cam questions
Old Nov 9, 2010 | 01:16 AM
PRE-Z06's Avatar
PRE-Z06
Originally Posted by zeevette
It's not really lift that's the problem, but duration, and lobe separation angle. I'd definately check clearance with that cam.
agreed, you should be fine with that cam and stock heads/gaskets, but it doesn't ever hurt to double check
Old Nov 9, 2010 | 07:36 AM
94-vette's Avatar
94-vette
Originally Posted by Badd LS6
whats up panda haha..
its for the most part a daily driver..go out racing with friends and such often (mostly roll races)..occasionally the track..so far my PB is a 12.2 on street tires..i know i can hit 11s on radials..i wanna go for mid 11s..and of course whoop my dads and uncles c6z06s haha
You want a fast car so bad you cant stand it.Whats the matter?You tired of those boys up in chi-town kicking that @ss! Remember your car isnt tuned,go get it tuned you should pickup 100rwhp!
Old Nov 9, 2010 | 08:00 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
looking at the patrick G custom grind 231/235 .617/.620" 112+4lsa...was just curiouse about the lift being so big..is that gonna cause clearance issues??
you better chech PTV
Old Nov 9, 2010 | 12:01 PM
Badd LS6's Avatar
Badd LS6
dude your a tool..you must be 17..take your forum ***** somewhere else.
Old Nov 9, 2010 | 10:51 PM
94-vette's Avatar
94-vette
Coming form a guy who wants to put gages in his car for decorations!
Old Nov 9, 2010 | 11:11 PM
Badd LS6's Avatar
Badd LS6
yup just like a christmas tree..
Old Nov 10, 2010 | 10:30 AM
AU N EGL's Avatar
AU N EGL
HP and Speed costs money. Lots of it.
Old Nov 14, 2010 | 11:16 AM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
you could also change the LSA to a 113 or a 114 to help your PTV clearance. Ask Patrick what your PTV would be with this cam, a true cam guru should know what fits what when the stock heads are still in place.
I am also considering this cam for my LS2
Old Nov 14, 2010 | 11:17 AM
Neumonic2002
Also, if going with this cam consider matching it with the proper springs!
Old Nov 14, 2010 | 02:43 PM
Bop Bop's Avatar
Bop Bop
If you are running an A-4 Trans and you go with a 228-232, .580+ lift cam, plan on putting in a stall converter to get the drivability back. It's gonna push bad at idle. Example, 30 to 40 mph with out your foot on ther gas. With a 2700-2800 stall it will drive like it did from the factory.
Old Nov 14, 2010 | 02:58 PM
Bop Bop's Avatar
Bop Bop
Help me out. What does PVT stand for?
Thanks......
Old Nov 14, 2010 | 03:18 PM
ZZ06's Avatar
ZZ06
Thanks......
Piston To Valve clearance
Old Nov 14, 2010 | 03:55 PM
  #33
Badd LS6's Avatar
Badd LS6
thanks for all the help and advice guys!!
i plan on goin with patriot gold dual springs
i operate a 6-spd 2004 Z06
Old Nov 14, 2010 | 06:51 PM
  #34
sami85L98's Avatar
sami85L98
That patrick G cam looks great, high lift numbers give little more torque down low, that huge lift has nothing to do with PTV clearance as Zeevette already said. Go for a Patrick G cam.
Old Nov 14, 2010 | 06:57 PM
  #35
sami85L98's Avatar
sami85L98
i got a offer on a patrick G custom cam..231/235 lsl lobes on a 112+4
If you want my cam 228/232, .585/.595, 113 LSA no advance ground in this cam as far as i know, still in box brand new bought from 21stcenturymusclecars.com part of LPE, they even call this cam a Lpe GT18 Cam.
I will switch my cam for this Patrick G Cam i like that cam specs, plus $50. lemme know if you already owened that cam? if not diregard this post.
