Service Active Handling - Consumer Action
I have filled out the ODI contact form and have filled out the formal complaint form.
In short i hope this helps solve the problem/s with ah system failures,It wont get my 4500 mile 2lz Dsom z06 back but more importantly it could save lives and other property.
Thanks for donating your time to this.I as well as others im sure THANK YOU. Ian Cote
What happened to your 'Z' ??
Everyone was fine, Z06 was totalled, and I just think (even though very capable of doing so) he had no desire to buy it back from the insurance company and repair it. With all this uncertainty... would you? or would you just take the cash for the value of the car and think about your next ride?
I didn't know how frequently he was checking in to this forum, so I figured I'd chime in here.
looks like this recall is pretty worthless
I want an hour of my life back for the trip to the dealer GM
Let me know when you have a real fix
Also to the original poster of the POLL, you should have a section for those of us that did the recall and problem still occurs
Same here. Did the recall fix and still have the same issue.
He is a very good dude - always trying to help out. I know for a fact he went back and forth directly with the NTHSA Principal Investigator, Steve McHenry during this whole thing. He showed me all the emails he had sent from each individual on CF that contacted him. A personal crusade for our safety
Link of the completed study: http://nhthqnwws112.odi.nhtsa.dot.go...09002-3573.PDF
1. Yes, '09's are affected. (Mine is a 2009 3LZ C6Z) I get two messages: "Service Active Handling" and "Service Traction Control."
2. Yes, I drive with the wheel fully extended. While I leave it fully extended (no cycling in and out), I do use the manual tilt when exiting the vehicle.
Also, I note that once the message comes on you cannot fully defeat the system. But, if you're quick, you can. Before the message comes on, turn off AH and TC, which then puts you in Comp Mode, hold for another 5 sec. (seems longer) and then all is off -- no more messages until restarted.
I'm notifying NTSB and seeing my dealer for the TSB repair.
Thanks to all for their diligence and excellent reporting.
Andy
Thanks for your post above with pictures!
My Service AH light came on last week, so I started reading up about it on the forum. I read many post, and still wasn't sure if I wanted to try this. My Z was built in March 2006, so it's not covered under the recall.
My plug into the steering wheel positioner switch (SWPS) is different than what you show. The orange clip you show would not work with the plug style I have....this is probably why my car wasn't covered under the recall, cause they changed the plug.
Apparently, my plug had just come loose, and I pushed it further in, and it snapped into place. Ths Service AH light is now off.
Thanks!
At this point, I think people having issues, just DO IT YOURSELF. Stop relying on GM or some ****ty dealership to fix it because obviously they are not doing a very good job, regardless of warranty or recall. Better safe than sorry.
Good luck
T
I had the "Service Active Handling" message appear while I was on a long road trip. The warning would come on intermittently. I called the dealer's Corvette guy and he told me to bring it in for a scan when it again appeared. (I always drive with the traction control on.) Shortly after this I was driving in a down pour and started to pass a truck and as I got beside him the spray was limiting my visibility so I stepped down on the accelerator and one (?) rear wheel broke loose causing the rear of the car to start moving sideways. I quickly recovered with no further incidents occurring.
I took the car to the dealer and they quickly found the problem: the cable connected to the steering wheel sensor(s) was pulled loose and a new cable clamp (specified in a factory alert?) was installed. Note: my car does have a telescoping wheel.
Just returned from a 4,900 mile trip from Oregon to Fairbanks with no
problems with the traction control or any other part of the car. Cor vettes are wonderful touring cars: comfortable, economical and fun to drive.
Good luck
T
1. The sensor is mounted off center (does not point directly down, but approximately 20º to passenger side;
2. The male end of the connector has six pins rather than four.
3. There is lots of wire -- nothing to pull tight.
Although the connection seems loose to me, wiggling it does not set off the SAH message, so the connector may not be the issue.
I've ordered an Actron scanner, which should be delivered tomorrow. We'll see -- I may have jumped the gun assuming it was the connector, but it seemed like a logical place to start given the history.
Andy
I drive a 2010 ZR1;
In less than 1500 miles, I started to get the same "Service Active Handling" message on the DIC. I'm not sure if I seen "Service Traction Control", but on several occasions the "Service Active Handling" message appeared. With more frequency the last few days I've driven it. A restart seems to make it go away, and I didn't notice anything but when I seen the message, it worried me and I just coasted to a stop and restarted the vehicle. Seems to fix the error for a short while, but it comes up every few drives. I'm very concerned about this.
Any advice on how to fix this myself for the "2010" year model would be greatly appreciated, but I do plan to file a complaint if I am able. All help would be appreciated.
- Bryan
I drive a 2010 ZR1;
- Bryan
I drive a 2010 ZR1;
- Bryan
Here is a DIY that I created when I fixed my SAH. I have had NO ISSUES since I did this myself. Although I have a 2006 Z06, I would bet that you have the connector that is pictured right above your post by A-Z. They may have changed the connector, but it apparently is still a (Chinese?) POS connector. If you look through the 5 million posts in this thread, you will also find that Bill Curlee posted a very interesting article on the POS connectors and problems they are causing other than the SAH issues that are primarily related to the SWPS. Basically, the way I see it, the poor connectors used in the wiring harness are the sources of all these problems. Fretting, harnesses too tight and pulling on the connectors, or just bad connections are creating open circuits in the system. Since the car is like a fly by wire jet, it is causing other issues as the computer tried to correct the error, like applying a left or right brake when you are going straight because it thinks you were in a turn.
Since you have a new ZR1 (bastard
) I suggest you follow that DIY and check that SWPS. I bet it is just loose.Good luck
http://s680.photobucket.com/albums/v..._AV8R/?start=0
Tony
