C7 engine failure
Old Sep 9, 2014 | 08:29 AM
Boomer111's Avatar
Boomer111
Default C7 engine failure
http://www.autoblog.com/2014/09/08/c...rouble-report/
Old Sep 9, 2014 | 08:58 AM
Mike Mercury's Avatar
Mike Mercury
https://www.corvetteforum.com/forums...road-test.html
Old Sep 9, 2014 | 09:05 AM
bjhayes's Avatar
bjhayes
Wasn't there a thread a while back about incorrectly labeled oil filters?
Old Sep 9, 2014 | 09:38 AM
MrGeorge's Avatar
MrGeorge
Maybe it makes sence to have the filter and oil changed sooner than later.
Old Sep 9, 2014 | 09:43 AM
AFVETTE's Avatar
AFVETTE
I change the oil/filter right at 1000 miles on EVERY car I have owned (even pre-owned ones). My 2014 Stingray is sitting at 957 miles on it and will be taking it to my dealer this week.
It may be a waste of resources, but it makes me feel better.
Tom
Old Sep 9, 2014 | 09:48 AM
RottenII's Avatar
RottenII
Tom
My exact thoughts. I'm at 967 and its going in Friday.
Old Sep 9, 2014 | 09:58 AM
Larry/car's Avatar
Larry/car
My dealer is one of the will not change the oil until DIC is at 22% under the 24 month free scheduled maintenance plan included with the car's purchase. Good enough for GM, good enough for me. Satisfies warranty requirements.
Old Sep 9, 2014 | 10:00 AM
1SG_Ret's Avatar
1SG_Ret
Just a case of bad mojo IMO. Faulty oil filter causes engine to break. Too bad it happened on a long term test car, where it can be reported as "Car and Driver Uncovers trouble with Corvette Stingray's LT1 V8"
Just another case of a sensational headline that (in our sound bite culture) implies one thing while the facts reveal something entirely different.
Unless we start hearing this from a number of sources with the same causation, I'd not concern myself.
Old Sep 9, 2014 | 10:01 AM
HolyRoller's Avatar
HolyRoller
Tom
Looks like the cause was a defective oil filter shedding a piece of metal into the oil stream. So by changing from a known good filter to an unknown one, you just doubled your chances of the same thing happening to you.
Old Sep 9, 2014 | 10:08 AM
HolyRoller's Avatar
HolyRoller
I remember the early days of the F-14, whose airframe did not get along well with its engines for awhile. The headlines would claim "Another Navy F-14 Fighter Plane Crashes" when they should have said "Two More Crummy TF-30 Engines Crash While Installed in a Navy F-14 Fighter Plane."
Old Sep 9, 2014 | 10:13 AM
Eric ray's Avatar
Eric ray
https://www.corvetteforum.com/forums...-problems.html
Old Sep 9, 2014 | 10:19 AM
dbdave's Avatar
dbdave
If the filter, in fact, was the cause of the problem, I would definitely like to know the batch number of the filter and if all with that batch number are being pulled from the inventories.
Old Sep 9, 2014 | 12:09 PM
hawkgfr's Avatar
hawkgfr
Your dealer has been overruled....You CAN get the oil changes anytime you want now.(according to other threads in this forum and the customer service person)
Old Sep 9, 2014 | 12:21 PM
NSC5's Avatar
NSC5
It certainly doesn't hurt to do a quick audio/visual inspection of the filter. Several years ago I picked up a couple of AC/Delco filters for my 6.6 Duramax and I noticed one rattled when I picked it up. I shook it in the store and a couple of little fragments of metal came out of what should have been the clean side. I have made it a habit of checking filters closely since then. I really like the open construction drop in cartridge filter in my Cadillac 3.6, I wish GM used those for more of their engines.
Old Sep 9, 2014 | 12:33 PM
kp's Avatar
kp
Or, you could have a 'bad' filter on your car now and changing it can reduce the chance to zero.
Goes both ways..
Sure, they know what shocks had bad welds and they should know the 'bad' batch of filters. They all have inventory numbers on them these days. I'm a bit of a skeptic on the oil filter having anything to do with it, since its not the only C7 engine that had bearing problems.
I have had some pretty nasty looking oil filters new in the box, unless you cut it apart its hard to tell. Either way, I'll still use AC delco filters and let GM worry about the bottom end staying together for the next 4.5 years
Old Sep 9, 2014 | 01:19 PM
Detroit Steel's Avatar
Detroit Steel
CorvetteForum Editor
Default C7 Engine Blows in the Car and Driver Long-Term Test Car
Hell, even the best of the best have a bad day sometimes. That appears to be the case with a manual Z51 Corvette loaned to Car and Driver magazine, which recently reported that the engine blew on their long-term C7 at around 6,000 miles.
Read the rest on the Corvette Forum homepage.
Old Sep 9, 2014 | 03:52 PM
bobby777's Avatar
bobby777
Was it a AC Delco oil filter for sure? Had they just had the oil changed or was it factory fill and filter? thx
To C7 engine failure
Old Sep 9, 2014 | 08:37 PM
Posi6's Avatar
Posi6
Lotta people "poo" "poo"ing the report not worried about the engine? Reminds me of when LS7's were dropping valves left and right.
Old Sep 9, 2014 | 08:49 PM
MrGeorge's Avatar
MrGeorge
Had the dealer change the oil and filter this morning. Car has 1,500 miles on it, should have changed it out at 500 miles. Was willing to pay for the services but dealer ( Lakeside Chev, Rockwall, Texas) , said its on the house. it may still blow but it won't be because I was running the original oil and filter.
Old Sep 9, 2014 | 08:50 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
LS7s "dropping valves left and right?"
Out of almost 38,000 C7s we now know of 2 that have blown their engines. Even if there are a few more I'm not worried.
