Service Active Handling - Consumer Action
I was driving back from Ky. this Sunday, had been driving ~5 hours and everything was running smooth. I'm doing 80-85 in the left lane when suddenly I loose all power,engine and electrical. Luckly I was able to get to the right shoulder but it was very intense due to all the traffic around me. Once I got pulled over there was a relay ticking somewhere and the dash lights were flashing in unison with the relay. I could not get the car to restart. Eventually had it flat bedded to chevy dealership in LaGrange, Ga. When they checked the car Monday AM they said the ABS module had shorted. This in turn opened up the CAN bus which shut down the ECM & BCM. Supposedly they bypassed the ABS module (can they do that?)and the car was running but I don't have ABS. I drove the car home without incident but am worried about just what is wrong with it. Oh yeah they want ~$1500 to replace the ABS module.
I do seem to recall seeing "Service ABS" as all the excitment was happening but it hasn't come up since.
Sorry for the long post but wanted to be clear as to what happened.
Car is an 07 ZO6 with 46K miles and the telescoping steering wheel.
Kelly
Heres the only C6 schematic that I have (05 off of ESI) so I hope that its the same as 07.
Module ground is Pin F
Can buss POSITIVE is B11
Can buss Negative is B10
Looks like its a shielded wire and the shields are B12 & B9
If disconnecting the module from the car fixed the problem, the connector and the wiring is most likely fine.
The STEALERSHIPS gets a premium for all their parts. Contact Gene Culley www.gmpartshouse.com and see what he can do for price. The EBTCM is a plug and play module that you can change your self and save a boat load of cash!
Heres the procedure:
Electronic Brake Control Module (EBCM) Replacement
Removal Procedure
Turn the ignition switch to the OFF position.
Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
Disconnect the brake fluid pressure sensor connector.
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the two bracket bolts.
Disconnect the electronic brake control module (EBCM) connector.
Remove the four EBCM to brake pressure modulator valve (BPMV) bolts.
Separate the EBCM from the BPMV by gently pulling apart until separated.
Installation Procedure
Clean the BPMV seal surface with alcohol using a clean rag.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the EBCM to the BPMV.
Tighten the four mounting bolts in the following sequence:
Tighten
• First pass to 3 N·m (27 lb in).
• Second pass to 6 N·m (53 lb in).
Connect the EBCM connector.
Connect the brake fluid pressure sensor connector.
Install the two BPMV bracket bolts.
Tighten
Tighten the bolt to 27 N·m (20 lb ft).
Lower the vehicle.
Turn the ignition switch to the ON position, engine off.
Perform the Diagnostic System Check - Vehicle in Vehicle DTC Information.
Gene will give you the best price!
Good luck and keep us informed on the results of your repair.
This is ONLY a temp fix. I'm POSITIVE it will be back as soon as there is enough movement in the connector components.
Hopefully,,,,,,,,,,,,,,,GM will man up and provide a repair.
BC
if they don't address this issue with the current climate with Toyota's acceleration issues. It can be argued that our issue is just as dangerous.GM is recalling several vehicles but not the vette
The Cars included in the current GM Recall List:
·2005 - 2010 Chevrolet Cobalt
·2007 - 2010 Pontiac G5
·2005 - 2006 Pontiac Pursuit (Canada)
·2005 - 2006 Pontiac G4 (Mexico)
Thanks for all the hard work Bill!
Tony
Tony
Bill
under mild acceleration either turning or just straight out the Service Active Handing, Service Traction Control, Service ABS errors appear. They remain on the DIC until the engine is restarted.
However, when the service tech tries to read out codes with the Tech-II there are no codes stored. GM tech services tells him that cannot happen and a code must be stored, but there is no code.
last week GM installed a data recorder and they are trying to analyze the recordings to see if any codes are captured, no feedback yet.
I will keep you updated on what we find.
UPDATE 1:
The data recorder had no information captured even though the messages appeared on the DIC. We will try the data recorder again and see if anything can be captured. I am printing out this total forum entry and taking to the tech.
will keep everyone informed if anything pops up, except a message.
UPDATE 1:
Service ACTIVE HANDLING SYSTEM is the message I got. Have not had an issue since I did my fix.
Karl
Each time that you turn off the ignition, the EBTCM resets its self. Ask them to look for DTCs when the problem is current and connect the TECH II with out turning off the ignition.
See if you can wiggle and pull "lightly" on the Steering Wheel Position Sensor cable and cause the problem. You will need to remove the close out panel under the drivers dash. Its not too difficult. Heres a picture of the SWPS and the cable;
Woops,,,C6 calls it VARIABLE EFFORT STEERING!
I am new to the forum as well just had this happen to my 09 vett we just put a Edelbrock super charger on and now when i accelerate hard i get these warning lights you have mentioned in this post never happened before until i got more power to the rear wheels possibly a different problem. ?
please advise
thanks Dan
I tried the following in a relentless persuit to keep my vette.. Tuning to adjust to tire sizes(invo), Doing the clip on the steering column, brakes, grounds checked, new SWPS and even a new EBCM!! This issue along with being modded got me kicked out of a a couple of places... I was postal!
At the end, a local tech at a dealer found the issue was that my car simply did not agree with the exhaust combo. The vibration/tone was too much for the electric sensor. I chose to keep the headers and go with Z NPPs and it completely went away for good!!! This was my experience.
