C6 1/4 Mile Performance Challenge
Old Oct 8, 2006 | 09:43 PM
  #921
yell03's Avatar
yell03
I spun on the 1-2 shift hard, maybe a little hop, but not enough to make me back out of it.
My Viper and my 03 Cobras did the same on the 1-2, but it is not the amount of hop as at launch, so I just let it rip on the 1-2.
Yes, it only happens at the track where it is a very smooth surface.
Howard
Old Oct 9, 2006 | 05:46 AM
  #922
Ranger's Avatar
Ranger
Here is another entry for the "showroom stock" C6Z06.
Cecil County Dragway, Rising Sun, Maryland. Sunday, October 8th. Witnessed by forum member waynet.
C6Z bone stock on stock tires, two passes, here are the splits.
DA was 1250 feet, as measured on my TAG weather station.
60'........1.848
330'......4.905
660'......7.370 @ 101.38
1000'.....9.470
1320'...11.244 @ 127.03
Two hour later, a second pass. DA at 1575 feet. The splits were:
60'........1.830
330'......4.915
660'......7.381 @ 101.31
1000'.....9.484
1320'...11.264 @ 126.91
Rear tires were set to 26 psi hot, adjusted in the staging lanes before each pass (psi will elevate in tires facing the sun). Fronts were at 42 psi.
Kept the coolant temp below 195. Launch rpm was 3100-3200, with a fast clutch release, followed by a progressive throttle squeeze. Throttle was on the floor at about 20-25 feet off the line. I had heated the tires with a burnout to first smoke. And then staged immediately.
These times will improve with improved driving under better conditions.
Ranger
Old Oct 9, 2006 | 06:40 AM
  #923
yell03's Avatar
yell03
Ranger -
Very nice!
I give you credit, you have really got the driving dialed in.
I watched a NEW Z06 run a 12.01@123.7 on 10/7 at E-town on a 2.01 60'.
I watched him run a 12.06 also.
The guy was a good driver, just has not snapped the 11s yet.
I do expect that you will run some 11 teens and maybe 11.0s if the conditions are perfect.
I also don't expect anyone to come closer than 0.2-0.3 of your times in a STOCK Z.
You put alot of time in to knowing your car and conditions
So, when are you gonna do minor mods and run a 10.9?
Howard
Old Oct 9, 2006 | 08:40 AM
  #924
Ranger's Avatar
Ranger
Originally Posted by yell03
Ranger -I give you credit, you have really got the driving dialed in...You put alot of time in to knowing your car and conditions...So, when are you gonna do minor mods and run a 10.9?....
No mods in my future, Howard. I'm a stock guy attempting to whittle away on the ET via the driver mod. I written often that it takes 30-50 passes to get dialed-in to any platform. That's especially true with the C6, due to the complexity (smartness) of the ECU/PCM and the toll of TM. I'm at 38 passes, 10 on stock tires and 28 on DRs. I'm still learning small things that make a difference.
Ranger
Old Oct 9, 2006 | 10:47 AM
  #925
yell03's Avatar
yell03
Ranger -
I hear you on the complexities of racing a C6.
I was humbled on Saturday at E-town.
Four launches and none better than a 2.023
2.3, 2.2, 2.1 and a 2.0.
However, I am going to mod, the C6 needs a little more, the Z06 has MORE than enough.
Howard
Old Oct 9, 2006 | 05:38 PM
  #926
SHOOTER 49's Avatar
SHOOTER 49
Seems like mid -Atlantic numbers are setting the bar. N.J, PA, and MD.
Old Oct 9, 2006 | 07:54 PM
  #927
LS1LT1's Avatar
LS1LT1
Ranger -
Very nice!
Amazing numbers once again Ranger, 11.2s bone stock!
When discussing the C6 Z06 with the many 'car people' that I hang around with I regularly quote your times (both stock tire and DR) and I had the 11.31 and 11.20 memorized, now I have to relearn your ETs again!
Good job and congrats again.
Old Oct 9, 2006 | 08:05 PM
  #928
Patman's Avatar
Patman
Hehe, that's funny, because when I talk to people about how I want an A6/C6, I'm always referencing your times to them!
Old Oct 9, 2006 | 08:25 PM
  #929
LS1LT1's Avatar
LS1LT1
Nice!
While daydreaming, I do sometimes start to fancy myself as the Ranger equivalent of the C6 automatic world ...but umm, not quite LOL.
Old Oct 10, 2006 | 07:38 AM
  #930
nastyC6's Avatar
nastyC6
last friday night at Etown my C6 auto ran 12.28 @114.78.1.9 60ft.on stock run flats..Vortec ,headers and a tune
Old Oct 10, 2006 | 07:43 AM
  #931
yell03's Avatar
yell03
nastyC6 -
Nice times!
Do you mean Vortex cold air?
All you auto guys are pissing me off, it is just too easy to run nice times
Howard
Old Oct 10, 2006 | 08:38 AM
  #932
Silver05GTO's Avatar
Silver05GTO
nastyC6 -
Nice times!
Howard
Yeah but look at your trap speed
Old Oct 10, 2006 | 11:32 AM
  #933
yell03's Avatar
yell03
I know, but would you rather run a 11.9@115 or a 12.2@120
On the highway the higher trapping manual would see an advantage,
Howard
Old Oct 10, 2006 | 12:27 PM
  #934
glennhl's Avatar
glennhl
Howard
From a roll you are correct, the manual will win. But in your example, I'd take the quicker 11.9 @ 115 from a dead stop. In your example, that car was .3 seconds ahead at the end of the quarter mile. At 115 mph, that's 50 feet. With the 5 mph advantage, the car that is behind will take another 7 seconds to catch up. There aren't many places on the street that you could stay WOT for a total of 19 seconds.
Old Oct 10, 2006 | 12:45 PM
  #935
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
Here is our latest for those interested.
2005 C6 Corvette Convertible
LS2/HD 4L65-E
DTE/APS Stage II Twin Turbo Package
DTE Stage II 3.42 differential w/ diff. strut
Magnaflow mufflers
M/T E.T. Drag Radials
Indianapolis Raceway Park 10-2006
10.89 @ 129.93 w/ 1.77 60 ft.
Old Oct 10, 2006 | 01:37 PM
  #936
LS1LT1's Avatar
LS1LT1
nastyC6 -
Hmm, maybe he installed a Vortec truck motor in there?
Hey, you've got that department covered as well man.
  #937
Ted P's Avatar
Ted P
I wish Ranger could get his hands on a regular c6 to see what it can do.
To C6 1/4 Mile Performance Challenge
Old Oct 10, 2006 | 01:39 PM
  #938
LS1LT1's Avatar
LS1LT1
Yes, I'd be curious about that as well.
Old Oct 10, 2006 | 01:42 PM
  #939
yell03's Avatar
yell03
Let's set it up.
Ranger can drive my car!
After next Tuesday (I'll have my headers on by then) we can meet up at ATCO or E-town.
You think Ranger will let me make a pass in his Z?
Howard
Old Oct 10, 2006 | 02:30 PM
  #940
Fore58's Avatar
Fore58
Let's set it up.
Howard
That would be the only way to do it. Ranger should be curious about what times he could run in a C6 through the 1/4. The quickest stock
C6 is 12.23 so far. The average Z is trucking around 11.90's I believe and the average good launch C6 is around 12.6. Ranger's last pass was 11.24, so take about .60 from the average Z, he would probably be around 12.00's with the C6 given his exceptional driving ability. I would be amazed to see a stock C6 break into the 11.90's. This would be a good challenge for Ranger. Having said that, I believe Ranger knows the real capability of the C6.
