C6 Clock/Nav fix...
Old Nov 29, 2019 | 08:05 AM
  #101
marinablu67's Avatar
marinablu67
Originally Posted by Phil F. Wier
I wondered the same as to whether it's a permanent fix or not. I guess I'll just keep the CD in my auto files in case I have to use it again.
Didn't you read my last post before yours? I had my battery replaced several days ago, and the clock worked fine after. It doesn't hurt to keep the disc, but it looks permanent.
Old Nov 29, 2019 | 08:04 PM
  #102
LarryMow's Avatar
LarryMow
Default Thanks Underachieved
I got the clock fix cd today and installed......worked great! Thank you to forum member Underachieved for sending me the cd........as promised, I’m gonna pay it forward.....if anyone is needing the CD, please PM and I will send it to you.....I’m gonna be out of town all next week, so it’ll be the week after before I can mail it out.
I will add, if that after you do the update and have reinstalled you map cd......if you notice the gps box with the red slash thru it is on the screen....simply shut off the car and then start it up again.
Old Nov 30, 2019 | 10:43 PM
  #103
boilerdog's Avatar
boilerdog
8th Gear
that's what I got I removed the map disc to soon you have let it fire up first then insert the disc
Old Dec 1, 2019 | 01:30 PM
  #104
Phil F. Wier's Avatar
Phil F. Wier
No, I didn't see it. I was looking for a post such as yours but I don't recall it being there when I posted. Thanks
Old Dec 4, 2019 | 11:03 AM
  #105
tascar7's Avatar
tascar7
Had to replace the battery last week and lost the clock on splash screen. After 3 attempts at downloading the FILE the CORRECT way it worked like a charm!
Old Dec 4, 2019 | 12:09 PM
  #106
ZR1Gerhardt's Avatar
ZR1Gerhardt
What is a CD/DVD burner? Just joking, but I don't believe I have owned one of those in years.
I think it is time to just plain update the head unit to something with apple play on it. At least for me.
Scott
Old Dec 8, 2019 | 01:10 PM
  #107
ESAFO's Avatar
ESAFO
Ok we have tried 2 different disks with no luck.
I have the RED slash through GPS logo but GPS still works fine still no clock.
Old Dec 8, 2019 | 03:21 PM
  #108
diyguy's Avatar
diyguy
Scott
Don't feel bad. I use WIN XP with diskettes. ;-\
Old Dec 8, 2019 | 04:15 PM
  #109
ESAFO's Avatar
ESAFO
Got it figured out i guess 3rd time was the charm, i'm sure i was doing something wrong because that's the way i do things... LOL
Old Dec 9, 2019 | 06:04 PM
  #110
diyguy's Avatar
diyguy
Finally got it figured out and unzipped to root file, and Win 10 was able to burn to CD... Cautious and a bit skeptical, got the car out in the open. Left car running and followed procedure. When it was done (the Chevy logo on screen), took that CD out, put back map disk and did not see the clock. Pushed the NAV button (no flag on GPS) then source button, and I'll be. FIXED! Only had to adjust for 1 hr DST.
If anyone needs the Fixer disks, PM me.
Old Dec 11, 2019 | 08:15 PM
  #111
msklein's Avatar
msklein
I downloaded the KWI file a couple of times on different CD-R and CD-RW but could not get the radio to start the load from the MAP DVD slot. I have a 2007 C6
Old Dec 11, 2019 | 08:22 PM
  #112
msklein's Avatar
msklein
I could not get the KWI file to load on my 2007 C6. Tried multiple discs both CD-RW and CD-R.
Old Dec 12, 2019 | 07:11 AM
  #113
ESAFO's Avatar
ESAFO
Make sure to follow the steps properly as described earlier.
After downloading original link (extract or unzip) file, then double click that link & KWI will show then download that onto disk & you should be good to go.
Old Dec 12, 2019 | 08:34 AM
  #114
msklein's Avatar
msklein
The fix does work but you need to burn the KWI file onto the CD-R disc not copy it.
Old Dec 12, 2019 | 08:37 AM
  #115
msklein's Avatar
msklein
https://www.corvetteblogger.com/2019...avigation-fix/
Old Dec 12, 2019 | 08:44 AM
  #116
FatsWaller's Avatar
FatsWaller
If all of the CDs that you tried were burned with the same burner, then try using a different burner. Not all burners produce CDs that can be universally read in other systems.
If no joy there, try downloading the file again. Data corruption can and does happen on downloads, ever though it's not 'supposed' to.
And, you are unzipping the download first, right?
Old Dec 19, 2019 | 06:20 PM
  #117
KATNHAT's Avatar
KATNHAT
Default Need the CD
Originally Posted by CSixDude
PM me your address.
Hi... I also need the CD to complete this fix. Can you please send me one? I'm very low-tech on this stuff. Not sure how to do a PM either. I guess that's a personal message?
Thanks a million!
To C6 Clock/Nav fix...
Old Dec 19, 2019 | 07:53 PM
  #118
KATNHAT's Avatar
KATNHAT
Default Need the CD
Hi diyguy...I figured out how to send a PM so I sent one to you with my info. Please PM me.
Old Dec 20, 2019 | 04:07 PM
  #119
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
I replaced the OEM POS nav with a non-nav Kenwood with Apple CarPlay and use Waze or Google Maps for navigation. However, I will subscribe to this thread for the next owner after I reinstall the OEM HU.
Old Dec 20, 2019 | 05:28 PM
  #120
KATNHAT's Avatar
KATNHAT
Default Need the CD
I'm still looking for a copy of the CD. If anyone can help please PM me.
​​​Thanks
