Cam install gone bad.
I don't know if you know it or not, but water cannot be compressed. Water can get by the rings during a hydrolock, besides causing unreal stress on the bearings as the piston tries to compress the fluid. If those forces can bend a connecting rod, you can bet your *** water can be forced around the rings along with compressing a bearing to failure, or in the case possibly near failure. And it doesn't take but a few seconds of water running through the bearings to cause harm. Not to mention the debris that was found in the intake track and apparently lodged in the intake valve.
The motor may not fail immediately, but to say there was no harm out of hand just proves my point.
A water failed bearing doesn't always show a failure right away. However, it can cause problems down the road. Looking at the bearings will show if there was water contamination.
Hopefully someone was smart enough to pull more than one bearing and save them for proof.
The parties involved seem more concerned with pointing fingers than actually finding the root cause of the failure.
Low oil pressure was a symptom of the failure, not the cause.
Seems like some could use a few anger management classes.
hmmmmm I have killed 4 engines (off-road racing) due to sucking in water, and what you just said is completely wrong, if you get the water out of the cylinders and that’s it, generally they will last another 10-50 hours on the watery oil (had to finish the race
).... that is if the rods and valves aren't bent. I also took those said motors apart myself to re-build and guess what? There was water in the oil on all 4.... It doesn't take very much, or very long to compromise the oil's lubrication values. No rings seal perfectly, and definitely not when they are trying to compress water until the engine seizes. Water in the oil would almost certainly let your bearings live for a little while though.... haha just like what you describe. It can also over stress the bearings making them a little flatter in one spot, while this is unlikely, it can happen.
Is this what happened to you? bah, who knows. It sounds likely to me though.
Who am I though, just a ME with lots of this exact experience... Your going to be a lawyer....
If I was you I would *cough* "Cowboy up" and understand sucking in water until a engine dies generally causes a lot more harm then one would imagine.
Best of luck getting it sorted out. If I was your mechanic I would definetly change your tail light oil also, it would cost a lot, but if water got in there you car could explode at any moment.
I think it's very likely he did. I also think there was prior damage due to the submarine duty it did and the damage was accelerated by running it hard to feel that cam.
Take the emotion out of it and look at it logically. You need to do this, it's your baby now.
fellas,,, this thread is making things worse not better. Its hard to say what you mean in type sometimes and cooler heads usually prevail when they are "face to face" or even on the phone.
Get yourselves on a conference call for all involved parties. No reason to get even more upset then you already are. Good luck with the issue. Paul
I would pay to have your car fixed myself if I honestly felt Gectek did you wrong. He's not that kind of person, and has also been there on countless cam installs with me. You know how many he's screwed up? Zero. I honestly (not just because I know the guy) believe you are pointing the finger at the wrong person.
Oh, and sorry that you have to get a real job now. Welcome to the real world!!
About Rule292
Mods
None yet other than the famous Leres CAGS fuse
Your profile indicates that you are being "cautious" too.
Whats the matter??? Skeered???? Who can blame you after a saga like this one? I think you'll be OK with just that fuse though.
And never modify an expensive car if you can't afford too.
