C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Edelbrock E-Force?
Old Mar 11, 2010 | 09:25 PM
  #101
jcase10's Avatar
jcase10
St. Jude Donor '10-'11
they started out with the Ebrock tuner that comes w/ it, but then they dyno tuned it up a notch. They had it higher but was a little lean, so I think their comfortable with 504. did I mention its sleeper quiet...
Old Mar 12, 2010 | 12:11 AM
  #102
bosco 08's Avatar
bosco 08
Originally Posted by jcase10
Lastly, I told him that I am gonna sleep on it tonight and let him know if its a go tomorrow. Seriously on the fence right now.
How much does the shop want for a turnkey install?
Old Mar 26, 2010 | 06:55 PM
  #103
Motorhead-47's Avatar
Motorhead-47
Originally Posted by vertC6
Really doesn't sound that hard at all, I am sure it will be a tight fit but all things considered should just be a couple of hours.
Dropped my driver's side only fuel tank this afternoon solo. Took slightly over an hour after I got the car up on jackstands and tires/wheels off.
Definitely do-able following the directions posted earlier but definitely a ROYAL PITA. Collapsing the crossover tube is tricky.
One mistake I made....gravity is not your friend...do your best to drain the tank completely before you get started...every gallon weighs 7-ish lbs and I had more than two gallons left!
You are only half-way home when you get the tank out. The fuel pump appears to be slightly larger than the hole!...no kidding....SECOND PITA event was getting the fuel pump out of the tank.
Old Mar 27, 2010 | 03:42 PM
  #104
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
It's supposed to rain tomorrow so give me a shout if you're doing anymore wrenching. I'll be home most of the day. Hopefully your kit gets here on time.
PS - Your garage smells like gasoline.
Old Mar 27, 2010 | 04:23 PM
  #105
Motorhead-47
Smells like fun to me....just checked and my 1591 is now in Birmingham. It goes from there to Dothan and I suspect they'll call me Monday afternoon for a Tuesday delivery.
I could use a hand tomorrow slipping the front fascia off. Other than that I've just about disassembled everything else.
Old Mar 29, 2010 | 12:41 PM
  #106
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Old Mar 30, 2010 | 02:45 PM
  #107
Former Vendor
"Out For Delivery"
Old Mar 30, 2010 | 08:55 PM
  #108
Motorhead-47
DELIVERED! Had to chase the semi driver down at an off ramp on the Interstate to get it but it's now in my hands. That's sure one big azz box it came in!..about 30"x36"x24" if anyone cares...shipping invoice said 199lbs!
First step... Fuel pump goes in tomorrow.
Old Mar 30, 2010 | 10:24 PM
  #109
jrhunkler's Avatar
jrhunkler
Old Mar 31, 2010 | 06:41 AM
  #110
wallyj's Avatar
wallyj
Default Fuel pump
Let us know how that fuel pump goes in since it was such a pain coming out. If you can get any pics that would be great.
Old Mar 31, 2010 | 07:49 AM
  #111
Motorhead-47
You bet...will do. Since this thread has gone all over the place I will probably start with a fresh thread. I won't document the standard install info as A&A has already done an excellent job of it in another thread. I'll focus on the little gotchas I've uncovered/observed as I go.
As for the tank and fuel pump, I think once a guy has done one of these it really isn't a big deal...on a MN6 car that is. You need to be able to visualize in your head how the crossover tube connects and things such as that because you'll be working pretty much in the blind. I'll shoot a picture or two of that coupler (tank end) while the car is apart and I'll also have a few comments on R&R'ing the fuel pump from the tank to start off with.
My next challenge will be trying to fit the heat exchanger up in the radiator baffle along with my Z06 oil cooler. Ideally I'd want the sandwich to be s/c cooler, oil cooler, AC condenser and radiator but there are clearance issues going that route so the s/c cooler may have to go behind the oil cooler...less than optimal. Depending on what I see with respect to IATs I may downsize to the 1/3 size Z51 oil cooler which will allow alot more airflow directly to the s/c heat exchanger. I've watched my oil temps closely since installing that Z06 cooler and I think for a car that is 95% street use the Z06 oil cooler is overkill anyhow.
fun...fun....fun!
Old Mar 31, 2010 | 10:34 AM
  #112
jcase10's Avatar
jcase10
I never got a definitive invoice from that shop.
I am in the process of having the install done by someone else, so I would rather not say right now. But I will tell you this .....its on the way
PM me and I'll tell you what the shops ballpark $ was.
Old Apr 1, 2010 | 10:04 PM
  #113
Motorhead-47
A few pics....
The driver's side tank
The lines in the tank
The dreaded crossover tube connector
What the crossover tube connects to
Fuel Sending Unit which has to be swapped to new pump
These are the two sending unit wires that have to be swapped to new connector
Getting the new pump in the tank is a challenge. The even larger challenge for me was getting that crossover tube reconnected...spent an entire morning swapping the pump and finally getting the crossover tube aligned and reconnected...it will definitely try your patience!
Old Apr 2, 2010 | 06:34 AM
  #114
wallyj's Avatar
wallyj
Great info and pics. Looking at the crossover tube I can see that really being fun. Without seeing what it looks like ahead of time I'm not sure how you ever got it.
Old Apr 2, 2010 | 07:13 AM
  #115
Motorhead-47
Here are a couple more shots for those interested.
The pump which extends from the very top of the tank to the floor of it. You have to slip the pump half way in and then fish the two lines inside the tank out so you can connect them to the pump...a CHINESE PUZZLE for sure!
The other side of the crossover tube as seen from where the fuel tank rests..sorry about the focus...hard to get a clean shot up there
I should wrap up the Edelbrock install today. I spent some time yesterday afternoon trying to get both my Z06 oil cooler and s/c heat exchanger both fitted in the radiator plastic "baffle". I was really hoping to stack the s/c heat exchanger forward of the oil cooler but I was unable to come up with a solution that gave me the clearance I needed. The end result is the stack is oil cooler, s/c heat exchanger, a/c condenser and then radiator. I'll shoot a picture or two this morning. Although the oil cooler and s/c heat exchanger don't touch, there isn't much more than about 1" of clearance between them. I'll run with this setup for a while and will consider downsizing to the Z51 oil cooler which is about 1/3 the size of the Z06 oil cooler...same hoses and mounting holes. This would give at least 2/3 of the s/c heat exchanger direct exposure to the cool air. IMHO the Z06 oil cooler is overkill anyhow for a car that spends most of it's time on the streets.
I'm also running a Dewitts radiator so I expect little to no change in engine temps.
Oh and for those that were asking...this head unit is one big porker!....
I wonder how that weight compares to a Maggie?
More to come
Old Apr 2, 2010 | 08:14 AM
  #116
Tally Ho's Avatar
Tally Ho
I'll see you around noon to slap that "porker" on there.
Old Apr 2, 2010 | 02:03 PM
  #117
Former Vendor
To Edelbrock E-Force?
Old Apr 2, 2010 | 02:10 PM
  #118
Tally Ho's Avatar
Tally Ho
The head unit has been installed. For you DYI people this is a two man job. Now it's time to hook up the hoses, fuel delivery, and electronics. More to follow.
Old Apr 2, 2010 | 08:19 PM
  #119
Motorhead-47
A few more photos
Cooler sandwich
Water pump is in
Almost done
Old Apr 3, 2010 | 12:59 AM
  #120
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Wow, thanks a lot for the excellent photos!
