C7 fast list!
Old Oct 31, 2015 | 05:32 PM
  #521
10mm_'s Avatar
10mm_
St. Jude Donor '15
I hope Richmond opens again this year. I ran my best time there id love to go back on spray
Old Oct 31, 2015 | 07:28 PM
  #522
C7/Z06 Man's Avatar
C7/Z06 Man
Originally Posted by wfarmer.z
The weather seemed good so I went to the track last night. Went to VA Motorsports Park since Richmond Dragway still isn't finished with resurfacing. Place was packed. Lots of break downs and track clean-up. Only got 2 runs. Both were new best times for me though!
2015 Z06 A8. Still all stock on drag tires. DA was around -500
I was just on the dragtime site for DA and I noticed that the two DAs they have listed, one before you ran and one after is -575 or -677.
Old Nov 1, 2015 | 01:50 PM
  #523
wfarmer.z's Avatar
wfarmer.z
Very possible. We were using a fellow racers info who had a gauge at the track. Dragtimes wasn't working on any of our phones that night. It was the best air the Z has been in since last spring for sure!
Old Nov 1, 2015 | 01:54 PM
  #524
wfarmer.z's Avatar
wfarmer.z
They open back up next Saturday for T & T
Old Nov 1, 2015 | 02:09 PM
  #525
Complete Street's Avatar
Complete Street
Supporting Vendor
Year of the C7: 2014 M7 2LT (Non-Z51)
Tires used on the pass: MT 285/35/18
Performance Mods (if any): A&A YSI Kit, Low Boost 7psi, Kooks Headers, DRs
Category submitted for: Boost
60'............. 1.639
330'........... 4.500
660'........... 6.856
660’ mph... 105.51
1000'.......... 8.865
1320'......... 10.554
1320’ mph… 132.62
Name of the track: Cecil County Dragway
Date of pass: 10/23/2015
Image of complete Time Slip: See attachments
__________________
www.cspracing.com * Complete Street Performance * CALL US 610-628-1563
And don't forget to Like us on Facebook and follow us on Instagram @completestreet
Old Nov 3, 2015 | 09:17 PM
  #526
Pete@ChampionMotors's Avatar
0Pete@ChampionMotors
Former Vendor
Year of the C7: 2015 A8 Z51
Tires used on the pass: MT 18'DR
Performance Mods: A&A YSi, Champion Cam, Arh headers, stock motor
60'-------------1.644
330'------------4.307
1/8-------------6.477
1/8mph--------115.86
1000-----------8.360
1/4-------------9.962
1/4mph--------141.22
Name of the track: Toronto Motorsports Park
Date of the pass: Nov 3/2015
Old Nov 4, 2015 | 09:50 AM
  #527
10mm_'s Avatar
10mm_
St. Jude Donor '15
Wow that is awesome! 3rd place just got claimed
Old Nov 4, 2015 | 12:46 PM
  #528
Dave01GT's Avatar
Dave01GT
http://youtu.be/8S0XNE975uI
Congrats! I'm hoping for the same results when I take mine to Memphis this weekend. Did you go with the 305/40/18's? How much boost?
Old Nov 4, 2015 | 11:04 PM
  #529
Former Vendor
305/45/18 Radial R
13psi
Old Nov 7, 2015 | 06:52 PM
  #530
Dave01GT's Avatar
Dave01GT
Will upload the video when I get home. Here's my updated slip. Took it down to Memphis since gateway is closed for the year.
Old Nov 8, 2015 | 12:10 PM
  #531
pettvette's Avatar
pettvette
CI 5-6-7-8-9-10-11 Vet
Default Improved times
Made it to Beech Bend Raceway Park yesterday Nov 7th and got to make 5 passes in my 2015 ZF1 A8 cp. All the runs were in the 11.80's with the best being 11.82... The weather was cloudy and the temp was stead at 60. I tried both power braking slightly, and mashing the gas from idle both results were pretty close with leaving from idle was the quickest. The slowest pass was 11.88. I did a pretty good burnout to heat the tires on all passes. the best 60ft time was 1.79..... At least that moves me up the list a few spots......
Year of the C7: 2015 A8 ZF1 Cp. 2.41 gears, NPP
Tires used on the pass: Stock Z51 style Michelins set at 28 lbs hot
Performance Mods (if any):None
Category submitted for:Stock C7
60'.............1.845
330'...........5.057
660'...........7.686
660’ mph...94.69
1000'..........9.932
1320'..........11.823
1320’ mph…119.22
Name of the track: Beech Bend Bowling Green KY
Date of pass: 11/7/2015
Weather conditions: (include Density Altitude, if known): 58-60 degrees DA approx. +400
PDR video of the 11.88 run...
I ran an 11.83 on this run the 580HP Camaro ZL1 ran a 12.09 (GoPro mounted next to the license plate...)
Old Nov 8, 2015 | 07:17 PM
  #532
Former Vendor
http://youtu.be/gHpc9tOmR-c
Awesome pass Dave01GT, pretty sure you just claimed my #3 spot on the list. Did you end up sending your stall out to Circle D? If yes how much stall increase did you see?
Congrats!!! on #3
Old Nov 8, 2015 | 08:00 PM
  #533
Dave01GT's Avatar
Dave01GT
Congrats!!! on #3
Thanks! Yes the converter was sent to Circle D. I honestly haven't paid much attention to what it flashed to. I've found my best 60' by just launching off idle. They told me it would probably only be a few hundred rpms higher. I went from constant 1.63-1.65 with the stock converter to 1.53-1.55 after Circld D modified it. I am still on the factory shift points, so I always try to concentrate more on clicking the paddle and redline. That was my only clean pass I made. Most spun a bunch, or I wouldn't click in time and hit the limiter. I had a best of 6.42 1/8 but messed up a shift. Think it could've gotten a 9.89.
Old Nov 9, 2015 | 05:52 AM
  #534
Fore58's Avatar
Fore58
660’ mph...94.69
1320’ mph…119.22
https://youtu.be/LLAuihY6Afo
https://youtu.be/aB6ojuzsqRM
Nice run.......actually that would put you in 7th place and I have to drop one spot.
Old Nov 9, 2015 | 11:53 AM
  #535
pettvette's Avatar
pettvette
Sorry about that.... I tried hard to get an 11.7, but it didn't happen.... Odd that I'm in 7th on both the C6 & C7 Stock Fast list...
Old Nov 9, 2015 | 06:23 PM
  #536
Ls2000's Avatar
Ls2000
Size:  518.2 KB The new time was accomplish with Texas Speed headers. Nitrous outlet direct port system on a 200 shot. Ccw 17/10.5 Ccw rear wheels and 275-40-17 MT drag radial. Front Ccw 17/4. I am still trying to get the transmission to work better under new power. 620hp-714tq 6sp auto stock air box stock intake manifold, full e85 Texas Speed headers brisk spark plugs stock can and heads.
Old Nov 14, 2015 | 12:03 AM
  #537
Complete Street
Supporting Vendor
Performance Mods (if any): A&A YSI Kit, Medium Boost 10psi - But with slipping belt seeing only a peak of 8.5 psi, Devil's Own Meth Injection, Kooks Headers, DRs
60'............. 1.610
330'........... 4.371
660'........... 6.646
660’ mph... 108.91
1000'.......... 8.565
1320'......... 10.176
1320’ mph… 140.56
Date of pass: 11/13/2015
Image of complete Time Slip: See attachments (Right Lane)
Other notes: I have a pulley that was making a hair over 10 psi on the dyno, but at the track it was slipping - the belt is a hair too long, so it was only seeing 8.5 psi before slipping and dropping down to 6.5 psi. Not sure if you want to list it at 10 psi, or 8.5 psi. Dynoed at 700 rwhp on 10 psi without the belt slipping.
Its too bad because it would have made it close to a 9 second pass with a little more mph. Next up raising the boost further and we'll see if we can power into the 9s.
There are a couple videos of the run that I'll try to link when I get them.
To C7 fast list!
Old Nov 14, 2015 | 12:08 AM
  #538
10mm_'s Avatar
10mm_
St. Jude Donor '15
Originally Posted by Ls2000
Attachment 47929749 The new time was accomplish with Texas Speed headers. Nitrous outlet direct port system on a 200 shot. Ccw 17/10.5 Ccw rear wheels and 275-40-17 MT drag radial. Front Ccw 17/4. I am still trying to get the transmission to work better under new power. 620hp-714tq 6sp auto stock air box stock intake manifold, full e85 Texas Speed headers brisk spark plugs stock can and heads.
Why was your MPH so low?
Old Nov 14, 2015 | 12:11 AM
  #539
10mm_'s Avatar
10mm_
St. Jude Donor '15
660’ mph... 108.91
1320’ mph… 140.56
Old Nov 14, 2015 | 09:26 AM
  #540
Complete Street
Supporting Vendor
Video for my latest time.
