0w20?
Old Sep 8, 2011 | 01:39 AM
flynhi's Avatar
flynhi
Default 0w20?
Mobil is marketing a 0W20 full synthetic oil for better mileage.
Any issues in using this in my LS1 in a warm climate?
Old Sep 8, 2011 | 06:45 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
I wouldn't use it in my C5. It is not what the manual calls for. You should be using 5W30.
The 0W20 is designed to go with some of the newer engines that have been tested to use it. Your LS1 hasn't.
Old Sep 8, 2011 | 08:45 AM
AU N EGL's Avatar
AU N EGL
too light. 5-w30
for warmer areas use 10-w30
if your concerned for fuel mileage sell you vette
Old Sep 8, 2011 | 10:10 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless you live in the ARTIC TUNDRA,, stick with the 5/30 or 10/30 oil.
Bill
Old Sep 8, 2011 | 11:48 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I use 0W-20 in my C-5 during the winter......while it's in storage! I like to start the car 2-3 times during the winter to circulate the oil and lube up the seals, etc, , run the A/C in defrost mode for the same reason, and keep the valve springs from sitting in one position for too long. I put the "light" oil in it so it will start circulating faster.
Old Sep 8, 2011 | 11:53 AM
RaW Z06's Avatar
RaW Z06
I would stick with the 5/30 Mobile 1
Old Sep 8, 2011 | 12:28 PM
jrose7004's Avatar
jrose7004
X5 or so!
Old Sep 8, 2011 | 12:49 PM
JDS99's Avatar
JDS99
Make that X6
All of the bearings in your engine require a particular film thickness of lubricant. GM put 5W30, even on the filler cap, for a reason. Unless you feel like using your engine as a test bed for a thinner oil at like temperatures, I would stick with the recommended.
Keep your foot off the floor if you are concerned with fuel mileage...
Old Sep 8, 2011 | 03:08 PM
Jewjenk's Avatar
Jewjenk
WOW!, buy a Vette and worry about the gas mileage?. I'll trade you my other car,,,,,,,,,,,,,,,,,,,,,,,,,,,,,a HUMMER..........
Old Sep 8, 2011 | 03:15 PM
Vettmann17's Avatar
Vettmann17
Old Sep 10, 2011 | 03:10 PM
TEXHAWK0's Avatar
TEXHAWK0
I noticed some of the new Toyota's come with 0W20, but I have a hard time using zero OR 20 weight oil, even in engines that are supposed to be designed for it, in Texas. I changed the oil in my daughter's 4Runner and used 0w30, but I would not use it in an older engine.
I use 10W30 Valvoline Synpower in my Z06.
To 0w20?
