Torque Management System - C6
Old Sep 13, 2006 | 05:32 PM
  #581
Whiterock1's Avatar
Whiterock1
Originally Posted by shurite44
Just google torque management. You will see a host of articles from different manufaturers. Nearly all new cars use some form of TM in the computer program.
I agree with that--ultimately that's what traction control/assist is, and often PASM/Active Handling, et al. Good advise on Google. I'll check it out.
Old Sep 13, 2006 | 05:39 PM
  #582
LS1LT1's Avatar
LS1LT1
Originally Posted by jimman
So with perfect traction and a 3200lb car starting a 2000rpm's you can go from Zero mph to X mph with no reduction in engine rpm's or parameters.
No, who said that?
So basically you're claiming that what we're calling TM is merely just the normal 'rpm/power drop off' that occurs between shifts (auto or manual) during hard acceleration?
And C5 Z06s with roughly the same power output/weight running quarter miles that are in some cases over 6/10ths quicker, they magically avoided this rpm drop off?
Old Sep 13, 2006 | 05:58 PM
  #583
zippin zee's Avatar
zippin zee
Originally Posted by Whiterock1
I "actually drive a C6" virtually every day, as one sits in my garage. And I have actually driven high performance cars since 1969. I know what it feels like when timing is pulled because of a knock sensor kicking in, and I know what it feels like when revs are dropped prior to an upshift on a slush box. While I can't speak to the autos on C6s, I can say that no timing is pulled on my m-6 2006 Z51 when I run it through the gears. And, maybe it's just me, but dyno runs I've witnessed/participated in didn't granny shift in lower gears getting up to 4th. There would have been documented indications of so called torque management. How do the mags get 4.1 0-60 and 12.5 quarters if the car is such a dog? You can't disprove a negative, so the discussion is pointless. I think the round earth contingent had a limited membership at one timel, too...didn't make it any less correct.
Well I don't drive mine every day but I have had mine to the track and that is where it will raise its ugly head. I put 100's of runs on my 2002 Z28 and the first time I launched my C6 at the track I could tell somthing was wrong, call it abuse mode, torque management, voodoo whatever som- thing is there that reigns the car back and keeps it from 60' like it should. You do not notice it on the street rolling on the throttle. I thought my C6 would fly before I took it to the track. Take your C6 to the track and run some of those 12.50's and report back.
Old Sep 13, 2006 | 06:08 PM
  #584
shurite44's Avatar
shurite44
My understanding is TC is measured at the wheels, comparing front to rear wheel speed to determine if the rears are spinning.
AH uses other type sensors to help maintain directional control but I do not see as they have any TM functions.
TM from what I have read is measured at the engine using the air/fuel/and exhaust sensors. For TM to work you really don't need any input from sensors at the tires or wheel.
TC can reduce power I agree with that, but the reason for the reduction in power is basically the opposite of a TM function.
Old Sep 13, 2006 | 06:11 PM
  #585
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
I "actually drive a C6" virtually every day...
'I think the round earth contingent had a limited membership at one time, too...didn't make it any less correct.
what ? the earth is round ? man i was always told it was flat
Last edited by Zig; Sep 13, 2006 at 06:20 PM. Reason: no edit:" round earth contingent had limited membership.. hah, at one time wasn't the world flat... hahahah" - just thought that was funny.
Old Sep 13, 2006 | 06:32 PM
  #586
Zig's Avatar
Zig
Originally Posted by dennis50nj
:Zig i do remember smokey i seen that episode of legends of nascar a couple of years ago.
dag gone it, wish i saw it.
but what does that have to do with torque management.
i really don't know, i simply proposed the possibility of 'timing beling pulled as the TM feeling and we got off onto Smokey.
I brought in some info (quoted the source and provided the link to additional information) about running too cool and this happens.
and the only cool temp afect on our c6s is you have to reach 167 degrees in a certain time fram within so many cycles or limp mode can happen .and other computer problems.
if the engine does not reach 167 degrees in a specific time frame the system will shut-down, into a limited power mode ?
wow.. what, is this for the folks in alaska ? the car says, hay, it's cold outside, i ain't going out there.
could you elaborate. i understand limp home or reduced power mode. but i don't understand 167 activating it. is that something like running of half-an engine.
Old Sep 13, 2006 | 06:43 PM
  #587
Zig's Avatar
Zig
Originally Posted by HITMAN99
I don't recall anyone saying that the C6 is "such a dog". What I have heard Ranger say is that your Z-51 may be able to produce faster 60' times at the track than his Z06,
I had no idea ... how would that be possible ????? unless.... no that couldn't be it.
my car will beat his then
that is so funny.... that also implies the z51 (and argueably the mn6 f55) will beat the vipers.... hhhmmmm.. nice.....
and that the lower his 60' time is, the slower his 330' time is.
does that mean he's not obtaining constant acceleration thoughout the run ??
This is not theory, it's real world track results from a very experienced drag racer.
TM absolutely, positively does exist, and you can see the HPTuner screens where you can edit it out (at least for some cars).
agreed, i was also under the impression the automatic tansmission car have torque management, that's basically how they work.
What is not clear is exactly what algorithms are used to measure TQ, and exactly how it is managed. It's also not clear how the programming is different between an M-6, an A4, an A6, and a Z06. The A6 apparently has its own computer, and over 100 different tranny control tables.
If you don't believe it exists, then you don't need to worry about it. I have an A6, I believe it does exist, and so does HPTuners. When their new beta software is wrung out by the many dyno tuners out there, I'm sure that more information will come to light. When the non-beta production version of HPTuners comes out, I plan to buy it and use it for tuning. The very first thing I will do is edit out TM, or at least scale it back some. Until then, I will wait patiently.
this has been asked several time but nobody has been willing to provide results for the following.
would you mind letting everyone know what happens when the only the TM limits are raised. No other timing or air/fuel ratios are modified. what happens when the only thing modified is the tm limits ? what happens when the limits are lower by a value of 50 ? etc.
seems like a simple test to me.
Old Sep 13, 2006 | 06:52 PM
  #588
Joe_G's Avatar
Joe_G
St. Jude Donor '08
you are wrong you wont see tm on dyno because you cant accelerate that fast on the dyno
On every dyno run I've seen they don't start sampling until you are in 4th gear (direct). So TM wouldn't kick in. However, there is a dyno run posted here somewhere showing alleged TM at hard vs. soft shift points.
If you don't believe it exists, have it tuned out and then drive your car. Then see if you still think it doesn't exist! My car was night and day.
Can't believe I'm jumping in this fray......
Old Sep 13, 2006 | 07:06 PM
  #589
dennis50nj's Avatar
dennis50nj
i was telling the other guy you dont see it on the dyno. because he said if it exists why hasnt he seen it on the dyno i have said all along it does exist i am one you side joe i think we need to get tm uniforms so we know who the players are
Old Sep 13, 2006 | 07:09 PM
  #590
shurite44's Avatar
shurite44
We will have a big pink TM on our chest and wear a broke differential as a hat.
Old Sep 13, 2006 | 07:14 PM
  #591
dennis50nj's Avatar
dennis50nj
Zig i had this problem car acting like it floated the lifters rocking like dying for fuel engine light on service active handling on the DIC they replaced everything steering sensor 3 times abs module ecm 3 times they even had to get one of the line.still would happen one off the techs said i cant work on that anymore with that 160 stat and fan module i am losing money on diagnostics. then he said it runs to cold then he exsplained how it worked so now i let it warm to 167 havent had the problem since about a year
Old Sep 13, 2006 | 08:46 PM
  #592
Joe_G's Avatar
Joe_G
St. Jude Donor '08
LOL! I'm telling you. have it tuned out and then post. If you can't feel the difference, buy a minivan.
  #593
Brett Hunter's Avatar
Brett Hunter
Dyno runs would show evidence of torque management, if such a thing existed. I've never seen one that does. I think TM is , outside of traction control--or active suspension if you consider puting on the brakes torque "management." I've never read a word about tm in any car magazine, either. If it existed, they certainly would have had an article about it. Like I said .
I thought I already posted this chart in this thread but instead of looking for it, here it is again.
This dyno was done while speed shifting, notice the drops in performance versus normal dyno runs.
When the car was taken to a steady rpm in 4th then floored it produced "normal" numbers 346 hp and roughly 348 tq.
TM will show up on a dyno, track or street. It all depends on how you drive.
Old Sep 13, 2006 | 08:59 PM
  #594
zippin zee's Avatar
zippin zee
Those dyno runs were done on one of the flat earth days!!!!!!!!!!!!!!
Old Sep 13, 2006 | 09:18 PM
  #595
TrackNoob's Avatar
TrackNoob
if you've got the answers, provide them.
what happens when
what happens when
etc.
[/QUOTE]
Old Sep 13, 2006 | 10:34 PM
  #596
LS1LT1's Avatar
LS1LT1
JoeG what part dont you comprehend. i have been telling everyone that TM DOES EXIST for more than a year. are you dizzy from the g force on the turns or what.
Yeah I think he knows that Dennis, he was agreeing with you. I think he was suggesting that others go try it (have it tuned out/removed) and then talk about whether or not it exists, not for you to do it.
Old Sep 13, 2006 | 10:48 PM
  #597
dennis50nj's Avatar
dennis50nj
i guess i am getting to old and cant comprehend. hey i'm from the pines. my comunication skills are poor.
very sorry JoeG thanks Marc you can be my interpeter
To Torque Management System - C6
Old Sep 13, 2006 | 11:18 PM
  #598
LS1LT1's Avatar
LS1LT1
Or you could just delete that (and this) post before he sees it, I'll delete mine and no one will be the wiser.
Old Sep 13, 2006 | 11:42 PM
  #599
dennis50nj's Avatar
dennis50nj
good idea but i think there on to me. ah what the hell its done and gone
Old Sep 14, 2006 | 12:02 AM
  #600
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
We can solve this issue very easy. Anyone who has run the 1/4 mile more than once should see the same thing on their time slips.
A better sixty foot time will result in a longer 330 & 1000 foot times when compared to another run with a slower sixty foot time.
Example
run 1 _____ run 2
60 foot ..... 2.078 _____ 2.136
330 foot ..... 5.602 ____ 5.581
1000 foot ..... 10.906 ____ 10.784
Now why did I go slower with a better sixty foot ????? Voo Doo, those extra meat ***** the night before or TM/abuse mode. Now if you all look at you time slips I bet most if not all have the same result.............OK now we can finally end this discussion
