Service Active Handling - Consumer Action
Jessica
Chevrolet Customer Care
I have a 2011 Z06, with the Z07 Ultimate Performance Package. 9,882 miles.
I've had other C6 Corvettes and had the issues with the steering position sensor on my 2005. Had the recall work done, but I'm pretty sure this isn't the root of my problem in my 2011 Z06.
I've taken it to my dealer and they just tell me they can't find anything wrong with the car, but I've had quite a few instances of the Active Handling System applying the brakes at times it shouldn't. I've had the Service Active Handling Message on the DIC once.
I've been coasting/engine braking in 4th gear, in a straight line and it applied brakes. I've been in turns and had it apply brakes to the outside front wheel in a jerky way when I was in no danger of losing traction. As I'm going through the turn, it's like jerk, jerk, jerk, through the turn. I've even had it apply brakes to both front wheels and bring me to a stop while going straight. The person behind me was pretty mad, they thought I was brake checking them. It was an Aston-Martin, thank God he didn't hit me. That was pretty embarrassing.
I see that this is a widespread problem, but different causes in various years. As I said, I don't think my problem is attributed to the steering position sensor, like with the 2005-2006s.
What bothers me is, the dealer just throws up their hands and says "it's not throwing any codes, and when we drive it, it operates normally, so we can't do anything". Really? Has our world gotten to the point where, if they can't plug a machine into it and the machine tell them what's wrong, they can't do anything?
They did offer to give me a data collector, to connect to my ODB II, so they could get a snapshot of what's going on when/if it happens again. I just never know when that's going to be. I only drive the car about 4,000 miles a year, so this may be quite a challenge.
I would be willing to pay, to upgrade the whole system to the newer Performance Traction Management System, that the 2012 and 2013 cars came with. I haven't heard of anyone having these issues with the newer system and I know for a fact, it's a better system.
Has anyone investigated this or knows what all is entailed with upgrading a car (2011 or earlier) to the 2012-2013 PTM (Performance Traction Management)?
I would think that it's mostly software, with some hardware changes.
My car will still intermittantly lock up one of the front brakes (Left Front or Right Front) and state "Active Handling" on the dash.... No DTCs. When it goes into this mode, it will continue to lock up that brake for every 10 feet of movement till the ignition is cycled. Car has 43k miles.
Read through the information and see that the thread mostly applies to 2005-2008. I own a 2010 GS with 10150 miles on it, and I'm getting the "service active handling system" with a yellow signal in the gage. The car seems to drive just fine.
The TPMS devices are all new, they are clones from the orginal ones. But, I get the same notice with my GM factory TPMS on. I have two sets of wheels each with its own set of TPMS devices.
The warning comes on after driving for a bit. But, is not there when the car is first started.
Any one got any advice?
If it fails any portion of the test, you get the messages and the DTCs
I see you're having similar issues! If anyone is currently experiencing this and has their Corvette at the dealership or planning on taking it in please private message me. I would like to help. Please include your VIN, mileage, address, phone number, name and the name of your dealership. Also reference this thread. I look forward to helping out where I can.
Kelly J.
Last edited by nock; Jun 1, 2014 at 10:46 AM. Reason: My son though he was sending a private message
Marissa
I was later told by a club member that there were problems as per this thread, and a temporary fix was to hold down the active steering button for 8 seconds to disengage the handling and traction control to make it home. I made it home with no problem, but was concerned this might happen again.
Took the car to the local Corvette Shop and had the wheel aliment checked and the rear wheels were off pretty good, but the fronts were fine. The shop owner told me I should always disengage the active handling system as I did after the track experience.
I also checked my VIN for recalls, but my car was clear. My Vette is a 2006 Couple.
When the issue would occur I'd get a wheel locking down pulling the car to the right. Fortunately it would usually happen fairly quickly and not randomly while I was driving down the highway.
I was going to purchase a new hub for the one connector and splice in a new connector on the other end when I came across a thread on here where the guy just removed the connector and soldered the wires together. Rather than dropping money on replacing a hub that doesn't need to be replaced just for a connector I went the solder route and have not had an issue since. If I ever need to remove that hub I can just cut the jumper wire I soldered in and solder it again when I am done. So much easier to deal with than a poorly designed connector.
The sensor is integral to the hub and I do not believe it can be replaced.
http://forums.corvetteforum.com/1573340784-post849.html
Splicing in a new connector:
http://forums.corvetteforum.com/c5-t...e-harness.html
Then I read read what it would take to replace the hub:
http://forums.corvetteforum.com/c5-t...ment-help.html
and figured soldering would be a much better use of my time & money:
http://forums.corvetteforum.com/1573067036-post17.html
I also used 16 ga wire to make a jumper cable between the sensor wire and the connection going to the chassis. Heat shrinked them both then wrapped in electrical tape.
Since the aliment and running with the Active Handling and Traction Control OFF, no problems so far.
