C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Forced Induction engine reliability list
Old Nov 26, 2013 | 02:18 PM
  #61
Le Mans Z06's Avatar
Le Mans Z06
Originally Posted by brewcitygymratt
What a great sticky thread for those people who have gone FI and those on the fence about going FI on their c6. It's especially helpful for those who daily drive their c6. Thanks for starting this thread!
No problem
Old Nov 30, 2013 | 09:05 PM
  #62
Slowsome's Avatar
Slowsome
Stock Bottom End
ECS Novi 2200 | 12psi | 765 | 678 | LS3 | 6k | 12K | No | 93 W/ Meth | M6 | Street Car
ECS Novi 2200 | 12psi | 765 | 678 | LS3 | 17K | 20K | No | 93 W/ Meth | M6 | Street Car
Modified Engine
ECS YSI | 20psi | 973 | 852 | LS3 416 | 12K | 17K | HeadGasket Failure took out the Block| 93 W/ Meth | M6 | Street Car
made 968 in the video, but ended up at 973 at a later date...
Old Dec 11, 2013 | 10:10 PM
  #63
blacklsx's Avatar
blacklsx
- Type of forced induction - ECS Novi 1500
- PSI of boost - 8.5
- RWHP/ RWTQ - 669/629
- What engine? - LS3 dry sump
- Miles on the car at install - 4800
- Miles on the car now - 6200
- If the engine was hurt, what failed? - NA
- Type of fuel - E85
- Transmission - m6 with mgw shifter, Rps triple carbon clutch
- Degrees of timing
- Mod list - restricted ECS Novi 1500. LG 1 7/8s with cattless Xpipe and factory npp.
Ragin Racing dual steal 360 fuel pumps to boost ref. fuel pressure reg., and
and fast 85 lbs injectors, Comp spec blower cam with double springs.
- How do you use your car? - To have fun with.
Old Jan 18, 2014 | 10:15 AM
  #64
Le Mans Z06
Updated!
Old Mar 4, 2014 | 06:50 PM
  #65
ZoLOW's Avatar
ZoLOW
Update, dynoed my car at work a couple of weeks ago and it made 647/565, numbers I had before were given on a dyno sheet when I bought the car
Old Mar 5, 2014 | 05:25 PM
  #66
Le Mans Z06
Done. Any new mods or same mods? If new mods state new mileage please. Thanks.
Old Mar 5, 2014 | 05:48 PM
  #67
ZoLOW's Avatar
ZoLOW
Same mods at a higher elevation to, haha guess just breaking it in previous owner did the mods then never really drove it I think
33.5k miles now
Old Mar 8, 2014 | 01:46 PM
  #68
D&C vette's Avatar
D&C vette
Update: New dyno
[IMG][/IMG]
Old Mar 8, 2014 | 04:07 PM
  #69
Kadorja's Avatar
Kadorja
Hopefully I'll have a new spot on here soon... curious to see if my fuel system was a part of me not making a good deal of HP.
Shop brought in a 5th gen Camaro with similar mods and comparable S/C which put out 720whp.
I'll edit this with my new setup hopefully by next week. (Fingers crossed)
Old Mar 8, 2014 | 04:47 PM
  #70
ATLS2's Avatar
ATLS2
Supercharged (ECS Novi 1500) | 10 lbs | 653 | 578| LS2 18k-22k miles| N/A | 93 + Meth | A6
Use car for street cruising
-ARM 1 7/8 Catted headers
-BB Bullets
-Mild Cam
Old Apr 2, 2014 | 03:21 PM
  #71
Gaskill's Avatar
Gaskill
MP112 supercharger | 8 lbs | 580 | 520 | LS2 62k miles | 91 + meth | A4/3200 stall ( s/c was installed when car was new. I added cam,heads,headers,stall @ 60k )
Old Apr 2, 2014 | 03:33 PM
  #72
Callaway Chris's Avatar
0Callaway Chris
Former Vendor
Originally Posted by Callaway Chris
Callaway Chris | Callaway SC606 Supercharger Package on 2010 GS | 7psig | 606 hp, SAE 553 ft-lb torque | 6.2L LS3 | Callaway SC Pkg. Installed when new | Current mileage = 181,400 | Nothing has failed/broken | 91-93 octane | M6 | 10.8@128 ET, then driven 200 mi home...
Test drive one of your own @ www.callawaycars.com
191,000 miles, now - still going, and going... no issues...
Old May 2, 2014 | 08:57 PM
  #73
PGPierce's Avatar
PGPierce
What was your 1ST thoughts on this Build?
Old May 2, 2014 | 09:59 PM
  #74
383's Avatar
383
Well?
Old May 27, 2014 | 01:41 PM
  #75
VetteNGT500's Avatar
VetteNGT500
Format for post:
- Type of forced induction --------------E-Force
- PSI ----------------------------------6psi
- RWHP/ RWTQ ------------------------ 505 / 464 @3967
- What engine? ------------------------LS3
- Miles on the car at install -------------4K
- Miles on the car now ------------------26K
- If the engine was hurt, what failed?-----NO
- Type of fuel --------------------------91
- Transmission-------------------------- M6
- Degrees of timing---------------------- not positive....
- Mod list----------------------------1.7/8 hdrs, no cats, SLP LM II
- How do you use your car? ------------- Daily Driver
comments/suggestions welcome.
Old Jun 5, 2014 | 05:10 AM
  #76
corvettepower's Avatar
corvettepower
Originally Posted by Detoxx03
08 LS3 stock bottom and heads, supercharged D1SC 9.5 psi 93+meth cam, headers, 764/635 installed at 44,000miles now 64,000miles no issues no failures and feels great.
which pulley size did u go with on ur d1
Old Jun 5, 2014 | 05:16 AM
  #77
corvettepower
Detoxx03 what pulley size did u go with to achieve 9.5psi
To Forced Induction engine reliability list
Old Jul 23, 2014 | 11:22 AM
  #78
Pappa3duck's Avatar
Pappa3duck
5th Gear
What do you guys think of a pro charger? I have an 08 Ls3 Z51 with 36800 miles on it. Should i get the S/C before i get to any milage? its an A6 and bone stock right now. Its is my daily driver right now. Any addvice would be great. I want to make sure I get reliability out of my Vette and not hurt it.
Old Aug 7, 2014 | 09:52 PM
  #79
C U IN REARVEIW's Avatar
C U IN REARVEIW
Originally Posted by realcanuk
LS2 all stock. Installed Eforce at around 15k miles and ran it until about 30k with about 600 rwhp and 12 lbs of boost. No problems at all during that time.
Now LME LS402 short block, WCCH 245 heads, cam, etc. About 3000 miles now at 724 RWHP. No issues to date.
Is the 402 boosted or na? Which setup do you like better?
Old Aug 8, 2014 | 05:06 AM
  #80
realcanuk's Avatar
realcanuk
St. Jude Donor '13
The 402 is running the same eforce. Now at 780rwhp and no problems to date. I like the added power of the new setup and not worrying as much about engine failure.
