C7 fast list!
Old Mar 24, 2015 | 02:56 PM
  #421
Fore58's Avatar
Fore58
Originally Posted by 10mm_
Also for those of you drag racing autos are you leaving it in D? I tried to paddle shift mine on the street and there's a huge delay from when I hit the paddle to when it shifts, I am assuming the paddles are for road racing not drag racing.
The unfortunate thing is the transmission seems to short shift when left in D, or maybe the tach just can't keep up in the lower gears because it revs so fast.
Leave mine in D.
Old Mar 25, 2015 | 10:53 AM
  #422
10mm_'s Avatar
10mm_
St. Jude Donor '15
Originally Posted by Fore58
Leave mine in D.
Ever notice it short shift on it's own? Usually first and second, I have seen this on PDR recordings as well.
Old Mar 25, 2015 | 12:46 PM
  #423
Fore58's Avatar
Fore58
I have the A6.....so it seems like the A8 is a little different from first to second. But I can tell you that it all depends on your launch technique. I honestly believe that the shift from first to second in D mode is going to react to on how high or low you stall it from launch. The A8 is so quick from first to second to what I've noticed from your video and others. When you get a chance, go back to the C7 Fast List and read the technique from WFARMER,Snorman and VNAMVET.
Old Mar 25, 2015 | 03:19 PM
  #424
10mm_'s Avatar
10mm_
St. Jude Donor '15
I think I asked about technique but never got a response, I didn't realize they had already typed it somewhere in the thread. I will re-read back through and see.
I am almost thinking that letting the converter flash a little bit off idle might be better than what I was doing, I brought it up on the converter about as hard as I could (2100 rpm ish) and it just hooked and went. It's amazing how well these tires work with a little heat in them.
Old Mar 26, 2015 | 01:51 AM
  #425
wfarmer.z's Avatar
wfarmer.z
11.77 or 10.77?
Sorry 10.77 / 1.64 60'
Old Mar 27, 2015 | 01:39 PM
  #426
10mm_'s Avatar
10mm_
St. Jude Donor '15
I think I will head up to Richmond tomorrow to try for a good time, it should be pretty cool air.
In case anybody is in the area and wants to join.
Old Mar 27, 2015 | 03:18 PM
  #427
wfarmer.z's Avatar
wfarmer.z
I think im taking the Z06 there or mir tomorrow. If I end up at Richmond, hope to see you there
Old Mar 27, 2015 | 03:27 PM
  #428
10mm_'s Avatar
10mm_
St. Jude Donor '15
Awesome, it would be great to meet up. I have a white A8 Z51.
In your opinion is there a difference in times/mph for MIR and Richmond? Weather and traction being equal.
Old Mar 27, 2015 | 05:08 PM
  #429
wfarmer.z's Avatar
wfarmer.z
I run about the same times at both tracks.I figured id run tomorrow, there was a guy at the dealership taking off a set of the factory Z07 sport cup 2's so I was lucky enough to grab them from him. Im getting them mounted as we speak and hopefully they will help on the track times
Old Mar 27, 2015 | 05:46 PM
  #430
10mm_'s Avatar
10mm_
St. Jude Donor '15
That's awesome. I bet people would lose it if you managed a 1.5 60' on stock tires.
Also FYI they cancelled MIR tomorrow.
Old Mar 27, 2015 | 06:02 PM
  #431
wfarmer.z's Avatar
wfarmer.z
I just seen that. I think they should help on the 60ft even though it left pretty good on the super sports.
Old Mar 27, 2015 | 07:07 PM
  #432
wfarmer.z's Avatar
wfarmer.z
It looks like Richmond will be cancelled Saturday as well. acording to their website they are moving it to Sunday
Old Mar 27, 2015 | 09:08 PM
  #433
10mm_'s Avatar
10mm_
St. Jude Donor '15
Old Mar 28, 2015 | 07:39 PM
  #434
pettvette's Avatar
pettvette
CI 5-6-7-8-9-10-11 Vet
With 650 miles on her I made it to Beech Bend in Bowling Green KY. Temps were in the mid to high 30's making traction an issue. Had to roll into the throttle to get a decent launch. Was hoping for more but I think the track was just too cold... For what ever reason the best passes were made in Sport mode.
The car is a 2LT A8 with the ZF1 package, NPP & 2.41 gears
Traction control on, rolling into the throttle
Year of the C7:...2015
Tires used on the pass: stock 29 lbs
Performance Mods (if any)...:None
Category submitted for: ...Stock
60'.............1.952
330'...........5.167
660'...........7.800
660’ mph...94.37
1000'..........10.052
1320'..........11.954
1320’ mph…..118.35
Name of the track: Beech Bend
Date of pass:....3/28/15
Weather conditions: (include Density Altitude, if known): 35-42 degrees
Old Mar 29, 2015 | 12:14 PM
  #435
Fore58's Avatar
Fore58
Nice run.....glad to see more A8's on the Fast List.
Old Mar 29, 2015 | 01:16 PM
  #436
10mm_'s Avatar
10mm_
St. Jude Donor '15
I'm at Richmond now trying to move up the list.
The air is good, track is not very sticky though
Old Mar 29, 2015 | 03:15 PM
  #437
Fore58's Avatar
Fore58
Get that 60' down and you should be at least 11.70/11.80's. We may be done down here in sunny Florida for personal best. Good luck
To C7 fast list!
Old Mar 29, 2015 | 09:39 PM
  #438
10mm_'s Avatar
10mm_
St. Jude Donor '15
I did just that
Old Mar 29, 2015 | 09:53 PM
  #439
10mm_'s Avatar
10mm_
St. Jude Donor '15
Bump me up the list please.
Year of the C7: 2015 A8 Z51
Performance Mods (if any): none
Category submitted for: bone stock on stock tires
60'............. 1.68
330'...........4.83
660'...........7.42
660’ mph...95.62
1000'..........
1320'..........11.52
1320’ mph…119.52
Name of the track: Richmond Dragway
Date of pass: 3/29/15
Old Mar 29, 2015 | 10:12 PM
  #440
Fore58's Avatar
Fore58
Nice run 10mm......
Best 60' so far with A8
