Service Active Handling - Consumer Action
I'M SURE WHEM EVERYTHING IS RUNNING LIKE IT ID SUPPOSTED TO BE, HOPEFULY i'LL ENJOY DRIVING IT LIKE IT IS SUPPOSTED TO BE, AND THEN iI'LL BE ABLE TO ENJOY IT AND START MODIFIING IT LIKE "dAD" WOULD LIKE IT TO BE.
mOPARMIKE (AKA DADMOD)
Next week we have a tuner coming in and will do his 90% tune back to the car, and then finish it on the dyno for hopefully a perfect screamin' mean Z06 that it once was.
Drive Safe, Enjoy the Ride and Chadmod (our guardian angel) will be in the cockpit with all of us making sure we make a trip home in one piece.
Michael Jones
(aka: Mopar-mike, ChadmodDad, Dadmod
Michael Jones
I would have thought it would have been related to a bad BCM. Glad someone figured it out. Glad your back on the road diesel free. Bill
kindest regards,
-pete
Regards, Bob Kolhouse
HOWEVER something else has happened only twice and that is when i was just rolling down a two lane road straight ahead talking on the phone with one hand and the car just pulls hard to the right and applying brakes wasnt doing anything and had to keep pressure on the wheel to the left to maintain a straight line , like 2 seconds worth of that then it released the brakes and then service active handling chimed in, That didnt happen agian for another year when going down the interstate in the left lane with cruise on and she goes hard right into right lane and the hard left right back into the same lane before i could even start to get a foot on the brake, it was that fast, when i applied brakes it was the same as before, they just didnt work, then after a few seconds of fighting it, brakes released and then service active handling comes up, so every time i think about it i turn the system off,
is the the steering sensor wire I read we are talking about?
Each ignition cycle, the EBTCM runs a self test and all the DTCs that were previously set get reset and the lights and warnings also clear.
As it detects a new error, it it displays the new messages and DTCs
There are several causes for this problem. False or wrong signals from one or all of the following sensors:
- Lateral Accelerometer
- Yaw Accelerometer
- Steering Wheel Position Sensor (SWPS)
- Malfunctioning EBTCM
- Wheel Speed Sensor
Unless theres an obvious defect (Loose connector, damaged sensor, bad harness, corrosion etc..) The only way to figure out whats causing it is using a TECH II and having it connected when the problem happens.
If you can find a TECH II and connect it to your car, just driving it around may show a failing or over sensitive sensor.
Good LUCK and drive safe!
- Yaw Accelerometer
Yesterday, while accelerating at about 3/4 throttle in 3rd gear, I again experienced severe steering wheel shake. It oscillates at about 4 to 5 times per second from approximately 20 degrees each side of center. This is the 3rd time this has occured in the past year, each time at a different location, so I know it's not the road surface. I also know it has nothing to do with alignment or wheel balance as I've had this checked, and I also cannot reproduce this phenomenon. It's damn unnerving, as it doesn't start until 80-90 mph and comes on in a heart beat. I have never stayed in the throttle to see if the car will drive out of it, as I value my life, and it seems that only slowing causes the shake to disappear and it stops as suddendly as it occurs. And, it's not just the steerting wheel that is shaking, the car is also oscillating right and left, just as if I was rapidly moving the wheel.
With all the concern about the AH and TC with these cars and the accidents they have appeared to have caused, I wonder if this shake could be caused by a malfunction within these systems?
I sure would appreciate any insight, or know if anyone has had the same incident?
This was posted on 26 Nov., 2009 in a General Discussion thread.
I "WONDER" if we would get more attention if we brought this up on one of the BIG TV networks or even FOX news?? Just like the recent gas peddle getting stuck or the Firestone Tires exploding that got big coverage. I think I will send this link to FOX!
Start sending the BIG TV Networks this LINK.. Someone is bound to pick it up and do a story on it. You know,, GM stands for GOVERNMENT Motors.
This seems to be LOW KEY right now, Maybe we can ramp it up on our own!!!!
Bill Curlee
American News Room
I am a proud owner of a 2006 Corvette Six Speed Coupe. I love the car. I am also VERY VERY concerned that one day my car might have a mind of it own and the ACTIVE HANDLING System might wreck the car. I am a member of CORVETTE FORUM. People who own Corvettes all over the world meet in the same forum and discuss platform issues and concerns. The C6 Active Handling System has a FLAW that causes it to activate the vehicles Active Handling system on a straight level dry road when it shouldn’t and violently jerk the car to the LEFT or RIGHT at highway speeds.
This single issue is big covers the entire 2005-2010 C6 model platform and is starting to become a monster. No one at GM seems to be concerned. The NHTSA has been contacted by numerous C6 owners and they have only taken a nibble at our concerns but, nothing has been done to cause our problems to be addressed by GM.
I am writing FOX in hopes that you will read this 215 part post and to see if you would like to TAKE ON this issue as a Public Safety Issue. You are my FIRST contact point !! I have urged others on the forum to contact other news stations in hopes that someone will publically address this issue and bring it to light and cause the NHTSA to take ACTION or shame GM into fixing the issue!
I really enjoy FOX News and all that you do and do well and pray that you can investigate and report on this problem.
This is the entire www.corvetteforum.com C6 Technical /Performance post. Please read it and see if you can do a story on a real public safety problem:
http://forums.corvetteforum.com/c6-t...post1572268609
Thank your for your time.
Sincerely
William Curlee
BC
My 99 had a nasty active handling problem, when you would go change lanes it would lock up the RH front wheel and pretty much start sliding off the road. It happened the first time and I almost hit a friend of mine driving on the highway, bunch of lights went on in the dash but I was able to manhandle it and keep it out of the ditch (I ws going 85mph at the time).
I wrote it off to the 17" drag radials in the rear, until a month later the car did it again when passing on a 2 lane highway, it locked up the RH front so hard there was smoke coming off the tire.
I wrote it off again and a couple weeks later it did it again changing lanes on the highway. Car was out of warranty so I started troubleshooting, I was able to get the car to do it whenever I wanted by moving over at speed just the right way. I originally thought it was something with the steering angle sensor. But after studying the system I came up with the lateral accelerometer IIRC causing it. 20.00 for a used one and 10 minutes later the poblem was fixed, that was 6 or 7 years aho so I dont remember exactly how I came to the conclusion that that sensor was bad. Most likely it was a lucky guess..
Fast forward to 2009 and I'm glad to see they still havent figured it out 100%, I thought it was pretty stupid that I could turn AH off and it would still do the same thing and turn the AH back on by itself. I'm not that scared of it, but I really wish there was an easy way to turn it off and keep it off.
I sure am glad I came back to the Corvetteforum. I used to have a 95 Vette(sold) and since July now have a 2005 Z51.
Last Thursday I got a Service active handling message while crossing over a railroad track at 5 MPH. I pulled over and restarted the car, error message cleared. I thought maybe that just crossing such a bumpy track had caused it and thought no more about it.
The next morning driving to work on the highway my car suddenly slowed, kicking off the cruise control. The Active handling message came on and quickly went off. I didn't notice if the brakes came on or not. Lucky for me I had read this thread. I soon slowed and put both hands on the wheel. I moved over to the right lane to exit the highway. I slowed through 55 MPH that is when the right front brake applied for about half a second, scaring the crap outta me and pulling me over into the exit lane. Luckily, nobody was on my right.
I got the car serviced today and told them about the connector TSB. They found the steering position sensor bad and that was all. I'm still wary that the problem is fixed and may have to take a look at that connector myself.
Car is a 2005 Z51 with the telescopic steering.
Thanks for the heads up!!!
Also, i did file a complaint.
Darrell
