Trick flow install underway
Old Apr 15, 2010 | 06:58 PM
  #61
Rule292's Avatar
Rule292
St. Jude Donor '11-'12-'13-'14-'15-'16
Originally Posted by LSCHLEM
I just got done putting everything on except the FAST. Here are the final pics on the torqued heads. I will torque the manifold down later tonight when I get 2 1/2" bolts to get a better view. Check it out. Definately
overported here and will talk to porter about my situation.
Kewl!
When you get up and running you gotta give us another YouTube test drive getting on the bypass there at Broadcasting Rd.
Old Apr 15, 2010 | 08:17 PM
  #62
timd38's Avatar
timd38
If I was to pay to have a cam and head install like this, how many hours should I plan to pay for?
Thanks!
Old Apr 15, 2010 | 10:00 PM
  #63
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Thanks!
Shops quoted me 2 days and any additional parts + Dyno tune is like
$500.00 more. We are talking about $1,500.00 to swap out the Heads.
I already have A good tune and I can put a PATCH in W HP TUNERS.
I really enjoyed doing it myself although at times it had its moments.
That oil pump reservoir was messy and aggravating and I had to install it twice because of one bolt. I wish there was a way to get the water out of
there. I was going to use A VAC CLEANER. All & ALL even if the thing blows up it will have been worth it considering how much I learned by
doing.
I guess my hourly rate would be about $2.99 / HR. I had to buy all
new tools Metrics big time, Torque wrenches,specialty tools, cleaning
supplys. The last time I swapped Heads was in 1909 but i did full builds
without even knowing what I was doing. Ill fire it up tomorrow or sat
What do you think It will Dyno at ?
Old Apr 16, 2010 | 01:09 AM
  #64
SpinMonster's Avatar
SpinMonster
487rwhp/455rwtq
Old Apr 17, 2010 | 07:16 AM
  #65
black06vette's Avatar
black06vette
Thanks!
Depends on the guy doing the work, maybe 8-10 if they remove the heads and maybe 4-5 if they risk not removing the heads.
Old Apr 17, 2010 | 08:21 AM
  #66
LSCHLEM's Avatar
LSCHLEM
Default OH We better do better.
Originally Posted by SpinMonster
487rwhp/455rwtq
Maybe I will only get a 20 RWHP bump out of the TF Heads. I should get that out of a set of ported STOCKERS 243's. I got A little confidence going here and still have a few tricks on the Table. I know SPIN has some ideas
that I may work with him on. He said he would help Me reach my goals.
Old Apr 17, 2010 | 08:48 AM
  #67
dennis50nj's Avatar
dennis50nj
and he will, he has gave me a bunch of ideas
Old Apr 17, 2010 | 02:08 PM
  #68
LSCHLEM's Avatar
LSCHLEM
Default Fired up 1:50 pm . Wow, oh oh leak
Fired her up about 10 min ago. Turned for about 5 sec then fired. Sounded
Louder than norm but seen A gas leak at CYL #7 injector. Probably have to pull it. Maybe it didn't seat and should of used grease on the O rings I think. Didn't see any leaks elsewhere nor did the engine have loud tappeting. I love those Yella Terras.
Old Apr 17, 2010 | 02:23 PM
  #69
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Keep us posted Leon....and get a video up!
Old Apr 17, 2010 | 02:28 PM
  #70
dennis50nj's Avatar
dennis50nj
Old Apr 17, 2010 | 02:39 PM
  #71
LSCHLEM's Avatar
LSCHLEM
Joe , Can you put grease on those O rings around the fuel injectors. It seems like the one is cockeyed.
Old Apr 17, 2010 | 02:46 PM
  #72
Joe_G's Avatar
Joe_G
St. Jude Donor '08
yes I've used a little silicone spray with good effect.
A quick search reveals an injector company prefers dish soap.
http://www.ls1tech.com/forums/10830310-post7.html
Remember you've got the fuel rail o ring and the manifold o ring make sure both are propery seated and that your oversize washers are properly holding the fuel rails down...I have to tighten mine in a cross pattern and hold the rails down when I do it.
p.s. fuel on the engine (and I've had it more times than I'd care to admit on my Oldsmobiles over the years) scares the heck out of me. Be sure to have a extinguisher handy just in case. Put out quick a fire can be no big deal. I had a buddy's car burn to the ground while he looked for an extinguisher. Be careful buddy.
Old Apr 17, 2010 | 09:39 PM
  #73
LSCHLEM's Avatar
LSCHLEM
Joe, Thanks for the tip. It worked like A champ. The dish detergent actes as a lube all slid in nice. This time I did not start the Car . I pulled the START RELAY and only turned on the fuel pump. Still had a small leak at injector #4 . Fixed it. Then I put A Gauge on the shrader valve
and let it sit. So far no leaks. See if it holds Gas Pressure at 60# overnight. I should be able to fire that baby up in the Morning.
Old Apr 17, 2010 | 10:26 PM
  #74
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You should be fine. Looking forward to the results! Tf heads are probably my next mod.
And I'm eager to hear what Spin's ideas are....
Old Apr 17, 2010 | 11:46 PM
  #75
dsp300c's Avatar
dsp300c
when you think you will get it dynoed? can't wait to see another set of TF wake up an LS2. you will love them even though they cost some dough.
Old Apr 18, 2010 | 04:57 AM
  #76
SpinMonster
Send one head and the intake to me.
Old Apr 18, 2010 | 08:04 AM
  #77
LSCHLEM's Avatar
LSCHLEM
Actually Tomorrow is dyno Day. Got to run it this morning, check for leaks
strange noises, tools left in the engine and rags I might have forgot to take out of the runners. I may do A small Vid today yet.
To Trick flow install underway
Old Apr 18, 2010 | 09:32 AM
  #78
LSCHLEM's Avatar
LSCHLEM
WOWTook it for a drive this morning. Seemed like it was running slower than before and had sluggishness . CEL was on from the get go. Put the predator on and sure enough " Injector #3 was open. Put injector plug on and WOW the animal came out. Snappy was the word.
This Car is LETHAL now. In second and third wheel spin at partial pedal
and I never had it near to the Floor. The Torque is there instantly. Engine
ran at a cool 190 and no leaks or funny engine noises at least as of yet.
I am super happy about this install although I had my follies it was a tremendous learning experience. I know there is more than 20RWHP but
it feels like I added another 100RWHP/TQ.
Old Apr 18, 2010 | 10:14 AM
  #79
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Whoa this is interesting!!!
Old Apr 18, 2010 | 11:11 AM
  #80
pmj341's Avatar
pmj341
Leon
I knew you would be a happy camper
