dad uses at his shop called "The Right Stuff". Only downside is he said that with this stuff he doubts I'll be able to take the intake back apart.
Something FAST should do?
Make a seal kit for their inside of the intake just like they did for the ports.
Anyway, sealing up tomorrow and then the test run. I think after this Im going to pull the intake off every so often and run a degreaser through it. The amount of oil and crud is rediculous for me just doing test runs.
Ill post a vid up ASAP!
There are supposed to be rubber gaskets between the shells of the FAST. It's not one continuous gasket but a dab of silicone where each piece ends is enough to make a good seal. They can be purchased from any dealer that sells FAST products.
I didnt wanna do "just a dab" cause Its was pulling air through the sides even with it sealed with the last silicone I tried
But all is well, except the harness and my CAI parts not holding together well
P1515 Command vs Actual Throttle Position Performance (PCM Module)
All I do is reset it and my car is back to regular lol
Took it out for a drive just now to get that code # and got on it and the same thing happened. On my way home, going slow because I was scrolling through the DIC, car starts chugging again and wanting to cut off then I find this code ONLY
P1516 Command vs Actual Throttle Position Performance (TAC Module)
OK normally I would just reset it and be fine, this WOULD NOT go away, every time I reset it came back! lol the car would get better then sound like the lopiest loped out car!
I got my new harness from casper than was checked personally by a tech and then shipped to me. What could this mean? Please dont tell me a bad TB, Cause then Id be out 190 cause I doubt the member will take it back
I was thinking the EXACT same thing. Theres suppose to be red rubber gaskets in all those groves inside the manifold. If installed properly, you dont need sealer except in the areas where each segment joins together.BC
The next order of business is those to codes, cause I cant really drive it, and damn is it dangerous when its at idle cause it could stall...That + crossing a highway? = No more me lol
The Symptoms:
This Code comes on ONLY when I get on it and so far ONLY in 2nd gear going into 3rd(the car gets reduced power in 3rd)
Remedy- Quickly go into the DIC and reset the PCM codes- car drives fine..
Code 2
This code is coming on sometimes at idle( when the engine is about 220*) AND When at low idle or "street use"
This renders the car compelety immobilized even if I clear the code!!
Remedy-Shut off car wait a couple minutes ( Doesnt happen during Highway driving)
What could it be???? My only idea is that I bought a bad TB?
Should I start up a thread asking for a nearby member to lend me an TB to pinpoint the issue?
Im sry this hasnt been easy guys, Tech,Lucky,Bill,033Marine Thank you for your guys help seriously. It woulda took me twice as long to get just this far.
I am not so lucky at this point as my pcm is shot and needs to be replaced. Found this out after replacing the O2 sensors needlessly.
Good luck
Good luck
Exactly what issue's did you have?
Im still in the need of a TB, I think Ill post a thread In the regional thread to borrow one, this is such a PITA
Your saying you had the codes 1515 and 1516? What did you do?
Good to hear!! Glad it worked out. I still need to find out if this is a tuning issue or mechanical OR a bad sensor in the TB
Dont spray the headers, lol.
