Edelbrock E-Force?
So question for the forum please: I drive 70mph with KB set at 1 and get x miles. I drive 70mph with KB set at 3 and I get much less. Would make sense until the below are considered:
Engine is a gas "pull" system so why do I consume more at same load?
At 70mph the KB should not engage anyway?
Ultimately it is just hard for me to believe that the engine is consuming more because the KB is providing more fuel at the same comparable load? (push gas instead of pulling gas?)
Also since the car runs closed loop it would simply recalibrate the fuel trims if what you said were true (which it isn't).
The BAP's only job is to provide more fuel capacity under boost to prevent a drop in fuel pressure which is what happens when you try to flow more fuel than the stock system can support.
Even if you ran 20V to the pump at idle all that would happen is that it would end up running hotter.
So at a basic level I am concluding that the 1591 obviously implies more gas consumption at any load because of the bigger injectors and associated tuning and not because of the augmented supply via BAP which engages at boost anyway?
If it is so why then more consumption as I turn the BAP wick up at the same load?
Please consider this is not about fuel consumption but on whether I am running richer/poorer fuel mix?
I guess when you say "hotter" you are referring to the pump getting hotter?
If it can't do that it will throw a code.
The reason you observe poorer fuel economy with a supercharger is because your engine now has to run itself, along with all the accessories, PLUS the supercharger. The blower IS bypassed under all vacuum conditions, but it is not by any means a zero restriction piece, it is not frictionless, and it doesn't have zero mass, so it takes some additional horsepower to turn, and as a result it shows some loss of fuel economy.
Larger losses can be accounted for deficiencies in the tune; it is possible that too little timing is being commanded, for example. If the loss is very large that would be my guess. Typically you'd see a 1 - 2MPG drop from the blower, as per Corky Bell, in his book "Supercharged".
My current full time occupation is in fuel and fuel economy research btw
Same here.
