Torque Management System - C6
Old Aug 6, 2006 | 09:09 PM
  #481
ronsc1985's Avatar
ronsc1985
Originally Posted by dennis50nj
due you agree that i can heat my tires and get them just as hot without a line lock. if you do than how can using one give me a better 60ft it doesnt you are dreaming. a lot of guys use it just like i said so there is no roll up or back out of the beams and some people preload to get a better launch. some people just cant drive
Did you miss the word consistently? BTW I have a NHRA/IHRA competition license and race on a weekly basis against real racers not dyno queens and test and tune wannabes.
Old Aug 6, 2006 | 10:16 PM
  #482
dennis50nj's Avatar
dennis50nj
guess what i street race and i have a pro license. and i won the Winston championship pro eliminator in 1981 and the heavy eliminator Winston points championship in 1980. and the new egypt mud hop in A and AA and third in open class. in 1986. and my c6 went 11.9xs on stock run flats. and guess what. all the doesnt make me right or you right but i am right you are wrong don't change it to consistency now you said makes 60 ft faster wrong
Old Aug 6, 2006 | 10:20 PM
  #483
dennis50nj's Avatar
dennis50nj
Originally Posted by TMyers
Of course you missed the word speculating. I used that word because I don't know. And of course you know how it all works so please tell us.
if i new i would be rich that's why i paid someone who does. Julio and Dave at cartek
  #484
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Why are we discussing Line lock/roll control. ?????
Cartek had a 1.5 something sixty foot, the 11.5 et is irrelevant. How did he run that quick at sixty time without invoking TM? In my opinion we will never find out.
Because
We are never going to figure out how TM actually works from the tuners & GM is never going to tell. The tuners make money reducing its effects. If someone on this forum feels his car doesn't have TM than so be it. If there are still individuals who need to see for themselves..... then run a data logger while you run the car down the quarter. I am sure you will see timing being pulled, throttle position reduced & etc.
BTW Just for the record
Roll control on an auto saves the converter neck from ballooning causing damage to the front seal & front pump for those of us who insist on power braking instead of flashing the converter.
Old Aug 6, 2006 | 10:24 PM
  #485
dennis50nj's Avatar
dennis50nj
Because
way to go tommyd but that's why they make anti balloon plates
Old Aug 6, 2006 | 10:25 PM
  #486
Tommy D's Avatar
Tommy D
Having a license is great but the rest is not. We are all missing the fact that Cartek ran a very very quick sixty foot when no one else did
Old Aug 7, 2006 | 06:54 AM
  #487
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
the line-loc came into the discussion when it was mentioned as one of the mods. the cartek car had during it's run. i said it would help the 60' but instead of discussing tm we are debating the uses of line-locs..arrgghhh....
Because
would you happen to have some data from a run that shows the tm effect ?
is it possible to get all the data related to the run instead of just info that shows timing and throttle position. if we are able to see what triggers the event, it would help get around it.
i, for one, haven't experienced anything that i would call tm but that doesn't mean it don't exist. if someone has data that shows it's there and we can learn how to drive around it by asking questions and trying to poke holes in a theory, then great. i for one would love to learn how to drive around it, so i never experience it. remember, the truth stands up to examination while incorrect data falls apart.
once we figure it out we will be able to activate it on demand and also drive around it.
Old Aug 7, 2006 | 08:05 AM
  #488
dennis50nj's Avatar
dennis50nj
i have found the best way to drive around it is dont floor it quickly on the start
Old Aug 7, 2006 | 09:28 AM
  #489
jimman's Avatar
jimman
Not sure if this plays into this but when I first got mine it was, I thought, slower than my C5's. It seems to get stronger every day and now with just turning 50 K on the speedo it's alive and well. Mine never bogged or laid down even from the beginning as long as I had the AH off. I will agree that it didn't seem to have the snap the C5's did till around 10K miles. In fact when I picked the car up I had to drive 2500 miles home and the first tank of gas was only 19 mpg. Each tank got a bit better and the last tank pulling into home it was at 25mpg. Now I'm consistantly 29 to 31 highway and holding.
Old Aug 7, 2006 | 11:38 AM
  #490
2kvetmy's Avatar
2kvetmy
same impression i have on my 2006; seems a little less pull on initial take off and gas mileage is in mid 20's, not upper and low 30's; i have 2700 miles as of now
Old Aug 7, 2006 | 12:21 PM
  #491
shurite44's Avatar
shurite44
I read a tech paper on TM. It was a generic setup not vehicle specific, tested on a Ford Taurus. Anyway part of the TM system relied on the position of the accelerator to determine at least part of the calculation.
Sorry guys I have been looking for the web address for a couple days and I can not find my source for this.
I am going to try the gradual acceleration tomorrow night at the track and see what happens. I know this is the technique my cousin always used driving my C5 and he had better 60's than I could muster. I just have a hard time pushing the gas down gradually when I race.
Old Aug 7, 2006 | 12:23 PM
  #492
shurite44's Avatar
shurite44
Dennis in seconds give me an estimate on how long it takes you to push the gas to the floor. I need to do it on a count so I can stay consistent.
Old Aug 7, 2006 | 05:45 PM
  #493
dennis50nj's Avatar
dennis50nj
Gary I push it hard enough about 1/4 to 1/2 like a fast take off at a red light once car is in slight transfer i put it the rest of the way down but not super fast medium speed but steady. but the initial take off 1/4 to 1/2 is fast.1.764 60 ft so the that would have to be less one second. this might sound stupid but practice fast take offs at red lights in the rain or snow. even though the tires hook very well act like they don't.
Old Aug 7, 2006 | 08:50 PM
  #494
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
What is the source for this info? I don't see a reference to what vehicle it is talking about.
Thanks ahead of time.
The copyright indicates Alldata:
Try this link:
http://www.alldata.com/
Zig:
Don't know how much of this applies to manual tranny's. The Alldata link may address this.
The "learning" comment is based solely on me and a friend's driving impression over a period of miles and time. I remember mine was extremely aggressive when I first drove it and seemed to get less and less with time. Now, with over 500 lb-ft rearwheel tq, it's non-existent.
Old Aug 7, 2006 | 10:14 PM
  #495
boosted_z06's Avatar
boosted_z06
Try this link:
Zig:
Alldata loves to stick copyrights and charge for the content but that is a copy/paste right out of GM manual as I posted that content before but was called a liar since I did not hand retype it all in
Old Aug 7, 2006 | 10:16 PM
  #496
shurite44's Avatar
shurite44
Which GM manual? Owner's C6 manual or a service manual for the C6?
Old Aug 7, 2006 | 11:26 PM
  #497
Tommy D's Avatar
Tommy D
I have an auto and there were instances whereas I felt the car was taking a very long time to shift. It seemed like a prolonged shift. I looked at my times slips as Ranger suggested earlier on and I noticed a change similar to what he had said we would see when "TM" kicked in.
I agree I would love to learn how to drive around it and would really like to see for myself what is happening. However, unless someone is willing to "spill the beans" we are going to have to look for it ourselves with a scan tool or data logger.
To Torque Management System - C6
Old Aug 7, 2006 | 11:56 PM
  #498
jimman's Avatar
jimman
Like to see that manual myself?
Old Aug 8, 2006 | 02:25 AM
  #499
SpinMonster's Avatar
SpinMonster
Thought I would check in and see if there is any ground gained by either side after almost 500 posts. Anyone even slightly change their mind about the existence of TM?
  #500
SpinMonster
I had to post again to be number 500
