Hard Data ....
Cheers
Cheers
Wow, could Mercedes have made the car any uglier than that? I doubt it!
The guys who don't like the C7 styling need to take a look at that abortion. Can we say aggressively ugly?
Laptimes... http://www.sportauto.de/rundenzeiten...itHH&order=ASC
Review...http://www.sportauto.de/vergleichste...b-4806450.html
Cheers
It looks like a high school seniors dream car with all the ricey scoops, dooflickeys, and that retarded JC Whitney park bench bolted on the back of it.
At least from the rear...you know what it is.
As for this rev limiter would it be possible it's variable? If I'm not mistaken the GT500 has a rev limiter that's either 6200rpm or 7000rpm depending on temperature but more importantly duration. More than 8 seconds at over 6200rpm throws the 6200rpm redline. Seems like the dumbest redline I've ever seen but Mustang drivers never seem to do circuit racing or autocross so it probably doesn't matter for the usual application.
Could the 7200 RPM be the redline for an optional engine that will indeed have more horsepower than the base LT1 engine and that is what the SAE paper is about? I Don't know and neither do you, so I'll stick with the known information that GM has released so far regarding the C7's LT1 to be used in the base C7..
As the other posters say, on page 28, in Figure 55, there is a graph comparing Gen 5 6.2L to Gen 4 6.2L. LT1 and LS3 are specifically named in the caption and on the data series labels. The X-Axis has engine speed from 1000 to 7000 RPM every 1000 RPM. The Y-Axis has no scale, but each "minor" axis on the Y is in 10 kW increments. The power curves for both engines are overlaid. Eyeballing on the graph, it appears the LT1 has ~26-28 Nm more tq than LS3 at around the same ~4600 rpm (LT1 appears to peak slightly earlier). The LS3 power graph stops at the 6600 rpm, while the LT1 graph proceeds to ~7200 rpm. Peak HP in the LT1 occurs at approximately 6800 rpm and drops off 8-10 HP by cut off. At peak, the HP appears 26-27kW higher than LS3.
26 Nm = ~20 lb ft
26 kW =~ 35 HP
That puts the LT1 at ~444 lb ft of tq and ~465 hp using base exhaust LS3 numbers.
The graph only shows the upper ~180 kW, Nm of power/tq, so it is squished a bit.
In the graph, caption, and blub discussing figure 55, there was no mention of fuel used, or if they were "official certified SAE". The LT1 was called out specifically, but it is possible that this graph is having them run it at higher RPM than will be allowed in a stock production C7. Eyeballing the graph, if the LT1 was only reved to 6600, the peak number does not change much since peak power occurs around that area.
It is what it is.
Sounds like a great engine to me. I was just looking at a dyno chart on my 350Z (basically stock @ 164,000 miles), and it hits peak torque @ 4800 RPM but drops considerably after that. Peak power is at 6100 RPM (245 to the wheels), but the peak is pretty sharp and by redline (6600 RPM) the power has dropped significantly (down to 225).
Pretty impressive if the LT1 can indeed rev to over 7000 RPM and only drop 8-10 HP from peak. Seems like they really have managed to maintain the torque well over the full power band.
-T
