Vitesse Throttle Controller - Wow!
Old Feb 29, 2016 | 05:20 PM
  #661
NashvilleGrandSport's Avatar
NashvilleGrandSport
Originally Posted by 7.0Ltrs of Love
where is everyone buying these from? checked out the Vitesse site and it says "out of stock"... wondering for how long..?
Send Ahmed an email through the website or call the number on the website. The word is he is very responsive.
Old Feb 29, 2016 | 05:32 PM
  #662
Dcasole's Avatar
Dcasole
That's because we bought them all
Email them and ask as they are very responsive
Dave
Old Mar 2, 2016 | 11:10 PM
  #663
7.0Ltrs of Love's Avatar
7.0Ltrs of Love
ya sent an email was told he was waiting on some delphi harnesses should be by end of the week... placed an order hopefully will see one soon! need to wake up my ZR1, oem throttle response is lagging big time compared to the wifes ZL1!
Old Mar 9, 2016 | 12:25 AM
  #664
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default You're correct.
Originally Posted by schpenxel
My understanding is there are limits to what you can do tune wise. There is a table that defines the relationship between the pedal position and throttle blade position (actually there are several, trucks use different ones for 4x4 mode, towing mode, etc.)
If I'm reading it right, I am surprised to see how much pedal movement it takes to really get to "wide open".
HP Tuners has a big warning on those tables that if you enter something that the TAC module doesn't like, you can brick your ECM permanently. I haven't had the ***** to try messing with them, although I really do want to speed it up a bit. I haven't had the nerve to try it though.
This type of box is very very common in the BMW world. A lot of the drive by wire BMW's have a horrible dead spot when you first start to push own the throttle.. so these types of boxes improve that quite a bit.
I'm sure all this is doing is manipulating the signal it receives from the throttle pedal to change the relationship from actual pedal position to what the ECM thinks the pedal position is.
You're correct.
That's the C6 setup, but the C7 is totally different.
Don't mess with the C5 and C6 stuff unless you have experience. Bad things can happen.
The C7 is totally different and likely should not be messed with either as it has an effect on the
engine power and changes spark and fuel as well.
The C7 is much like the way a DURAMAX DIESEL works.
Chuck CoW
Old Mar 9, 2016 | 08:52 AM
  #665
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I have messed with those tables a bit now now on an E40 with varying results. The good news is I haven't bricked anything. The bad news is if I change anything more than a few % then I end up getting an ECM Checksum Error ~30 minutes or so into driving it, which I can only assume is it not liking my "adjustments".
So, I've stopped messing with it. I haven't gotten around to trying it on an E38 yet.
Old Mar 9, 2016 | 10:07 AM
  #666
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Same difference.... With E38
Same difference.... With E40 & E38 1% above what the throttle controller expects... P0606 and you're down.
Same thing happens when you try to copy a tune with my CoW BOOSTER! in it.... Touch the pedal..... P0606
E40 is a bit more messy.... The throttle tables change around a lot with the 6 different operating systems
out there..... You have many more chances of getting in trouble with E40.
If you'd like to "experiment" a bit with it, privately PM me and I'll work something out for you so you can tinker.
Chuck CoW
Old Mar 9, 2016 | 10:41 AM
  #667
pyrodav's Avatar
pyrodav
Im over here like "why every single Vitesse thread?"....Geesh
Old Mar 9, 2016 | 08:36 PM
  #668
OlyC6's Avatar
OlyC6
St. Jude Donor '16-'17, '19
Originally Posted by WasVette
That's another good mounting option - my '13 doesn't have that panel. You'll like having easy access to the controller as you experiment with the settings.
After several weeks of having this piece, I am still amazed at how well it works.
Is the wiring harness leads long enough to go another few inches and mount the controller in the armrest storage area?
Old Mar 15, 2016 | 08:24 PM
  #669
WasVette's Avatar
WasVette
Originally Posted by Joe_G
WasVette I'm thinking the company ought to send you a spare as a marketing fee! You're a great salesman. lol
Joe - I second that All kidding aside, the thread did get the sales ball rolling
Old Mar 15, 2016 | 08:30 PM
  #670
WasVette's Avatar
WasVette
Should be long enough based on memory. I like the ashtray area as it's not used anyway and I could do a quick, clean install without having to pull the console again.
Old Mar 19, 2016 | 07:46 AM
  #671
ranria22's Avatar
ranria22
Cruising
Default deceleration
I was wondering if this changed the deceleration of the engine when letting up on the pedal. I like the way the old carb engines decelerated, more like a prostock car.
Old Mar 19, 2016 | 08:56 AM
  #672
Dcasole's Avatar
Dcasole
Same decell as you have now ...
Dave
Old Mar 19, 2016 | 11:02 AM
  #673
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I know what you mean, some carb cars would rev up and down quickly and give that "vroom-paaaa" sound I grew up liking. Modern cars seem to hang and rev down more slowly.
In a c5 there were throttle cracker and follower tables that you could adjust to open or close (respectively) the throttle more or less quickly. Not available on the c6 as far as I've seen (though I haven't tuned every model, mostly the older stuff for me). If you adjust the throttle follower to close the throttle too quickly it'll increase the tendency for the car to stall.
I can tell you the cow booster, and I'm guessing the vitesse, WILL make the engine rev up more quickly but I've found that the revs will fall the same as stock, at least with the cow booster and I imagine the vitesse as well as I understand how it works.
If you want the engine to rev up and down more quickly a light flywheel will help. But, you lose some drivability with that, it's harder to take off at low speeds.
You can hear it in this video, if you're in tune to how a c6 revs up mine revs up more quickly but still revs down with a stock slope.
Old Mar 19, 2016 | 01:27 PM
  #674
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I've had some luck messing with DCFO, coast down timing and min air to make it behave a little differently during decel.
Old Jul 10, 2016 | 10:53 AM
  #675
--Z06--'s Avatar
--Z06--
Just installed and went fora quick spin. And I DO mean spin!! Put it in SP5 and noted immediate difference when driving. Put it on SP9 and the car is an ENTIRELY different animal. Came off the line like it was on boost. I swear I have never installed a better mood for the time and effort involved.
Old Jul 10, 2016 | 10:57 AM
  #676
Andy05C6's Avatar
Andy05C6
Any word in the controller for the 2005s?
Old Jul 10, 2016 | 12:46 PM
  #677
yellowmnm's Avatar
yellowmnm
Default yes
that's were mine is mounted inside my center council. no wires show clean install.
To Vitesse Throttle Controller - Wow!
Old Jul 10, 2016 | 01:03 PM
  #678
--Z06--'s Avatar
--Z06--
I just got into the car again and now I have CEL.
Any ideas?
Old Jul 11, 2016 | 09:24 PM
  #679
Ira T's Avatar
Ira T
I e-mailed him a few weeks ago and he hasn't got it figured out yet.
There are a lot of us waiting...
Old Jul 12, 2016 | 07:54 AM
  #680
--Z06--'s Avatar
--Z06--
Any ideas?
CEL cleared after an overnight. THis thing is INSANE!
