Average MPG?
Old Nov 22, 2011 | 07:39 PM
  #41
JoesC5's Avatar
JoesC5
Originally Posted by diamond78
We didn't buy it for the mileage either just wanted to make sure there wasn't something wrong with it and we didn't know it since we're the third owners. Thank you much for all your help!
I'm thinking next spring/summer we will get significantly less than we are getting now!
Plus...gas is different. I run 94 octane ethanol FREE gas that I can purchase locally in Springfield, MO. When I go on a long trip, where I have to purchase the 10% scam stuff, my gas mileage drops ~1.5 MPG.
Dosen't sound like much, but when I say I get 28.5 MPG (running with ethanol free gas) and then say I get 27 MPG(with 10% ethanol which most people have no choice but to purchase) then 27 MPG dosen't sound quite as good, but it's the same car and the same driver, just different gas.
Old Nov 22, 2011 | 07:52 PM
  #42
incabird's Avatar
incabird
I don't use my 2011 base C6 MN6 as a daily driver. It is just a fun car. I have a little over 2600 miles on it and I have been averaging 26 mpg or better hand calculated. We like to drive to central Ohio from northeast Ohio to Holmes and Coshocton counties. There are a number of great roads where you can have fun with the car. Very little traffic with enough twisties to have a great time. We drive 70 mph going down and back on the highway and whatever we can on the backroads going through the gears. Even with the "fun" driving we still have been averaging +/-26 mpg on a 250 to 300 mile trip.
Old Nov 22, 2011 | 08:02 PM
  #43
speedlink's Avatar
speedlink
94 or 91 octane makes no difference. The ethanol free does.
Old Nov 22, 2011 | 08:07 PM
  #44
phileaglesfan's Avatar
phileaglesfan
On the highway cruising at 75-80 mph my 11 GS Vert gets about 24-26. I've seen it get up to 28.
My 08 Coupe got about 27-29 on the highway at the same speed, up to 31 at one time.
Check your alignment. Toe-in will reduce your gas mileage quick.
Old Nov 22, 2011 | 08:32 PM
  #45
JoesC5's Avatar
JoesC5
True in a car that is designed to run on 91 octane or less, but it's also true that I run 94 octane in my Z06. It does make a difference in MY car, that is tuned for 93 octane gas.
Old Nov 22, 2011 | 08:35 PM
  #46
hawkgfr's Avatar
hawkgfr
My new 2012 is averaging a little less than 21...It got 27 on the 180 hwy trip home brand new with 20 miles on her.
Old Nov 22, 2011 | 08:41 PM
  #47
hig4s's Avatar
hig4s
I have seen a couple mentions of folks getting 26 MPG or higher on the highway - I certainly have not been able to accomplish that. We went on a two hour drive, had the cruise set on 78-80 and averaged about 21.4 over and back. Do you have to drive 65 to get the high MPG? (cuz I don't think I could do that!) :o
What does everyone usually average town/highway?
You didn't mention what car, engine or year..
But
I average 24.5mpg over all, do more highway than anything else.
On a flat freeway at 75mph with cruise on I get 26mpg, at 70mph I get 29mpg.
2011 LS3 2LT coupe manual. I never cruise faster than about 75mph.
Old Nov 22, 2011 | 08:55 PM
  #48
JoesC5's Avatar
JoesC5
But
Post #20, he stated he has a 07 with a manual transmission and in a later post he said he has a Z51.
from your avatar I'm assuming you don't have a GS thus at 75 MPH he is turning 230 RPM more then you in 6th gear, that will eat up around 2-3MPG. But he should be seeing a little better gas mileage then he is. Is your mileage hand calculated or by the DIC? My DIC reads about 1-1.5 MPG higher then hand calculated.
Old Nov 22, 2011 | 09:16 PM
  #49
Captain TJ's Avatar
Captain TJ
Default Mileage
'09 A6 Z51 vert, 34,000 miles used to get 21-22 city, 28-29 hwy, but since I put on the Z06 muffs with the mod and M2W, it has really gone down! Wonder why
Old Nov 22, 2011 | 10:42 PM
  #50
hig4s's Avatar
hig4s
You are correct, I have a narrow body. I've calculated it by hand a couple of times and it has always matched the DIC exactly so I just go by the DIC now.
I do drive pretty mellow and when I don't it makes noticeable difference. To the point if I am down to the last 1/4 tank I become even mellower.
But then I had a Jeep Wrangler before and no matter how mellow I drove, the best I could average was 15mpg.
Old Nov 22, 2011 | 10:57 PM
  #51
360Rocket's Avatar
360Rocket
St. Jude Donor '12-'13-'14
2005 A4 vert. My DIC reads 17.4 MPG, no better.
Old Nov 22, 2011 | 11:09 PM
  #52
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
I have a 05 A4 with 3.15 gears and some bold on mods. Around town I usually get approximately 19 miles a gallon.
On long trips from New Jersey to Florida my mileage varies between 26 and 29 miles a gallon depending on how much stuff the wifie makes us load into the car
Prior to the bolt on mods it used to average over 30 mpg on long trips.
Old Nov 22, 2011 | 11:16 PM
  #53
Rocket-J's Avatar
Rocket-J
It would be good if everyone would state the year,model and engine.
It all matters.
On my 94 coupe, 383/430hp, 6sp, I averaged 28 on trips. My best was 33 mpg indicated, at 72 mph. That was the majic number.
On my 2012 GS coupe, stock LS3, 6sp, I average 20.5 mpg. It only has 1000 miles. Best indicated is 23 mpg. I hope it gets better. No big deal if it doesn't.
Old Nov 22, 2011 | 11:23 PM
  #54
Brian2010's Avatar
Brian2010
On the hwy on a long cruise about 28-30 around the city about 18.
Old Nov 23, 2011 | 12:55 AM
  #55
CaryBob's Avatar
CaryBob
My DIC says I've gotten 14.8 lifetime in a mix of suburban and interstate driving.
Old Nov 23, 2011 | 12:46 PM
  #56
cclive's Avatar
cclive
My long term average on the DIC is showing 25.6. I do mostly highway driving.
Old Nov 23, 2011 | 01:10 PM
  #57
FloydSummerOf68's Avatar
FloydSummerOf68
Originally Posted by ROD BROWN
Around town 11- 16 mpg. 19-20 on the freeway.My mileage sucks and I don't drive hard.09 with z51,6 speed.
Originally Posted by sprtplt
Your mileage doesn't suck, you are being honest/accurate.
No, his mileage DOES suck.
19-20 on the freeway?!?!
Something is definitely wrong there.
To Average MPG?
Old Nov 23, 2011 | 02:38 PM
  #58
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
06 Z06 I get around 27 mpg on the highway consistently on trips if I can restrain myself and keep it around 70-75 mph. Not bad for 505 horsies
Old Nov 23, 2011 | 09:31 PM
  #59
Mregor's Avatar
Mregor
I get about 21 in combination driving. Strictly hwy, 28.
Old Nov 23, 2011 | 10:38 PM
  #60
OnPoint's Avatar
OnPoint
The Consigliere
I have no idea what either of my C6s get for mileage. They do well enough to not be an issue.
Unlike the 3 hours this evening I spent cruising around in my recently resto-modded '68 GTO convertible. Filled its tank at the beginning of the cruise, and a very sizeable chunk of it was gone when I pulled into the garage. Holy crap. Cool ride, for sure, but thirsty.
What a great reminder of just how fabulous the C6 cars are for power and fuel mileage.
