Vitesse Throttle Controller - Wow!
Most people that get his custom tune are very satisfied with the results.
Would you share what you feel the differences are between the Vitesse and the Sprint Booster?
I'll bet this thing even makes a stock car drive like a completely different car. You definitely will have a smile on your face.
Tom you can log throttle blade position and pedal position with HP Tuners and see what the difference is for various pedal positions with the unit. You'll be able to see different curves on your scanner, blade vs. pedal.
I've had a COW booster for years now and it really works as described here for making the car feel a lot more peppy. And it's great for heel and toe throttle blips which is why I got it. I'm sure this device works the same and as noted has a greater range of adjustability. By the way my Prius has three modes based on different button sets as well, and I understand the C7 has different throttle maps based on different active handling settings as well so this way to modify how the car feels is becoming very common.
Subfloor and I are having some good conversations about his new C7Z06...the relationship between the pedal and the throttle blade is absolutely NOT direct and completely different from a c6. You hit the pedal and the computer decides what to do with the blade and it's not anywhere near linear, you should see his scans.
I spoke to Howard at Redline about this the other day, he told me that the new controllers base throttle openings on a polynomial calculation - pedal input is a "suggestion" to the computer, and it gives what it thinks it should give based on available traction, torque limits, etc. etc. It's a huge difference between pedal input and throttle blade when you see a scan.
For old guys like me, I said this sounds like a Quadrajet with it's air valves on the secondaries - the secondary throttle blades are mechanical, but the air valves control the air and fuel admitted to the engine, it only draws as much as it needs (based on the spring wrap you set if you know that little secret). It also reminds me how at 12 years old I could ride my buddy's tiller engine mini bike a lot faster than he could...because I knew how to use my finger to bypass the governor on a B&S engine to give WOT. I told Subfloor too bad he couldn't run a string from the throttle blade in his car to the interior like I ended up doing on the minibike. lol
If I want more power I just step on the gas pedal harder and leave it (or shift to) in a lower gear.
Car seems to respond pretty well.
Here's a write up I did years ago wherein I tried to explain it. It's easy to feel but somewhat hard to explain to someone who hasn't felt it.
One thing is for sure, everyone on this thread raving about how much of a difference it makes are not making it up, you'd never get that many people to create false recommendations...this isn't Yelp you know....
https://www.corvetteforum.com/forums...-buck-mod.html
So the real answer to my question is, no you can not.
This Vitesse throttle controller is comparable to a BMW throttle controller called a PedalBox.
This Vitesse throttle controller is comparable to a BMW throttle controller called a Pedal Box.
So the real answer is yes, you can.
Now this Vitesse is a lot easier to install that removing your computer and sending it in (I did it when Chuck was in the same town) so there's other benefits to this, but to answer your question, yes you can change on the fly.
