C8 General Discussion The place to discuss the next generation of Corvette.
Sponsored by: Wheel Design
C8 problems
Old Apr 13, 2021 | 01:57 PM
  #1021
RIXKIX's Avatar
RIXKIX
First outing with my C8, s/n around 13500. Delivered in late October. Ran about 100 miles on it locally, in storage since then. I decided to take advantage of the weather on Easter and drive to to visit my folks. Crapped out about 15 miles from home, on the way back. Rough running, ESC light, engine light. Limped home. Dealer tech found a valve spring broken for #1 cylinder. They changed that spring only. Car had about 350 miles on it when this happened. Running fine now. Hoping for the best as break-in continues.
Old Apr 13, 2021 | 02:06 PM
  #1022
RKCRLR's Avatar
RKCRLR
Assuming your car is in the affected range for valve springs, the dealer didn't follow the TSB to replace all springs on a Corvette.
Old Apr 13, 2021 | 02:29 PM
  #1023
Fast Dawg's Avatar
Fast Dawg
I would print that bulletin and take it back to the dealer. I would leave it there until they replaced all the valve springs they were supposed to replace. Otherwise it may end up in the shop to get the engine replaced.
Old Apr 13, 2021 | 09:34 PM
  #1024
Grey's Avatar
Grey
I have 10200+ Long Beach Red, HTC 3LT mine went down at 63 miles #5 valve spring, Sept 20. That was the time period GM had just begun to realize the scope of the valve spring problem. They replaced all 16 springs, your build period is in the affected motor production. After the valve springs were replaced, car has been perfect. Send a note if I can help you further.
Old Apr 15, 2021 | 11:09 AM
  #1025
Cali2Indy's Avatar
Cali2Indy
What is the affected VIN range?
Old Apr 15, 2021 | 11:29 AM
  #1026
RKCRLR's Avatar
RKCRLR
The TSB (PIP5752A) is by build date, June 1, 2020 to September 15, 2020
Old Apr 15, 2021 | 11:40 AM
  #1027
Cali2Indy's Avatar
Cali2Indy
Thanks for your quick reply!
Old Apr 15, 2021 | 12:06 PM
  #1028
Cali2Indy's Avatar
Cali2Indy
I’m picking up a 2020 C8 next week and it falls within that range. Hopefully the odds are against this anything like this happening. Will be driving it 2.5 hours back home. I’ve been hearing about the direct injection noise that some of my OCD brothers are hearing from the engine bay. Other than the check engine light and the motor going into limp mode does anybody know what the ticking sound difference is between a broken valve spring and just the normal sound of the ticking sound of direct fuel injection?
Old Apr 15, 2021 | 02:36 PM
  #1029
RapidC84B's Avatar
RapidC84B
If a spring breaks it'll create a missfire which will throw the CEL. The direct injection ticking is totally normal and prominent.
Old Apr 15, 2021 | 03:08 PM
  #1030
Cali2Indy's Avatar
Cali2Indy
Great thank you very much!
Old Apr 16, 2021 | 08:05 AM
  #1031
Fast Dawg's Avatar
Fast Dawg
If I were in your situation I would be very nervous about driving that car off the dealer lot. My son-in-law owns two Matco Tool distributorships. He was at a local Chevy dealer that is well known in the area for getting their techs trained to work on Corvettes last week. He sent me pics of a 2020 C8 on one of their lifts and a picture of the hole in the engine block. There were two more on their lot with the same problem. I've seen a post by a member here that he drove his C8 off the dealer lot and after driving it 180 miles this happened to him. I would call the sales manager at your dealer and discuss this issue with them.
Old Apr 16, 2021 | 10:18 AM
  #1032
Cali2Indy's Avatar
Cali2Indy
It’s a private party sale not a dealership. I drove the car already and everything seemed fine, but you are correct anything could happen. I guess like the J&J vaccine I received I’m kinda playing the odds. At least the car is under warranty. I will make sure to bring my AAA card though😀.
Old Apr 16, 2021 | 10:28 AM
  #1033
Jimp94605's Avatar
Jimp94605
I have to wonder why selling the car profit motive?
Good Luck AAA is a good thing
Old Apr 16, 2021 | 10:52 AM
  #1034
Cali2Indy's Avatar
Cali2Indy
Yes He’s flipping the car to make some money, only 200 miles. This is my first Corvette I’ve had multiple Ferrari’s so that AAA card is always with me. I will say though I’ve never been left stranded so I’m hoping for a good experience with the Corvette. However, I’m doing something that I’ve told myself I would never do, which is buy a first year model car. I guess I will find out soon.
Old Apr 16, 2021 | 12:05 PM
  #1035
Jimp94605's Avatar
Jimp94605
Good luck Drive it like you stole it
Old Apr 16, 2021 | 12:15 PM
  #1036
Cali2Indy's Avatar
Cali2Indy
Lol yes! Of course still not over 4000 rpm.
Old Apr 17, 2021 | 01:27 PM
  #1037
skunk22's Avatar
skunk22
Anyone having problems with their XM system? About half or more of the time when starting up it shows
“loading XM” and sometimes it never connects, other times it plays the last channel it was on but cannot change
to any other channel while still showing loading. Then other times it works perfectly. When it shows loading sometimes you can shut the car off let it set there 10 to 15 minutes open the door then close door start the car and it sometimes starts working.
Skunk
To C8 problems
Old Apr 17, 2021 | 04:48 PM
  #1038
Jimp94605's Avatar
Jimp94605
If it were me, I would Call XM to make sure you get your “free” trial service extended. Sounds like its on their end, probably have to download the app again.
Old Apr 18, 2021 | 07:48 AM
  #1039
CapoCam's Avatar
CapoCam
Question for everyone, with the 2021 MY nearing end of production, is it safe to say that most of the major first model year issues have been addressed, (i.e. valve springs). I know there will always be unknown issues that arise but is there any logic in holding off for a 2022 or is the 2021 a stable car?
Old Apr 18, 2021 | 07:53 AM
  #1040
Undy's Avatar
Undy
From: Virginia Beach, VA & Port Charlotte, FL (snowbird)
GM does not have a good track record of solving major problems between MYs. Some of the cases in point: C6 Z06's LS7 engine failures and C6/C7/C8 3LT leather delamination problems. If you want the car just but in without regard to model year.
