IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Dec 22, 2015 | 11:50 PM
  #1761
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The chassis ground points are MIRROR located. If you find one on the drivers side, there is an identical one on the same place on the passengers side.
There are THREE ground points on the engine. Two on the sides of the block and one on the back of the drivers head.
There are FOUR inside the cabin. At the base of the door A pillar and behind the seat near the seat belt retractor asembly. The ones in the cabin require door sill cover removal and the trim over the seat belt retractor removal.
The ones in the cabin are 9 times out of 10 NOT an issue.
The only C5 that uses chassis ground G-402 are 97 and 98 C5s that have rear mounted EBTCM. All other C5 that stud is not used and has a rubber cap over it.
BC
Old Dec 22, 2015 | 11:58 PM
  #1762
MOTOXAZ's Avatar
MOTOXAZ
As luck would have it mine is a 98 lol.
Old Dec 23, 2015 | 12:07 AM
  #1763
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
In mid 98, GM moved the EBTCM to the front. So,, you could have a front mounted EBTCM. You can easily tell.
If you have a EBTCM and BPMV on the rear of the differential, you will know.
Old Dec 23, 2015 | 12:17 AM
  #1764
MOTOXAZ's Avatar
MOTOXAZ
Gotcha yeah right now the main thing I am trying to get rid of is the feedback I get through the sound system that is rpm related.
Old Dec 23, 2015 | 12:27 AM
  #1765
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your generator outputs DC Voltage. IF,, the rectifers inside are not working properly, thay can pass AC. Use an AC Voltmeter and read the large BATT terminal to chassis ground. You SHOULD read ZERO AC VOLTS. If you read any AC volts, I would take the alternator to a Starter/Alternator rebuild shop and have them rebuild it.
Make sure that you tell them the reason your bringing it.
The correct way to test it would be to use an oscillascope but, most people dont have one. The meter isnt fool proof but, its a good quick test.
NEXT. Use te same meter set to DC Volts. Put the positive lead on the BATT terminal on the back of alternator and the NEG terminal on the POSITIVE battery terminal.
You "SHOULD" read ZERO VOLTS DC. If you read any voltage the connection between the battery POS and the alternator is faulted. Most likely at the solenoid main terminal.
BC
Old Dec 23, 2015 | 05:36 PM
  #1766
MOTOXAZ's Avatar
MOTOXAZ
BC
Where is the large batt terminal to ground chasis?
Old Dec 23, 2015 | 06:35 PM
  #1767
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The LARGE RED wire on the back of the alternator under the black boot. Its connected directly to the battery through the starter solenoid main power stud.
Old Dec 23, 2015 | 07:10 PM
  #1768
MOTOXAZ's Avatar
MOTOXAZ
Ok So I lack a lot of knowledge when it comes to electrical. You wanting me to put the positive lead where the red wire connects on the starter solenoid? I appreciate the patience and help.
Old Dec 23, 2015 | 08:06 PM
  #1769
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
No... The JUNCTION on the solenoid or the FUSE in the wire coming from alternator "COULD" be loose, burnt, corroded ect.
You will become Stretch Armstrong and put the DC Meter RED Lead on the back of the ALTERNATOR BATT Terminal and the other on the POSITIVE terminal on the BATTERY.
Its easier to get a helper.
What you are doing is looking for a VOLTAGE DROP across that circuit, meaning a lously connection. In a PERFECT C5 WORLD,, the reading that you should see is ZERO. Report the reading:
ENGINE OFF
ENGINE RUNNING
Just for grins and to get a better idea how your electrical system is working, read the battery voltage directly on the battery terminals:
ENGINE OFF
ENGINE RUNNING
Bill
Old Dec 23, 2015 | 08:19 PM
  #1770
MOTOXAZ's Avatar
MOTOXAZ
Where do I connect the ac voltmeter?
Old Dec 23, 2015 | 08:26 PM
  #1771
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The POSITIVE Meter lead on the connection on the back of the alternator (BATT TERMINAL) & the NEGATIVE LEAD on any good chassis (bare metal) ground. Clean with a wire brush.
Good ground connection area:
Old Dec 23, 2015 | 08:32 PM
  #1772
MOTOXAZ's Avatar
MOTOXAZ
Ah I gotcha now. Thank you.
Old Dec 23, 2015 | 11:15 PM
  #1773
ArtGle's Avatar
ArtGle
Veteran: Marine Corps
Default Starter, Battery, and Power Cables
Thought I might help out a little here?
Using Bill's original photo of the starter cable studs.
I've added my own starter, which is a 99 Coupe.
Suddenly started having trouble starting the car, intermittently.
Battery was 9 years old, so I replaced it.
Problem 'appeared' to be solved.
Days later same problem... "INTERMITTENT"..
Bought starter, pulled mine.
Battery / Power Cable stud nut on starter wasn't tightened enough and the connection was rusty, and BURNT.
Cleaned up all the cables and the starter and replaced the nut.
Problem solved. Kept my starter and got my refund on the unused new starter.
Old Dec 23, 2015 | 11:22 PM
  #1774
ArtGle's Avatar
ArtGle
Default Circuit
See next picture.
Old Dec 23, 2015 | 11:31 PM
  #1775
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!! Your the man! Mad computer skills!!!!!!!
Old Jan 2, 2016 | 08:35 PM
  #1776
bigbob76's Avatar
bigbob76
Thanks Bill, this is pretty wonderful to have this resource. At the risk of asking a dumb question, what information does the legend to the schematic give me. Example: by the right front headlight (4) G102. Other than knowing the location of a groundpoint does G102 send me to somewhere in the manual for more information? Thanks, Bob
Old Jan 3, 2016 | 08:08 AM
  #1777
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bob
Once,,, I was a C5 NUBEE... My 1998 C5 coupe FAILED electrically shortly out of warranty. I had to ask a lot of forum questions and become ONE with the Service Manual to understand what as defective and how to resolve it.
Heres is a FREE On-Line service manuals. Its excellent: http://www.bbbind.com/free_tsb.html
To use the Service manual effectively, you:
1. You have to figure out how GM References each Volume. Then what is in each section/chapter. Each section is then layer out in a general view and then it gets more detailed.
So, I you wanted to see what G-102 goes to, you would go to SYSTEM (Electrical Distribution), Then SUBSYSTEM (Ground Distribution) Then you just go down through the pages . G-102 is only DOT on the schematic which is part of splice pack SP-100.
SP-100 fingers out to every MODULE & or component that is attached (grounded) to G-102/SP-100.
When you go to a component page for a single part, like the passengers head light motor, that page will reference or point to the motor being grounded to G-102. You will also see the head light motor BOX on the G-102/SP-100 Ground Distro page.
There is a GENERAL section and sometimes that references specific information for making a proper connections, how to read symbols, soldering etc.
Grab one of the three Book/Volumes and page thru each section and see what’s in it and how its layed out. Once you get familiar with what each book contains and what each chapter/section contains, you will be able to see a volume, go to a section and find a component.
It takes a while to get use to them. TRUST ME.
Oh,, once you get the C5 Service manual memorized and figured out, You will purchase a C6 and then have to figure out Those Service manuals ALL OVER AGAIN! They are layed out the same but, how the schematics are drawn/layed out is different than the C5 schematics.
Then you own a Chrysler / Jeep and those are way different.
Bill
To IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Jan 3, 2016 | 09:06 AM
  #1778
bigbob76's Avatar
bigbob76
Yikes, I see what you are saying and it sounds like I may be in for another case of information overload, lol. And yes, I'm hoping in the not too distant future to have a C7 so my journey is just beginning. Thanks very much Bill. Bob
Old Jan 3, 2016 | 09:30 AM
  #1779
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I was seriously overwhelmed using the manuals when I first received them. I had HUNDREDS of yellow stickies sticking out of the manuals referencing something that was important.
I don't have those yellow stickies any more as I am a lot more familiar with how to find what I'm looking for. It will come over time.
Old Jan 6, 2016 | 07:23 PM
  #1780
James2000's Avatar
James2000
There's always a catch to having one of the coolest cars made. I will do my grounds as soon as the freezing weather passes. Thanks for the valuable info!
