Dyno Pull Gone Bad....
Old Aug 14, 2013 | 03:43 PM
  #61
PRE-Z06's Avatar
PRE-Z06
The LS9 cam is worth ~25hp from the dynos I have seen on an LS3. It's 7* larger on the intake and 19* larger on the exhaust with .011" more lift on the intake and .033" on the exhaust it would gain more than 1.85 rockers or ported intake imo and be cheaper. The hot cam from GM made 40hp more in a LS3 in the article below and it would still work with your stock springs/pushrods. The ASA cam mentioned is 8* larger on the intake with the same lift so I imagine it'd make ~15hp more. Though the hp gain of 95hp from the alleged 525hp crate engine already takes into account bolt-ons I believe as you can see in the dyno what a stock LS3 does with them at the crank and then the difference from the additional cam. Another option for good bang for buck valve springs are Brian Tooley dual .660" for $219, hope this helps.
http://www.gmhightechperformance.com...n/viewall.html
Old Aug 14, 2013 | 04:28 PM
  #62
HOXXOH's Avatar
HOXXOH
Originally Posted by LS1LT1
But DO keep in mind that jpee does NOT use skinnies nor remove the passenger seat of his well optioned C6 like many of us have done, heavy Optima battery and sometimes a nearly full tank of gas too (I've yelled at him for that part already LOL ).
But even still, he can run 11.50s with a stock internals/bolt ons LS3 at E-town even at his raceweight. If not during June/July/August then at least during the rest of the year.
With the rare exception when not running DR's, I've never been slower than 11.40 even in full street trim. Sometimes I just go have fun and don't bother with any weight reduction. I even ran with Joe G., Theofel, and friends at PBIR on Invos while on vacation and managed an 11.44 before I had headers and ported IM. However, my low fuel light did come on before I left the track.
John's not going to have problems running 11.50's, since Cartek can surely tune better than me.
Old Aug 14, 2013 | 05:32 PM
  #63
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
He should just put in an LS9 cam and call it a day
Old Aug 14, 2013 | 05:36 PM
  #64
jpee's Avatar
jpee
I think thats where I'm going...!! Sounds like it won't shake my fillings loose, and still give me some nice added power.. I'm NOT looking for a 10 sec car.. just a low 11 sec...
Old Aug 14, 2013 | 05:46 PM
  #65
franman69's Avatar
franman69
Anybody know if you can put the LS9 cam into an LS2??? (I'm cam shopping)...
Jpee... sounds like you're on a good track to getting her back on the road, faster than ever. Sorry again about this crazy hassle you're going through.
Old Aug 14, 2013 | 07:00 PM
  #66
Joe_G's Avatar
Joe_G
St. Jude Donor '08
My opinion is if you are going to bother going to the trouble to put in a cam, get a cam designed specifically for the operating characteristics you plan to use the car in.
The ls9 cam is a cam made for a blown engine that must comply with emissions standards and a 100,000 mile power train warranty. Personally I wouldn't use a cam for a blower car on a N/A car.
The LS3 heads have substantially different flow characteristics than the ls2 heads. I would not use a ls3 designed cam with an ls2.
If you have a natural aspirated engine that you don't need to comply with emissions standards, you can get a cam that is substantially more suited to your needs.
It's generally good practice to match your components as a system, you will be much happier with the result.
Old Aug 14, 2013 | 07:18 PM
  #67
dennis50nj's Avatar
dennis50nj
Joe is 100% correct
Old Aug 14, 2013 | 09:43 PM
  #68
franman69's Avatar
franman69
Great advice Joe and of course you're right.. I'm just swimming in Cam research, specs and 'opinions'... the article on the LS9 cam was interesting for sure. I'm not looking for a radical cam in any way.. I know I'll need to do the other upgrades at the same time, so I'm just exploring all options. Now, the Jpee's thread digressed into a cam discussion, I just had to ask.
I like some of Spin's threads on Cams. Good reading for sure.
Old Aug 15, 2013 | 12:26 AM
  #69
irok's Avatar
irok
jpee if you swap out that cam or have the front engine cover off your new engine dont forget to swap out the finicky high tech failure prone cam chain tensioner in the LS3 for the bullet proof LS2 chain dampener p/n 12588670 that is used on the LS7 and LS9 also. dont want to be pulling oil pan later and trying to fish out pieces of the LS3 chain tensioner. I believe they are under $20. Dan
Old Aug 15, 2013 | 10:44 AM
  #70
jeremy_sanchezC6's Avatar
jeremy_sanchezC6
Agree
Old Aug 15, 2013 | 10:54 AM
  #71
John harlen's Avatar
John harlen
Then talk to a reputable shop. Flowtech can set you right.
Old Aug 15, 2013 | 02:13 PM
  #72
PRE-Z06's Avatar
PRE-Z06
Just to clarify the only difference in the LS9 cam for a "blower" and the LS7 cam which is a "NA" cam is a 2* wider LSA and that could very well be for emissions because of trying to run the same size cam in a smaller motor
Yes there are better aftermarket grinds out there, I was only sharing that info with jpee being that he sounds like he's on a budget and only looking for a small gain in power.
Old Aug 15, 2013 | 07:35 PM
  #73
jpee's Avatar
jpee
Thank you.. you hit it on the head.. I'm limited on my spending.. YES I have a few $$ to spend, but NOT thousands... I cleaned out my savings when I put a hole in the side of my LS2 block...
I DON'T want to put in an LS3 and screw it up also...
Old Aug 16, 2013 | 02:52 PM
  #74
victorf's Avatar
victorf
IMO, any performance designed car from any brand had spent countless hours in the making, backed up with an warranty from the maker basing on their engineered over design within the reliability parameters. When we push that envelope with go fast goodies, we are in the arena of pay to play.
That said, within the C6 family, we are blessed with base, Z06 and ZR1, personally, if I want a lot more power, given the iffy reliability with the Z06, I would go for the ZR1 along with the warranty and call it a day.
Based on experiences, I am perfectly satisfy with my base, along with basic hot rod 101, consist with Fast intake, long tube and such, all without extreme violation of the basic design parameters as to make my LS2 into an money pit.
I do understand we all have different levels of "Go For Broke" tolerance.
